Learning how to drive with a trailer..
/ Learning how to drive with a trailer.. #1
tomcatg
Kubota L3901DT
Okay this is something that at 58yo, I have never done and its on my list to learn. I have a tow package on my truck, but no hitch and I don't own a trailer yet. To make things more interesting I live in the country and there are lots of windy small roads...some so narrow I fold in my trucks side mirror when I am on them...as I know from experience can be an issue. Two weeks after getting this truck someone came too far over and we slapped mirrors.
Anyway what is the wisest and safest way you guys would recommend to get into this? I want to get a trailer for the tractor at some point and a small camper.
I am one of those people that is typically, cool calm and collected and not easily stressed out. But for some reason thinking about getting stuck on one of these curvy back roads and having to back out or turn around with a trailer etc tenses me up just thinking about it lol.
Thanks in advance!
/ Learning how to drive with a trailer.. #2
Forward, not so much of an issue.
Backwards, a whole 'nother can of worms.
Backwards around a curve with no room? That takes some experience.
It's less difficult with a longer wheelbase and if you can see the trailer. Up until now, I've only had a small 4 x 8 with a short wheelbase. It's a real bugger to back up, even with a car.
Once you get it in to the property, practice, practice, practice.
Opposite steering while pushing an object just takes some getting used to.
/ Learning how to drive with a trailer.. #3
Your in pickle all right!
How about a dual axle, flat bed, short and narrow trailer that will just do the job.
14' - 16' long might do the trick.
/ Learning how to drive with a trailer.. #4
I'd say practise at home, before you get out into the feild. Plus bring someone with you who knows how to back-up or can at least spot you while doing it. Backing trailers on corners are tough when you can't see what's to hit.
/ Learning how to drive with a trailer.. #5
your profile doesn't mention where you are, but if you have someone around that can let you use their trailer and give you some pointers that would be best. Short trailers are harder to control and one tip I always tell my kids is go slow and if you place your hand on the bottom of the steering wheel at six o'clock position the direction you move your hand will be the direction the trailer moves this is more of a reference when sitting there thinking which way to move the wheel. Good Luck
/ Learning how to drive with a trailer.. #6
Shorter trailer ... easier forward as it should track the truck pretty well, but a royal PITA to back up will want to jack-knife/over-run the turn faster. Longer trailer ... easier to back, but may need wider turns going forward since your rear wheels will tend to undercut the back wheels of your truck. Key's wind up being ... practice (somewhere you won't get into a jam or have pressure to do something stupid because everyone's honking horns) & get to know the characteristics of your set-up (length/turning radius/opposing tracks of front/rear of the trailer -- which may require starting or changing the turn earlier than you think) before attempting heavy traffic. Don't oversteer, especially when backing. Try to know your path ahead of time ... not always possible, but it's better to avoid having to back down 2 miles of narrow winding road than to try to attempt it with no confidence. Make sure your mirrors are set up right ... you'd be surprised how many (4 wheelers) do really stupid stuff around trailers because they don't understand things like blind spots & limited movement capabilities. Learn to do a 3 pt. turn/alley backing so if you get into a jam, you can back the trailer into a driveway/sidestreet/farmgate & turn the rig around to be going forward again asap. Don't be afraid to stop & re-assess if you aren't sure what's happening & slow & steady wins the race. Finally, pay attention as you drive watching for bailouts/turnarounds/etc. since you always want "options" if things start snowballing on you. You should develop a feel pretty quick, & it just gets easier and more refined with doing.
/ Learning how to drive with a trailer.. #7
Regarding backing: Practice, practice, practice.
Longer wheel base trailers are easier to backup.
Go slow, because required reactions have to happen fast.
When backing, getting a trailer to turn is the easy part, getting it to stop turning when you want (and not jackknife) is the part that confuses people.
I always tell people it’s best if you think about what which direction (left or right) the bumper of your truck is pushing the tongue of the trailer, versus which direction it should be. Then steer the truck accordingly.
Think about (the overhead view) of backing a trailer and turning trailer left (say) 45° and continuing backwards in a straight line. As you back, the trailer tongue has to first be nudged to the right, causing the trailer tires to track left. However, you now have to “follow” the tongue of the trailer with the push vehicle, keeping the whole rig in relative alignment or the trailer will keep turning (relative to the truck) and eventually jackknife.
“Be the ball hitch”.
This is why saying “You have to turn the wheel this way or that way” doesn’t make sense, because you’re turning it every way depending on where you are in the turn and your alignment situation.
And when thing start to go sideways (they will), just stop, pull ahead 1/2 a length until rig is realigned, and start over. Pull forward and start over as many times as it takes. Trying to correct a backing mistake by continuing to backup almost never works.
When driving forward, remember that like a vehicle rear wheels that track to the inside of the turn when you make a sharp corner, a trailer will track drastically to the inside of the turn. Take wide turns, with the outside nose of truck as far to the outside of the turn as possible, and watch your mirrors to see where trailer is tracking.
/ Learning how to drive with a trailer.. #8
I feel your pain. Until last year I had never dealt with a trailer and I'm 60+.
The advice given here so far is pretty spot on.
One thing that I do is that I never go anywhere where I might run into issues. If I'm going somewhere new I have not been with the trailer I make the trip without it to check everything out, find those places where I could have trouble. Plan what I'm going to do when I get there. I plan a route that avoids the worst trouble spots even if it means I have to travel more miles. And I make sure that I am never in a hurry or do things in a hurry.... even if someone else is in a hurry.
