Del Morino Funny Super Adjustment
/ Del Morino Funny Super Adjustment #1
Gr8Pyrs
Kioti CK3510SE
Can someone assist me in getting my Del Morino adjusted for cutting height.
Per the specs it is adjustable from 1" to 3".
I want to be around 2" to 2-1/2" if possible.
I have the back roller at the lowest point, with the gearbox leveled with the top link the flails are 1” off the ground. I’m doing this on a level paved area.
If I adjust the top link out to gain height, I’ve gone up to a 2” clearance, I lose lift height and functionality of the rotation. It doesn’t work.
The owner’s manual has nothing but raise or lower the roller.
Any thoughts out there.
When adjusted as below, no lift or at least not high enough for the vertical lift function to clear the ground.
TIA
/ Del Morino Funny Super Adjustment #2
TIA
About your beautiful Italian made orchard and Vineyard Shredder;
you need to have your dealer increase the relief pressure on the
three point hitch hoist circuit of your mule if it is unable to lift the mower.
If the rear roller is at its lowest mounting point that is the highest
cutting height and you will have difficulty obtaining a good cut as
there is less of a pressure gradient to create the suction needed for
the knives/hammers to cut and lift the material.
You have 3 height settings on your flail shredder indicated by the
3 holes in the side weldments of your flail shredder.
The bolt in front of the rear roller holds the rear roller in place and
If my memory is right you just loosen it a little to allow the rear roller
to be raised and lowered to adjust the cutting height of your flail shredder
You remove both bolts on the adjustment holes and reset the bolt,
nut and washer in the desired hole and tighten them back up.
/ Del Morino Funny Super Adjustment #3
The Messicks web site has a rather long video on the Del Morino. It looks like the fellow has the unit sitting down tight on the ground. He did say that if you lift the unit with the 3-point arms - it will not cut. And he gives a demo of this.
I would get back with the dealer and ask how you get the one to three inch variable cutting height. There must be a way that the back roller can be dropped further than you are getting now.
/ Del Morino Funny Super Adjustment #4
Does it have knives or hammers? What are you attempting to cut with it? You may have to adjust your lift arms so that you can get more lift height to make what you are trying doable.
/ Del Morino Funny Super Adjustment #5
I have a 10' Maschio. I have my slides on the ends adjusted for my cut height coupled with the roller position. But mine is made for grass and brush cutting and is not a ditchbank cutter like yours. I think I cut to 1.5".
It does lift no problem. And I have the roller at the lowest point.
I'm working with the dealer and he is trying to find answers but in honesty he is new with this unit as well.
The specs were the confusing part saying 1" to 3". I'm shooting for 2" in my application of use. Native grassland and open field maintainace.
The owners manual is "limited"
/ Del Morino Funny Super Adjustment #7
You missed my point or maybe I misunderstood you. I believe you said it doesn't lift high enough to work properly when you get the height set where you want it. If that's the case, I was saying you may need to adjust the lift arms so it will lift "higher".
I may be doing things wrong on my end as well. If I have the unit on the ground and adjust the top link to raise the front end so the blades are slightly higher. They're then is not enough travel to lift the unit off the ground high enough. The lower arms are not the issue but when extending the top link it won't go up as high. I only have one hole to place the top link on the tractor not multiple or some units have.
/ Del Morino Funny Super Adjustment #9
As usual they do not understand these mowers and how they work.
You need to decide what height of the three positions you want and need to mow at.
The highest bolt hole setting of the three will give you the best closest cut.
The middle hole will make the cut one inch lower and the bottom bolt hole
the highest cut height.
If your lower links are fully retracted which they appear to be they need to be extended one or two holes
at a time along with your top link to find the right place for it to work and maintain a level flail mower to lift
the shredder to allow the rotation cylinder to rotate the mower to vertical or allow it to drop below the
horizontal plane to mow a downward sloped bank.
These boom mounted shredders are designed to work with the three point hitch fully elevated with the boom fully extended
to the right to mow hedges, vineyards berry cane hedges and mow weed trees back along a lane or road.
I have to finish my chores but I will come back to this.
I think I'm better understanding your comment on the lift arms after thinking it thru.
Thanks I'll take all the help I can get.
/ Del Morino Funny Super Adjustment #12
I wonder........ is the 3" cutting height when you use hammers rather than the knives. Are the hammers shorter than the knives.
/ Del Morino Funny Super Adjustment #13
Who is "they"? Second question, does this tractor have adjustable bottom 3PH links? That's not common. At least for a JD. For mine there are only a few adjustments. Roller position, top link adjustment (I have a hydraulic toplink), 3PH height and mine has adjustable skids on the sides. I use the float position on the toplink and put my 3PH lift arms in float position. If everything gets setup and the way you want it but it doesn't lift high enough you may have to adjust the lift arm height so it lifts higher. That doesn't change range of travel just the lift height. Leon is correct in that the cutters like you have aren't so much for mowing flat fields but for hedge and ditchbank mowing. I've never adjusted one of those because I have a rotary ditchbank cutter. My flail is a 10' slide model.
/ Del Morino Funny Super Adjustment #14
oosik, I'm guessing he has hammers. I would think they would put hammers on a ditchbank mower. I have no idea if they are shorter. I've never seen the knives for mine.
/ Del Morino Funny Super Adjustment #15
Just ask the seller to produce a customized rear roller bracket, you can get any cutting height you want, just cut down some plates and weld them together, easy work.
By the way, I see there isn't safety valve on your mower tilting cylinder, consider Del Morino is an Italy brand, this is againt Europe safety standard and sell it in the US market, funny.
It has hammers but per the manufacture specs on capabilities Y's or hammers are the same. The three point arms are telescopic.
/ Del Morino Funny Super Adjustment #17
So extend the 3PH arms if they are designed to do that. I thought those telescopic arms were just for hooking up an implement. That's how mine were on my 5310 and on this 5090 I have. But I can't run them extended.
I'm not sure yet if they have multiple positions or as yours did, just for hooking up. New machine and the flail was hooked up when delivered. Will be looking into it.
/ Del Morino Funny Super Adjustment #19
I have an older Kioti and the extendable 3PH arms are only for hooking up, they don't lock extended. When people say adjust 3PH arms they are likely referring to to adjustments where the lift links attach to the arms. The owner's manual doesn't appear to explain this, but I've attached a picture of what to look for. You can adjust the connection between the vertical link, circled in blue, and the 3PH arm circled in red. Depending on which holes you use it adjusts how high the arm raises. In the picture I attached there are holes in the vertical arm and the 3PH arm. If you post a picture of the back of your tractor we can help show you which holes to use. I have a more basic del Morino and agree the rear roller doesn't allow a high enough cut on its own, I have to extend my top link a lot, but it works fine that way.
I'm not sure I have the same options. There are only two hole positions and the lift arms are currently in the one closest to the tractor.
I'm not sure of the clearance with the telescopic activation handle if in the front position hole.
****Power to dash w/jump pack. Does NOT start**** Year: 2012 Make: Ford Model: Transit Connect (A66738)
****Power to dash...
9008SFL (A64556)
9008SFL (A64556)
2014 Ford Escape SUV (A66738)
2014 Ford Escape...
2020 CATEPILLAR 289D3 SKID STEER (A65056)
2020 CATEPILLAR...
2013 JLG 8042 TELEHANDLER (A67714)
2013 JLG 8042...
2025 44in Single Cylinder Grapple Rock Bucket Skid Steer Attachment (A66734)
2025 44in Single...
