BigBlue1
This isn't 'per code' electrical advice, but in my assessment the rating of a switch is for how much current flows through it. If you have a switch with one or several lights that it switches and the total draw of all lights is less than 15A then a 15A switch should be fine to use. No idea how an inspector would assess that situation. If you had 4 switches with 4 different 5A lights (one per switch) on a single 20A circuit then 15A switches would still be fine even though the circuit was drawing full 20A collectively. In my view...
Outlets are different because the load plugged into one is subject to change and nothing stops a person from plugging in a single thing that draws the peak load of the breaker on that circuit. So I always use an outlet that matches or exceeds the rating of the circuit breaker.
