To the basement, or to the scrapyard? My attempt to resurrect a Tarm Excel 2200 Wood Gasification boiler
/ To the basement, or to the scrapyard? My attempt to resurrect a Tarm Excel 2200 Wood Gasification boiler #1
aczlan
Good Morning
Northern Fingerlakes region of NY, USA
Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
I picked up a Tarm Excel 2200 Gasification Wood Boiler this week, from the tag it appears to have been made in 2001:
It is a Wood/Oil (or Wood Propane) boiler, on the wood side it heats the wood till it smoulders, then burns the gas/smoke at around 2000F below the firebox:
Picture from: Tarm Furnace | Excel 2000/2200 | Wood and Coal Furnace Parts
A demonstration video of the next size down (the Excel 2000):
The previous owner was using it and it sprung a pinhole leak in the back of the firebox, they ran it (with the pinhole) for about a month on oil until they could get someone in to replace it (they put in a wall mount condensing gas boiler to replace it).
Not sure how often it got cleaned out as it had a lot of ash buildup/creosote buildup inside, here is a picture shortly after I started:
And where I stopped for the night. Can someone confirm that the corners (circled in red) should be square? It looks like they should be, but I don't want to break something if they are supposed to be angled. It appears that there is a bunch of creosote or ash built up there which is a solid lump:
IIRC, the leak is somewhere around where the yellow circle is, if not its a few inches below that:
I pulled out about 10 gallons of ashes out and that was just the easy to get stuff:
The flame tunnel from somewhere in the clean out process:
And how I left it for the night, 200w fan heater in there to warm things up and hopefully dry things out (sitting on a metal plate to keep it dry), not sure if the refractory absorbed any water (or if it can), but I figure that if everything is dry, it will be easier to work with than if its wet:
The plan is to get it cleaned out, then tape my needle scaler to a stick and pound the back wall until its clean.
Once its clean, I will look for pitting, pressurize the "tank" and spray soapy water on the back wall to see if there are any other leaks.
If there are not, it will get welded up and installed in the basement this spring/summer.
If there are, it will get sent to the scrapyard.
Aaron Z
Made a little progress the next night, adapted my needle scaler to get the back wall (while keeping my face out of the firebox and thus breathing clean air):
After doing a test patch:
Where I ran out of time and stopped:
The nastyness on the scaler from what was still damp:
Liking what I see so far of the top 2/3 of the back wall, the creosote just about fell off when I took the scaler to it.
Lower 1/3 (where the hot wet ash has sat against the steel for the past month) is more like what I was expecting to find.
Aaron Z
A few pictures from Friday night:
Air hammer with a chisel blade made short work of the clumps of creosote at the bottom of the walls, they looked like lumps of coal:
Some chunks in a pan, 1/2" diameter pin for scale:
Cleaned out firebox (for now, will probably clean more once it's all dry):
Dug a lot of sludge out from under the vertical tubes in the back, no pictures, but there was ash almost to the bottoms of the tubes.
One more night with the heater in the firebox and then it gets moved below to try to dry out the lower section.
Next up is to shorten the wooden "handle" on the needle scaler so it fits completly inside the firebox and I can get at the lower section straight on instead of at an angle.
Aaron Z
Someone on Hearth asked about using a angle grinder vs a needle scaler.
I thought about using an angle grinder with a wire wheel, but controlling it that far out when it "grabs" would be difficult and it would throw a lot of dust around.
The scaler and air hammer throw little or no dust that makes it out of the firebox and are easier to control.
Aaron Z
/ To the basement, or to the scrapyard? My attempt to resurrect a Tarm Excel 2200 Wood Gasification boiler #5
Hope you can save her. They are good boilers. Going to be able to reach it with the welder ?
Nothing much happening today, replaced some seals in my pallet jack so I can move this beast around the shop easier than with my forklift (its at the edge of what I should be picking up from the end with my little walk behind forklift due to how long it is).
The pallet jack seals were bad enough that I could not pump the handle fast enough to lift the boiler up when I was trying to bring it home.
Aaron Z
I have a stick welder and its straight in, so I should be able to.
Aaron Z
/ To the basement, or to the scrapyard? My attempt to resurrect a Tarm Excel 2200 Wood Gasification boiler #8
Keeping my fingers crossed!
