Rear Counter Weight
/ Rear Counter Weight #21
The OP was asking about counterweight on the rear for loads in the loader bucket. Your drawing shows the fulcrum on the rear axle. I was nicely trying to tell you your fulcrum is on the wrong axle for this discussion.
I do know a thing about weight and balance. It was required in my work as an aircraft mechanic of 42 years.
Brandi
Brandi, Bobs drawing has two scenarios. The top drawing shows counterweight and rear tire as the fulcrum. The bottom drawing shows no counterweight but loaded tires and the front tires as the fulcrum. I know you understand the principle but Bobs point in the drawing was loaded tires and wheel weights does nothing for shifting the weight and counterweight behind the rear wheels is necessary. However, it would take a lot of counterweight to move the fulcrum from the front wheels to the rear wheels no doubt.
/ Rear Counter Weight #22
If you all ever played on one of these, the whole scenario isn't hard to figure out.
/ Rear Counter Weight #23
When I made my counter weight, I put together a spreadsheet to add to the fun. It doesn't matter where the fulcrum is, either front axle or rear. The results would come out the same. But using the front axle eliminated the front axle weight as an unknown. I figured two ways - maintaining 25% on the rear axle at max loader capacity to find counter weight, and using 2/3 of loader capacity to find counter weight. Both converged at about 1150lb for a counter weight.
/ Rear Counter Weight #24
Just wow! That's beyond my interest or ability to create, and certainly impressive.
/ Rear Counter Weight #25
This is a good read about ballasting as well, with some actual figures on how heavy/light both axles get.
/ Rear Counter Weight #26
If I need a 'counter weight on the back end, I just hang my Landpride 84" shredder on the 3 point. It weighs about 1800 pounds. Plenty of rear weight.
/ Rear Counter Weight #27
It can't be that simple. Where's your mechanical schematic and flow chart? :ROFLMAO:
/ Rear Counter Weight #28
I can only see one drawing with the fulcrum on the rear tires.
Thanks for explaining there are two drawings!
Bottom line the further from the fulcrum, the less weight it needed. It is all about CG, center of gravity.
Couple of times in the past, when picking up complete trees, I felt my butt getting lite. I didn't add any more weight, I just extended the backhoe all the way out.
hugs, Brandi
/ Rear Counter Weight #30
hugs, Brandi
If you click on the drawing it opens... you will see the top and the bottom scenarios.
/ Rear Counter Weight #31
Counter weight does save the front axel but not in the way most people think. It would take immense counter weight to actually lighten the front axel by a lot. 800 pounds on a 4000 pound tractor isn’t even close to reaching that point. But what the counter weight does do is increase the traction on the rear tires. The front axel ring gears aren’t that strong and weren’t designed to do all the work. If the back tires are more planted and doing most of the work the front axel will be better off.
This discussion is all a matter of degree. 1) The amount of weight on the FEL 2) The amount of weight behind the rear axle 3) How far that weight is behind the rear axle
The point remains true regardless of the fulcrum point... when lifting with the FEL, the less weight on the front axle the better. There's less stress on the front axle's static and dynamic parts... because both can fail.
/ Rear Counter Weight #33
I think @bindian is just looking at the fulcrum diagram with an eye toward keeping the rear planted. For the purposes of keeping the rear on the ground, the fulcrum to consider is the front wheels, and then all of the weight behind the front is challenging the loader and its cargo.
When considering getting weight off of the front axle though, the rear tires are the fulcrum. Weight behind the rear axle works to unweight the front axle because the weight (like ballast box or an implement) is up in the air and the tires are the first thing on the ground.
Try a different picture: pickup truck with a trailer hitch on the bumper. To make it more obvious use a hitch extender. What happens to your steering when you put lots of weight out on that hitch?
The steering gets light, because the weight hanging off the back of the truck is levering the truck with the rear wheels as the fulcrum.
Same thing with the tractor.
But yes it does take a lot of weight or a longer lever arm (weight needs to be farther back) to counter enough to significantly unweight the front axle.
/ Rear Counter Weight #34
Here are some real world (northern) results. The rear box blade is about 500lbs and sand bags are about 1000lbs, for 1500lbs total. The setup has worked very well all winter and it has not felt front-heavy at all, even with a large 8ft pusher full of snow.
/ Rear Counter Weight #35
Hey, I'm interested in that 8 foot pusher and not having chains on the back.
I was of the mindset that I should get chains for the little 6 foot pusher I want to add to my snow weapons.
Do you find yourself alright with traction with just the added weight?
/ Rear Counter Weight #36
For the most part the traction is OK, but could definitely be better. Before next winter I plan to fill the tires, which should help. I also looked at chains but had no idea they were so expensive for large tires. The only reason I have an 8ft pusher is that I got a very good deal from an auction, otherwise I would have selected 7ft - or possibly 6ft if you need to push lots of deep or heavy snow.
The other thing to keep in mind is that a pusher only works well for short runs. If you have a long road or driveway you need to plow, a blade that can push snow to the side would be a better option. I have both a wide flat area and a long driveway and it's a bit of a pain to have to stop, turn off, and dump the pusher multiple times to clear the long driveway.
/ Rear Counter Weight #37
Too little ballast is worse than no ballast at all. I can actually increase the load on the front axle rather than reduce it, which is the goal
/ Rear Counter Weight #38
Instead of me jumping to conclusions can you explain this? Are you saying that it's possible to put some weight behind the rear axle that causes an increased load on the front axle?
/ Rear Counter Weight #39
Exactly what I am saying.
Say you are digging into a pile or a stump...and with no ballast the back wheels keep coming off the ground right.....
Now let's say the tractor weighs 2500#....and is able to expert (lift) 500# before the back wheels hike into the air. That would make 3000# all be on the front axle right......
Now let's add 500# of ballast. And that is enough to make the loader lift 800# before the rears lid in the air now. (Insufficient ballast). But now the 2500# tractor, 500# ballast, and now 800# load is all on the front axle. Total of 3800#.
So let's increase ballast to 1000#. That can now make our loader lift 1100#. AND the rears stay planted but barely....and only retain 500#.
So the 2500# tractor, 1000# ballast, 1100# load is now the total weight of the machine at 4600#.....but still 4100# on the front
Adding ballast/counterweight only adds to the "potential" loading of the front axle. But only up to the point of ENOUGH weight on the back to actually start unloading the front axle.
But this varies by tractor and loader lift capacities. With "just" enough ballast to max out the loaders lift capacity yet have next to zero weight on the rears is the worst case scenario. Because from that point onward any addition rear ballast will shift the fulcrum back to the rear axle and start unloading the front axle. But until that happens.....you are only adding to the potential front axle load
/ Rear Counter Weight #40
I am not an engineer but I believe it depends on where the center of mass is.
I believe your scenarios are only correct in the case where the rear wheels lift off the ground.
1995 CHEVROLET KODIAK C7500(INOPERABLE) (A67714)
1995 CHEVROLET...
1988 Ford 7610 Series II 4WD 97HP Agricultural Tractor (A66734)
1988 Ford 7610...
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
2023 Dodge Challenger Coupe (A66738)
2023 Dodge...
2007 Chevrolet C7500 Auto Crane 8406H 8,400 lb. Crane Mechanics Truck (A66736)
2007 Chevrolet...
Steiner 60in Fairway Mower Tractor Attachment (A64553)
Steiner 60in...
