Advice needed regarding Grapple
/ Advice needed regarding Grapple #1
Hwelbergen
New Holland Workmaster 70
I am in the market for a grapple . Not wider than 55 inch but preferably 48 inch . The narrower grapples are normally rated for lower HP tractors . My tractor is 70 HP . I do not have the space between rows to work with a wide grapple rated for 70 HP . I am looking for a strong rugged grapple to remove small Christmas tree stumps and cleaning up the land . Any advice?
/ Advice needed regarding Grapple #2
If I was buying a new one it would probably be like the frostbite. I’ve got a 54” EA, even on my big tractor it feels heavy and I very rarely use the full capacity.
/ Advice needed regarding Grapple #3
Dig, pull, shake, back drag to fill hole and done.
/ Advice needed regarding Grapple #4
You could check with these guys...
/ Advice needed regarding Grapple #7
I have one made by favor. It’s a heavy duty quality grapple that’s more than sufficient for a 70 hp tractor. Mine is 60” wide and they also make a 48” wide.
/ Advice needed regarding Grapple #8
I was considering that as well. Who makes that one?
It’s a Danuser puller. It’s a mean tool. I used to have one in a deal that didn’t workout. If I didn’t have a mini x now I’d probably buy another one. It’s not the best for a typical grapple function though. It can pick up and carry stumps or a log but it’s not the best for carrying brush. I have a stump bucket now that came in a package deal. It’s not as good as the Danuser but for a retail price of 1/4 what the Danuser is it’s a pretty useful tool.
/ Advice needed regarding Grapple #9
Check out Homestead Implements grapples. They are almost identical to the EA grapples, but slightly less expensive and free shipping. Their 55" is the smallest size they offer for tractors from 25 HP to 55 HP. They have two versions. The Pinnacle line is their deluxe version and then they have a less expensive Independence line. They also give a 10% discount for veterans. They are US Made and Veteran owned. Grapples - Homestead Implements
/ Advice needed regarding Grapple #10
The Intimdator excels at stump and tree removal. Reaching up and tearing off head slapping limbs. Has been great for pulling out saplings and brush in tight areas with minimal ground disturbance. The smallest whippersnappers can’t hide. Clearing around fences, buildings, ditches where I can’t mow. Can pull and stack 10-20 small trees, grab pile and carry long ways down woods roads to dispose. Carrying or dragging longer and bigger stuff down narrow paths saves from cutting into sections.
Have long bottom root grapples too. 54” EA grapple is perfect for the B26. Would have to be very careful if used on M59. Have 72” skidsteer rated grapple for it. Your 70hp tractor is at least 6’ wide? Definitely understand wanting narrow for woods work. For our wooded hillside farm the grapples are in constant use. Springtime tree pulling season is now.
/ Advice needed regarding Grapple #11
If you have limited lift capacity a short bottom tined grapple similar to the link below will be easier on your loader. Narrower is a good idea too.
The negative to this style of grapple is limited grab capacity. I have one similar to this and wish I bought this style instead. Much harder on your machine but better for handling brush and hauling cut logs
Depending on your volume of roots you might want to consider renting a CTL with grapple to make the job go faster and reduce wear and tear on your machine. Stumps are harder to push out than tree with stumps.
A mini-x rental works too but then you still have to move the roots with your CUT.
/ Advice needed regarding Grapple #12
[FONT=arial]Hwelbergen[/FONT], I think you would want your grapple at least as wide as your loader frame. Yes No. The Faver GX looks like it does not have any protection for the lid hydraulic cylinders. I added support to my lid protection plates/ hydraulic cylinder protectors/ because they used such thin material over a wide span.
/ Advice needed regarding Grapple #13
I had the Land Pride SGC1560 grapple and WR Long 3rd function valving installed on my Kubota M6040 ten years ago. The 1560 is the narrowest ( 60" ) in the SGC series. It's an extreme duty grapple and has served well. I find it so handy - never even once have I taken it off my tractor. A Land Pride grapple would be a good choice for you.
I use mine specifically to move large rocks and heavy chunks of pine tree trunk.
While you are at it - don't forget to modify the grill guard on your tractor. Limbs, stobs & roots have a nasty way of finding your grill, radiator or battery.
/ Advice needed regarding Grapple #14
With a 70hp machine I would be looking more towards a skid steer attachment. How ever alot of these thinner grapples are built for 20hp machines and cost alot due to the weight and steel type.
/ Advice needed regarding Grapple #15
The Land Pride SGC series is designated as a heavy duty skid steer implement. Constructed of 800# of AR400 steel. I very seldom lift a load more than 6" off the ground - knuckle dragging. So.. at lower lift heights it has substantial capacity. If you are concerned about lift capacities - check out the load lift charts in the Owners Manuals before you purchase a unit.
/ Advice needed regarding Grapple #16
I have a wicked root grapple. Looks like this one with long teeth which might suit what you are trying to do.
It has held up really well. Not abused but definitely very well used. I like the longer tines to scrap below grade raking up roots, etc... then a curl shake and most of the dirt simply falls through the bottom tines. I wouldn't use it to dig up "stumps" though as torque on loader arms could do damage pretty quick I think. A straight push with middle of grapple into christmas tree trunks should not be a problem.
1/2 the bottom tines are removable which might suit your plans of rooting up small stumps but wanting to leave behind as much dirt and small stuff as possible.
My biggest surprise is how well the black paint shows only minor wear? not sure what these guys use but definitely not tremclad (haha)
/ Advice needed regarding Grapple #17
This may be the heaviest narrow grapple made, but your tractor will not damage it: Demolition Grapples - Features - Sidney Attachments
Mine weighs 946 pounds:
6 tines, 44 inches wide:
Here it is pulling a long dead 10 inch diameter cedar stump:
/ Advice needed regarding Grapple #18
I have the same unit and it's held up well for me too.
My Branson's loader has slightly higher lift capacity and breakout force than the OP's Workmaster (as listed on tractordata anyhow). I do not think the grapple would do well to dig christmas tree stumps out. It takes a lot of force to pull a stump out of the ground, even in my land's loose sandy soil. While this grapple works well for logs and for brush it's not all that good at digging. It's wide so you'd need to force all the tines into the ground. It seems like a narrower implement would do better.
/ Advice needed regarding Grapple #19
Same here.... I use my backhoe for almost all stumps. I am in very sandy soil area
But if I bull doz say a 4 - 5" (especially if a little rotted) I can push it out of the ground. For sure I can not pull up (pluck) them straight up either. Pushing/bull dozing works when I am too lazy and just make a quick push.
I wonder if Christmas tree farm stumps would be too fresh to do this though.
What I have done in the last year is picking them up with the subsoiler and pushing with a bucket . I had a tc 30 ath the time . Maybe if I break them loose and then pick them up with the grapple it would work. This tractor has twice the power
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
2019 CATERPILLAR M316F MOBILE EXCAVATOR (A63276)
2019 CATERPILLAR...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
Ledwell Hydratail 48Ft Trailer (A64194)
Ledwell Hydratail...