/ To the basement, or to the scrapyard? My attempt to resurrect a Tarm Excel 2200 Wood Gasification boiler #9
I've always wanted an HS Tarm and never bought one, they are the Cadillac of gasification units. If I were you, one, I'd go to HF and buy one of their needle scalers, I have one, works very well and two, I'd MIG weld it, not stick weld it. Much easier, will give a much cleaner weld too. I'm on the Firewood Hoarders Club. Everyone on there burns wood including me. If you decide to scrap it shoot me a PM and I'll come and get it and pay you for it.
/ To the basement, or to the scrapyard? My attempt to resurrect a Tarm Excel 2200 Wood Gasification boiler #10
I might add, the bottom corners of the firebox are small radius. That is built up had creosote from pizz poor care.
I have heard of them as well, I knew exactly what I was looking at when I went over there.
Dad bought the Alternative Heating Systems Woodgun (same concept, different execution) many years ago and my brother is working on putting it to use now.
That is what I have:
Good point, may take it up to work and have one on the guys mig weld it.
My MIG is 120v only and I wouldn't trust it for this.
Will do.
Aaron Z
I found that with careful application of the air hammer/chisel and the needle scaler.
Pretty sure the entire area under the firebox was full of ash, the area under the heat tubes was full to the bottom of the tubes.
Aaron Z
/ To the basement, or to the scrapyard? My attempt to resurrect a Tarm Excel 2200 Wood Gasification boiler #13
That poor thing was rode hard and put away wet for sure. Very interesting unit and looks very well built. I can't imagine the noise using a needle scaler inside the burner, you're head must be still ringing even with muffs.
As for repairs, I agree with what was said, get it good and clean and use a mig, looks good and solid under the buildup
/ To the basement, or to the scrapyard? My attempt to resurrect a Tarm Excel 2200 Wood Gasification boiler #14
well that's a dirty job
My ears are fine, that is why I put the stick on the needle scaler. My head was outside the firebox and the noise level wasn't bad.
Had to reach in with the air hammer, but that was just 2-3 second bursts to knock the creosote chunks off.
It is much better than I was expecting it to be.
Aaron Z
/ To the basement, or to the scrapyard? My attempt to resurrect a Tarm Excel 2200 Wood Gasification boiler #16
People amaze me, not only with tractors but with everything expensive. The Tarm isn't aa cheap date, just like a tractor but people don't take care of either / or. Our biomass units get cleaned every week and what I call a 'deep clean' monthly. I'd never let any unit degrade to that point. Scratching my head over that.
He called Tarm about a replacement and a replacement system (with hot water storage which this doesn't have, but without oil backup) is pushing $40,000 these days.
Aaron Z
/ To the basement, or to the scrapyard? My attempt to resurrect a Tarm Excel 2200 Wood Gasification boiler #18
HW storage is a simple as plumbing it to your existing HWH or employing a static capture vessel.
Like I said in the previous post, I scratch my head in wonderment about people who buy expensive tractors and let them go to pot or buy cheap filters and bargain oil. I never do that. My Kubota's both get genuine Kubota filters and top tier fluids, always.
Penny wise, pound foolish will get you in the end, every time.
The firebox on your Tarm is disgusting btw.
Yep, they recommend at least 800 gallons for this boiler, I think I will end up getting some industrial surplus air tanks, or "hotdog" type propane tanks for storage, then foaming them once they are in place
Like I said in the previous post, I scratch my head in wonderment about people who buy expensive tractors and let them go to pot or buy cheap filters and bargain oil. I never do that. My Kubota's both get genuine Kubota filters and top tier fluids, always.Penny wise, pound foolish will get you in the end, every time.
Yep
Yes it is, now that the pallet jack is working and we have some warmer days coming up I think I will take a hose to the lower chamber to wash out all of the sludge, should be faster than trying to scrape it out.
Aaron Z
/ To the basement, or to the scrapyard? My attempt to resurrect a Tarm Excel 2200 Wood Gasification boiler #20
Good idea but I'd use a pressure washer with a narrow tip and do it when it's warm outside so it dries out quickly.
Started a thread on Firewood Hoarders under 'Gasifcation Boilers'. Lots of member have them on that site. Good folks too.
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
2017 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2017 DRAGON 150...
203201 (A60429)
203201 (A60429)
