Best Way to Weld Aluminum
/ Best Way to Weld Aluminum #21
Do you just swap liners when going from steel to aluminum? Never really thought about how much time/effort it would take to convert the same machine back and forth:
1. Swap gas bottle (same regulator?)
2. Remove standard wire spool.
3. Swap out liner & tip
4. Install Al wire
5. Reverse for next job on steel
Anything else?
I have a separate whip for aluminum. It is much faster to swap whips. So, I swap whips, wire, and gas bottle.
Eric
/ Best Way to Weld Aluminum #22
Eric
Same regulator? Never checked fitting compatibility between C25 and pure argon bottles. Or do you just run pure argon for everything?
/ Best Way to Weld Aluminum #23
Same regulator for C25 and Argon. Different reg for CO2. For MIG welding mild steel C25 is much better than pure argon.
Eric
light tower (A60352)
KUBOTA U55-5 EXCAVATOR (A59823)
KUBOTA U55-5...
Cat CB24B (A60462)
Cat CB24B (A60462)
2021 CATERPILLAR D3 CRAWLER DOZER (A62129)
2021 CATERPILLAR...
2001 Chevrolet Suburban SUV (A59231)
2001 Chevrolet...
2014 Kia Sedona Van (A59231)
2014 Kia Sedona...
