Tools & equipment that are fantastic.
/ Tools & equipment that are fantastic. #221
Curious if any one owns one of these, I can see it being useful, being cordless and somewhat powerful at 90k btu. If I owned one I probably would have used it a quite a bit already. But I already own two 120v corded salamanders. If your somewhat handy you can pick used 120v ones up for next to nothing at a summer garage sale. Don't own the DeWalt one maybe next Christmas lol.
I have a propane one. Its convenient not having to drag a cord out especially on a new construction where it might take 150 ft of cord to reach the temporary pole. The battery last for a long time.
/ Tools & equipment that are fantastic. #222
A business next door years ago had a similar one, a large open garage and they ran it one cold night. Next morning my shop cat was dead from carbon monoxide poisoning.
I suspect there's more to this story. I own one of these, and although I've never run one all night, I've used it many years in garages and barns of all type, with never a problem. Yes, they emit CO and water vapor, but if properly maintained and run on the proper fuel (kero, not diesel or no.2), the levels don't climb to any point they should be killing a cat in a well-ventilated building.
Maybe they had a fouled air filter, bad injector, something else also running in the building for additive effect? Too many people ignore recommended maintenance on their equipment, and then blame the equipment design when things go wrong, rather than acknowledging the real problem.
Having said all of that, they're not exactly "health food", either. Those sensitive to CO can get a mild headache if you operate these in a building with poor ventilation.
/ Tools & equipment that are fantastic. #223
Depending on temp outside I run my 135k btu for 5-15mins to take chill out of air in shop, I dont keep shop heated, a "7.5 k btu" forced air electric shop heater then keeps shop tolerable. Obviously not advisable and feel Im pretty aware of health effects but have run low sulfur off road diesel in it for years. Also use a window mounted repurposed high CFM exhaust fan when I weld in shop. Still think a portable hybrid heater like I posted would be invaluable and I'd probably use a lot.
"Correction, it's a 7500 watt 25k wall hung btu electric shop heater"
/ Tools & equipment that are fantastic. #224
Final thought on diesel/ kerosene torpedo heaters to be safer and need it to run extended periods in confined space probably should use or buy one with a exchanger/ vent kit Imo.
Unfortunately cat probably passed away from something not related to that heater.
Rest of the story: I called fire department who showed up within minutes. Their equipment showed carbon monoxide level was "off the charts" (fire Marshall). Vet autopsy proved cause of death, 8 yo healthy cat found dead at the door.
Again, I'm sure those heaters are fine, propane would be best...but whatever one I would use a CO detector.
/ Tools & equipment that are fantastic. #227
I guess this legally falls under the "fantastic tools", but I installed a minisplit HVAC system in my current shop, and it's the best money I've ever spent. If it's nice outside, I'm usually working on stuff outdoors. But now my shop is heated and air-conditioned, as a wonderful workspace whenever the weather is too miserable to be outside. I actually appreciate the cooling in summer far more than the heating in winter, as I don't mind working outside in the January cold, as much as the July heat.
Related to the above, now my Reddy jet heater is only used to occasionally bring the shed up to temperature to start the zero turn mid-winter (cold hydro pump), or to point at me when working outside on exceptionally cold days.
/ Tools & equipment that are fantastic. #228
My father used kerosene heaters for backup heat in the greenhouse. He also had one to keep his uninsulated shop from freezing, until the price of oil went up back in the '70s.
He gave me his smallest heater, a little Knipco which was great for warming my tractor, or heating the air around it when temps were 0'F and I needed to work on something. Eventually it stopped working and although I took it apart and got it to work again- by leaving a spring out of the motor- I never used it again. It's been down in the shed for 10 years or more, this spring I will probably toss it.
That cordless unit looks like the cat's meow.
/ Tools & equipment that are fantastic. #231
This is the blade for my brush saw. It’s the biggest one which Echo makes. It sharpens with a chain saw file.8BFA21FD-35B3-4A2B-8F6E-31936940A4AC.jpeg
Right now it has the weed whacker head with the nylon fingers.
/ Tools & equipment that are fantastic. #233
This is the blade for my brush saw. It’s the biggest one which Echo makes. It sharpens with a chain saw file.View attachment 783364
Looks like mine for my Husqvarna. Makes easy work of Aspen shoots encroaching my Xmas trees.
/ Tools & equipment that are fantastic. #234
I wish I had a Husky, but the one I want is close to $1400. I would have a hard time justifying that.
/ Tools & equipment that are fantastic. #235
Gee, you must have less rocks and gravel than us! :ROFLMAO:
Mine lasted quite awhile in sandy soil down state, took it up north by your neck of the woods and not so much.
/ Tools & equipment that are fantastic. #236
I love my Dewalt grease gun. Saves a ton of effort and time to grease up my little Massey GC1723.
/ Tools & equipment that are fantastic. #237
It's one of the smallest and inexpensive handlebar models at the time that could handle a blade. I run a 24 tooth husky Scarlett blade with pretty good results and durability until I take it up north lol[
/ Tools & equipment that are fantastic. #239
These little pump oil cans are great for adding transaxle/ gear oil etc, during changes and checks, minimal mess anymore (after I mastered refilling little cans) and controls output well in hard to reach spots. Easy to add hose extension if needed to.
/ Tools & equipment that are fantastic. #240
We got gassed once using one of those in a cold storage unit for apples. I was never sure if it was the kerosene bullet heater or the propane forklift, but there were two of us working and we both were out sick for the next day.
To this day I can't stand the smell of propane.
I hear ya on the propane forklifts. Don't know how anyone can work around one of them. 5 min. and I'm nauseous.
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A60352)
2019 Allmand...
2004 JOHN DEERE 624J WHEEL LOADER (A62129)
2004 JOHN DEERE...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
KUBOTA SVL97-2 SKID STEER (A62129)
KUBOTA SVL97-2...
2007 International 4300 Altec DM47 TR 47ft Insulated Digger Derrick Truck (A60352)
2007 International...
2014 RAM 2500 (INOPERABLE) (A58214)
2014 RAM 2500...
