dstig1
Elite Member
- Joined
- Apr 7, 2010
- Messages
- 4,799
- Location
- W Wisc
- Tractor
- Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
Standard NEC. The kitchen requirements are probably the most detailed and picky of anything for basic residential electric. They require 2 independant circuits serving the countertops, they must both be 20A and most of the time GFI protected. Then no more than 2' along the countertop to any outlet and there are special rules for peninsulas and islands too.
Edit: Gator posted while I was writing... No more than 2' to an outlet is essentially the same as every 4', but there are certain circumstances where that is not true. Say you have a section of counter that is 3' long between the fridge and stove. If you put one outlet at one end of it, the other end of the counter would also need an outlet somewhere to meet the 2' max requirement. If you put one outlet dead center, it would be no more than 18" to the outlet from any point along that counter, so you would be fine with one in that case.
Also there is meeting code minimum, and more importantly meeting your needs above and beyond that. While one outlet may meet code in this case, you may very well want 2, spaced out for better access and so you can plug more stuff in.
