mx842
- Joined
- Feb 26, 2011
- Messages
- 878
- Location
- Richmond Va
- Tractor
- Kubota L3301, PowerKing 2414, John Deere 316, Gravely ZT HD 52
I'll agree when you start porting and working on squish clearance and velocity it's time to jump up to VP 110 at least and with tighter squish clearance you'll need to bump it up more. VP has changed the numbers on their fuel since we stopped MX racing but I think we ran what is now x85L. that was $75.00 for a 5 gal can now it's well over $100 probably closer to $125.00.I use the Stihl oil, and run 100 Sunoco leaded race fuel. Since I only burn less than 10 gallons in the 2 stroke stuff it’s good life insurance for the saws. What got me started on it is an MS440 that I ported and runs about 200 psi compression. Turned out to be a great wood cutter and I started using the 110 in the rest of the 2 strokes and they are really happy with it. I mean if you are going to go out of your way + spend extra $$ why not?
All of my saws were older like the 051, 044, 031 and they all ran just fine on pump gas. I had the 051 for 20 years or more and the 044 was flirting with 30 and boy how much wood they both cut. Some days on a log pile I would go through 5 gal or more. All they ever ate was pump gas and Stihl oil. I still had the 044 and the 031 and both were running good until they got burned up in the shop fire I had. I found out, now this is what I have seen in the shop that the oil used was more of an issue that the gas itself. The main reason for jobs being in my shop were fuel related. I got to the point that I started asking where they were buying their fuel and what oil they were using. When asked, the ones that said they get it anywhere they can find at the time and that they used penns oil,wally world oil or some other brand were the ones that 90% of the time had problems. Penns oil says right on the can that it is good for boat motors, moto cycles,chain saws or about anything you wanted to put it in. That's bunk because oils formulated for air cooled engines is completely different than oils that are made for water cooled engines. This is what I have found in my own little world over the years.
I do see what some are saying about the ethonol fuel it did play havic with the older 2 stroke boat engines before they found out how to make the rubber parts that that were in them.
That's what botheres me about going out to replace my saws now because of the way they are making them now. I have to do that soon because I have a lot of wood to cut before summer gets here.
