Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #3
Maybe they need to stop putting FELs on lawnmowers
That to but there's a demand for loaders on lawnmowers. Larger tractors are designed primarily to handle ground engaging implements then loaders are installed as an afterthought. Going back,manufactures built engines,transmissions,differentials,wheels, axles and a few other components that were interchangeable across a range of horse powers then painted the finished product according to component package.
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #4
Not one word about proper 3 point ballasting to reduce front axle "static" loading.
This was found in the comments:
Brad Jenkins: "The more weight you put behind the rear axle, the more you take off the front axle."
Neil's Response: "Yes, but the amount required to correct it would put the rear axle way over capacity."
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #6
Interesting and likely has a point. Thanks for posting that video.
I don't categorically agree with his numbers or methodology though.
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #7
Its just a whole lot easier when they didn't publish the axle capacities.
Clearly the axles can handle ALOT more than they are rated for. Probably just a MFG's CYA move to deny a warranty claim if they want to
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #8
Why would a manufacturer build a front axel that is already at capacity before the bucket is even loaded?
My question is why someone would buy a 1,500 lb lawnmower and expect to operate it like a 10,000 lb skidsteer?
Or they purposely built them where they would be over capacity so the parts would wear out quicker requiring the owners to bring them in for repair sooner.
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #10
Interesting that without ballast you can only put the weight of the tractor and bucket load on the front axle.
With rear ballast, and a strong loader, you can put a lot more weight (the tractor, bigger bucket load and additional rear ballast weight) on the front axle.
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #11
In my view, none are over rated for capacity. It's the owner that overloads them by adding 'ballast' to the tractor, something I don't do.
It's the human factor at play and humans tend to push the boundaries of everything. Human nature I guess.
Did you actually watch the video?
Please explain as I want to make sure I understand you.
This intrigued me so much that I decided to reach out to Neil directly. He told me that he is going to make a follow up video. Out of respect for him, I will let him provide more explanation first before I give the CVF thought/opinion on it.
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #17
How many front axles ahve been broken on tractors by lifting something that exceeds the capacity?
It seems ridiculous the manufacturer would have a rated load on the front axle that is less than the weight added by maxing the FEL?
My thoughts exactly.
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #19
The video shares that the front axle capacities are way under the load if you are at capacity on the FEL. These are manufacturer specs. Front axle capacity 1600 lbs, load on front axle with FEL at max capacity was 2000lbs.
Granted these are sub compacts...I wonder what larger tractors would show?
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #20
That info does show up on industrial TLBs - even on tractordata but not so much for farm tractors or CUTs
SAE J43... is for wheel loaders and TLBs
Sae J43-2003 | PDF | Loader (Equipment) | Tractor
a highlight of some requirements when testing
The FEL IS mounted along with the heaviest recommended bucket
approved Rear counter weight- using the minimum recommended weight.
here is a Ford 555
Max front axle 10,000 lbs
4536 kg
8,970 lbs (SAE J43)
4068 kg
Max rear axle 12,600 lbs
5715 kg
12,550 lbs (SAE J43)
5692 kg
Seems like there should be a similar standard for smaller machines but have not seen it If I was a manufacturer would error on the side of caution for multiple reasons- which is what it looks like from Neil's reporting
2012 KENWORTH T800 KILL TRUCK (A60736)
2012 KENWORTH T800...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
SKID STEER ATTACHMENT AUGER (A58214)
SKID STEER...
flatbed trailer 24ft (A56857)
flatbed trailer...
2017 FREIGHTLINER CASCADIA (A60736)
2017 FREIGHTLINER...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
