WoodChuckDad
Elite Member
- Joined
- Jul 15, 2015
- Messages
- 2,714
- Location
- Free Union, VA
- Tractor
- Kioti RX7320 Power Shuttle Cab, Komatsu PC130-6
The electric can be moved however I want or need.
The inspector is going to use the clearances that are specified in the installation instructions. I wouldn’t worry about what the general code says, they use the manufacturer’s spec when there is a conflict between specs. I’m not going to address the location issue, except to say I usually go with whatever location I’d originally planned, unless there’s a pretty big issue that arises that hadn’t been considered. I’m not a fan of changing horses midstream.
Is that your local code? Or a national code?Maybe it is just that you are not done yet and I can't see all of what is going on in the kitchen countertop outlets, but my first impression is that your countertop outlets are not close enough together to meet code. It has to be no more than 2' to an outlet along the countertop with exclusions for sinks and cooktops/ranges. So an open counter needs spacing to be 4' max between outlets. This applies to each individual section like if you have a sink in the middle and counter on each side of it, then both sides need outlets if it is at least 12" wide counter.
You really want to make sure you get this right the first time to avoid major rework. And maybe you are fine and already on top of it. There is only so much one can tell from a video...
Also you probably should vibrate compact that new stoop. It will happen naturally too, but over a very long time.
“The National Electrical Code (NEC) requires outlets in kitchens. This article discusses accessibility to outlets over a counter. The NEC says every piece of counter 12 inches or wider must have an outlet over it. In addition, there must be at least one outlet every 4 feet.”Is that your local code? Or a national code?
