Pallet forks
/ Pallet forks #1
coolbrze
Gold Member
VA
Kubota MX5800
Looking for a set of pallet forks for my Kubota MX5800. I like my Everything Attachments grapple & landscape rake & am considering one of their pallet forks. What size (42" or 48") & capacity do y'all recommend for my tractor?
/ Pallet forks #2
Get a set of 48'' forks.......they are usually between 3000-4000# capacity, which extends past your lift capacity anyway.
/ Pallet forks #3
48" 3000 -4000 pound capacity. I have Land Prode on my MX5200
/ Pallet forks #4
I agree. 48". Even the 42" probably exceed your FEL capacity. So go for the longer forks. Broadens usage.
/ Pallet forks #6
I use 48”, 4000# forks on my MX 6000. The longer forks are more versatile and easier to see the tips when you’re maneuvering to position.
/ Pallet forks #8
I went with 42" EA forks for my L4701 and wish I had gotten 48". Thought I'd prefer the shorter/more manuverable ones, but have found I'd rather have slightly longer forks, or maybe just extensions so I can more stably lift larger pallets (I've had a few items delivered on 7' pallets).
/ Pallet forks #9
Depends what you are using them for. I bought 42" and they are perfect for moving IBC totes full of wood. longer forks would offer no advantage and might even 'spear' the tote behind the one I am moving.
I found the solution to "not seeing the tips" to be a cheap back up camera. Camera has other uses as well.
/ Pallet forks #10
My research put Express Steel as the best option for 48" 4k forks. <$800
I also have a set of these. I believe I paid $750 shipped with lift gate. There american made too.
/ Pallet forks #11
I would put a 4x6 piece of wood in back of forks when I absolutely needed 42" forks. That would be on 48" forks. We had a set of 42", hated them things. Bought some 48" and life is better. And yes, I pick up totes too. Pallets. Plywood. Bricks. Lumber.
/ Pallet forks #13
Yup
I use a $20 Wyze cam, a $15 Sony "powerbank" and if not within range of the house WiFi, my Mobely, plus appropriate USB cables and Ziploc bags then watch it on my Android phone. Just did that yesterday to hook up to drag an 18' trailer with my FEL on my M4700. A decent mobile camera can be like the ability to put an eyeball on most anything.
/ Pallet forks #14
You can’t go wrong with express steel. Mine are built like a tank and very affordable I got the 48 inch 4000 pound
for less than $800 shipped
/ Pallet forks #15
I like the express steel stuff. But wish they had a trailer hitch receiver tube on them. Need something to move GN trailers around.
/ Pallet forks #17
Titan has the receiver tube, plus mounts for hay spears - Palletforks.com. 48” and 4000# model is currently on sale for $705 with free shipping. It is back ordered for a couple more days.
/ Pallet forks #18
Only if you like imported Chinese junk. Pass
2022 EZ-GO ELITE...
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
2002 Massey Ferguson 1233 Tractor (A66285)
2002 Massey...
2007 International School Bus (A64194)
2007 International...
Smalline 4in. Double Diaphragm S/A Towable Trash Pump (A64553)
Smalline 4in...
Covered Livestock Mineral Feeder (A66408)
Covered Livestock...