/ Learning how to drive with a trailer.. #9
Thanks in advance!
What truck would have a tow package without a hitch? Does the truck have a trailer wire plug yet?
Once your truck is wired and has a hitch, find someone with a trailer to go through the steps attaching/driving with a trailer. Take the trailer owner out to lunch while you are on the test drive. Get a feel for it before you spend a bunch of money on trailers.
/ Learning how to drive with a trailer.. #10
If you have a garden tractor or a compact one, could you practice with that? I find backing with our atv to be much easier than a truck. Point is to practice with something that is easier.
/ Learning how to drive with a trailer.. #11
Good for you wanting to LEARN before jumping in with a trailer. I would suggest getting with someone who owns a trailer similar in size to what you have in mind. Then go to a large parking lot or even large empty field and practice there where you will be under no pressure and have plenty of room to make mistakes and learn how to correct them. Practice and time is the only way to learn, NO amount of advise (well meaning) from a forum is going to teach you the skills needed.
The information about short trailers is good to know but until you experience it you won't know how bad some can be. Also the placement of your hand on the bottom of the steering wheel is one I have given to others, it helps develop understanding of steering vs trailer reaction. But the BEST advise is get someplace where you have no pressure or distractions and practice, practice, practice.
/ Learning how to drive with a trailer.. #12
Ya, you got that right. Practice and practice before going on the road. That and bring someone with you to help spot if you need to do a corner. Funny being a farm kid, it was so many years ago, I don't recall learning to back things up.
/ Learning how to drive with a trailer.. #13
What kind of truck do you have? If it's a Ford try using that Pro Backup Assist. Then you can watch the steering actions until you get used to it.
I never use it because I have drove tractor trailer for over 37 years but I did try it once in my yard and it was hilarious.
/ Learning how to drive with a trailer.. #14
And as others have said....if you can learn with a short trailer, when you get a longer one it will be even easier.
Try practicing with a tractor or atv with a little cart trailer. Once you get that mastered you will be able to reverse any trailer.
/ Learning how to drive with a trailer.. #15
Farm kids didn't learn how to back up, how to back was breed in at birth
/ Learning how to drive with a trailer.. #16
If you have a hitch receiver mounted on the truck, getting the drop hitch (ball/tongue) is as easy as Lowes or TSC. Know your receiver width (1 1/4", 2", 2 1/2"). Know the drop for the trailer to keep it as level as possible (adjustable drop is better, but pricey.) Know which ball size(s) you'll need -- determined by trailer coupler. Most will be a 2" ball but light trailer could be 1 7/8" & heavy could be 2 5/16". Get the plugs/adapters for wiring. A 7 to 4 is useful, especially if you rent a trailer. Once you have all that, an easy way to practice (if no friends have trailers) is to rent a U-haul trailer from a location with pretty easy access to home. But take their damage Liability waiver in case you "bump" into things at home. Their trailers can be crap, but so was my first car. Start with the open trailers for visibility & work up to their largest enclosed trailer to mimic the camper set-up. (should be between 20 and 40 bucks a day). Practice with that. If you need to play around with more space, rent later in the day then try a school/community college/Walmart or mall parking lot after folks have gone home & it's not full of cars. Have fun. think of it like "drivers' ed for adults.
/ Learning how to drive with a trailer.. #17
You have received great advice so far, its hard to add to anything that's been posted .
I had no one to teach me how to do it, but after 12 years I had delivered over 850 tractors in places that would make you shake your head.
Customers would tell story's of how easy it was to get into their place just to get their machines delivered.
I had to disconnect the trailer a few times and use their tractor to turn the trailer around their snake driveway or back it up at the end of their driveway.
Turning back around with the truck was not an option !
I had a 22' PJ hydraulic tilt trailer with remote tilt, plus the truck length so It was around 48' long
Once you pull your trailer a few times you will gain confidence and put the worry behind you. ;)
/ Learning how to drive with a trailer.. #18
Find someone that is experienced in backing a trailer and has one. A standard 16'x7' to start will be sufficient. Find a big empty parking lot that has good, long stripping. Think school or business. Pull forward and straight with the left tire beside a long line (100+ feet).Using the mirror(s), Practice backing, keeping the trailer tire next to the line. What this does is help you learn how much steering input is needed. Most people tend to over steer/correct when backing. As others have said, a short and/or narrow trailer is much harder to back than a long(er) one. Good luck and let us know your progress.
/ Learning how to drive with a trailer.. #19
Find a large mostly deserted parking lot and practice backing up.
Sounds silly but don’t forget you have a trailer back there.
Anything that weighs a certain amount, roughly 2500 pounds, you need trailer brakes. State laws vary on the weight they are needed.
If you have a Ford with trailer backup assist it’s not so simple. You have to put reflective stickers on your trailer, take some measurements and then set it up in the truck. I’ve never bothered.
/ Learning how to drive with a trailer.. #20
Everyone who starts into towing trailers, forgets about it and runs it into something...
2002 Suncoast 18ft T/A Enclosed Trailer (A61574)
2002 Suncoast 18ft...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
Atlas Copco Air Compressor & Air Dryer (A62613)
Atlas Copco Air...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
