Buying Advice on Hydraulic links
/ Buying Advice on Hydraulic links #61
I just hooked up my blower and FEL SSQA blade today on my Branson 8050 with 3 rear remotes and I ran out of remotes.
I have one on the hydraulic top link,
the second one goes to the chute rotator,
the third one is going up to run the angle on the front blade.
Leaving the chute deflector not hooked up.
So I needed a forth one.
If I have to buy a snowblower, I think we have bigger problems than too few remotes.
/ Buying Advice on Hydraulic links #63
OK, my back blade has hydraulic tilt and angle and my toplink, I'd like the offset to be on the hydraulics but not enough remotes
and I haven't gotten hydraulics to my grapple so I'm up to 5.
/ Buying Advice on Hydraulic links #64
Whenever I need a 4th rear remote, I use this rig to tap the 3rd function valve:
I added a 4th break away coupler housing to the stack and ran temporary hoses forward to the 3rd function valve couplers. Yeah, it's a jury rig but I don't need it that often.
I had most of the parts laying around and the ones I bought were much cheaper than trying to use an electric diverter valve.
/ Buying Advice on Hydraulic links #65
View attachment 786765 View attachment 786762 View attachment 786763 View attachment 786764
That's some good creative out-side the box thinking! You're right, often the need for 4 remotes is seldom so what you came up with fits the plan just fine! Thanks for sharing.
/ Buying Advice on Hydraulic links #66
Any ideas why my HYD top link chatters when extended? If I go slow, it’s ok, if I don’t feather it, it chatters like crazy. 💁
/ Buying Advice on Hydraulic links #68
I had the same issue… I was told it’s because the weight of the BB was pulling hydraulic fluid through the top link faster than the hydraulic system could deliver it… causing cavitation (or something to that effect)…
Lower your implement to the ground and work your top link… if i operates smoothly this way you have the same issue I had…
The solution I was directed to was to install a restrictor in the hydraulic return line…
worked for me…
/ Buying Advice on Hydraulic links #69
I suppose these are technically parts, but they attach to the tractor, so apologies if this is poorly placed.
I am about to pull the trigger on a T494H (maybe a 4820H or T574H). I want to get a hydraulic top and side link. My primary use will be box blade work on driveway (200-300 ft) and paths. I have some questions for those who have been down this road before me.
1) Have dealer install it or aftermarket?
2) Options/features to look for?
3) Min-Max lengths?
4) Manufacturers with good reputation?
Installation seems pretty straightforward, but somethings are better in experts' hands.
Most kits come complete with what you need to install the 3rd function yourself but there are times they don't and that's when a dealer is needed. I live in Belchertown, MA and when modifying my tractors order the parts through Devon Lane Farm Supply Inc. and take thier advice on installing myself or having them do it. Only once needed them great people hopefully you have a good place to order from and talk with
Thanks. The 3rd function (for FEL/grapple) is definitely going to be installed at dealer prior to delivery. The TYM comes partially plumbed for 3rd function. $1100 installed and the parts are most of that.
This question is more about the replacing the top and side link on the 3pt hitch with hydraulic ones. The "3rd" rear remote valve is an option (the other 2 are standard equipment). At present, I am leaning toward just going with 2. For my purposes, I am not seeing a use for a 3rd remote. If I change my mind, I'll have to install it myself.
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A60736)
2014 MAGNUM...
1660 (A59213)
1660 (A59213)
2017 FORD EXPLORER (A59823)
2017 FORD EXPLORER...
1985 Ford Ltl9000 Tender Truck (A61307)
1985 Ford Ltl9000...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
