Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #3
Maybe they need to stop putting FELs on lawnmowers
That to but there's a demand for loaders on lawnmowers. Larger tractors are designed primarily to handle ground engaging implements then loaders are installed as an afterthought. Going back,manufactures built engines,transmissions,differentials,wheels, axles and a few other components that were interchangeable across a range of horse powers then painted the finished product according to component package.
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #4
Not one word about proper 3 point ballasting to reduce front axle "static" loading.
This was found in the comments:
Brad Jenkins: "The more weight you put behind the rear axle, the more you take off the front axle."
Neil's Response: "Yes, but the amount required to correct it would put the rear axle way over capacity."
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #6
Interesting and likely has a point. Thanks for posting that video.
I don't categorically agree with his numbers or methodology though.
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #7
Its just a whole lot easier when they didn't publish the axle capacities.
Clearly the axles can handle ALOT more than they are rated for. Probably just a MFG's CYA move to deny a warranty claim if they want to
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #8
Why would a manufacturer build a front axel that is already at capacity before the bucket is even loaded?
My question is why someone would buy a 1,500 lb lawnmower and expect to operate it like a 10,000 lb skidsteer?
Or they purposely built them where they would be over capacity so the parts would wear out quicker requiring the owners to bring them in for repair sooner.
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #10
Interesting that without ballast you can only put the weight of the tractor and bucket load on the front axle.
With rear ballast, and a strong loader, you can put a lot more weight (the tractor, bigger bucket load and additional rear ballast weight) on the front axle.
Wacker Neuson AR14H (A60462)
Wacker Neuson...
Kubota MX5400 land mgmt package
Kubota MX5400 land...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
2000 TEREX 60TON T560 REAR WHEEL DRIVE CRANE TRUCK (A59906)
2000 TEREX 60TON...
WIGGINS 5K FORKLIFT (A58214)
WIGGINS 5K...
17601CFL (A59228)
17601CFL (A59228)
