Cost of deep wells ???
/ Cost of deep wells ??? #1
westcliffe01
SE MI
Kubota M4500DT, B200 backhoe
My wife was looking at a piece of land in CO. So I sent the nearest well driller an email asking about wells in the area and the response was one should bargain on 600-850 ft and an all up cost from $70-100k. Drilling and casing $80/foot. Anyone's first thoughts on that news ???
Back in 2012 I met with a well driller in a different county where pretty much all drilling is through hard rock in the mountains and the estimate was for 500ft at a price of about $26k. Something has become a lot more expensive in 10 years and it was not gas, thats for sure...
/ Cost of deep wells ??? #2
It differs greatly from place to place, even within the same city. It seems the drillers know what areas are more difficult. Around here 650 feet is $7-10k probably 30% more now
/ Cost of deep wells ??? #4
So glad we are blessed with mountain spring water and gravity...
Water is about 58* and regularly tests better than the neighbors drilled well...have to use a pressure regulator to lower the pressure...!
Drilled wells here (lower Appalachia) with lots of granite is about $15/foot...depth really depends on where (elev. wise) on a mountain the home site is...
/ Cost of deep wells ??? #5
Not far off the prices here for a well that deep. One nearby was 700', for around $100k.
It is very very site dependent, and especially geology and hydrologically dependent. E.g. gabbro vs sand, accessible aquifer vs rock fractures for water. No guarantees.
All the best,
Peter
more than 90% of lots are undeveloped. Very few lots where the buyer has invested in a well prior to building.
Thats $14.28 a foot... Vs $80 a foot ?
/ Cost of deep wells ??? #9
Our last well was drilled at 500' and it cost us $25K. That was 10 years ago....
The prices can really vary though, we had prices / bids as high as $50K.
/ Cost of deep wells ??? #10
The worst part is they really don't know how far down they will go before hitting water, so the only way that they can even give a ballpark price is based on depth of nearby wells. In this state all wells are entered into a database so that you can get that information. I'm not sure if that's the case where you are.
/ Cost of deep wells ??? #11
I was watching some woman's Yt vids (Spirit Forest) on a house she was having built in the mountains of CO. She mentioned a monthly fee after the well was drilled due to water rights.
/ Cost of deep wells ??? #12
I had a quote of $34 a foot in 2019. Didn't get drilled until 2022 at $55 a foot.
/ Cost of deep wells ??? #13
There is a lot that you can do to determine and budget for a well. If you need help let me know. All well info is public and online in CO.
/ Cost of deep wells ??? #14
20 some yrs ago we bought a property with a well. It went dry 6 months after we moved in. The Driller said $25 a foot plus casing, wire, & pump. We ended up going 500 ft. Casing every bit of it and putting in a new electric panel, 4200 gal holding tanks, 2 bladder tanks and related pumps. It was 30k when the dust settled and we ended up with a second mortgage on the place.
/ Cost of deep wells ??? #15
Initial well costs are one thing but consider the future. If you drill the first well in a subdivision, it may have to be deepened if the water table drops when subsequent wells are drilled.
My neighbors well was initially 300'. When I drilled my 500' well 6 months later, his went dry and he had to drill another 200'.
There are a lot of variables involved but certainly something to consider when pricing a well.
/ Cost of deep wells ??? #16
Yes, there a lot of scary stories of wells being drilled. But in CO it is a daily thing to dig a well. The key is to pick a property that has water. That isn’t too difficult. There are a lot of resources that are available to you to figure out if the area you are in is good or not good for a well. In the past, I mean way past, people put the house in a location where there was probably water. Nowadays people put the house in a location for the “view”. Make sure the lot you buy has those locations in the same spot.
/ Cost of deep wells ??? #17
A friend just drilled a well, he called around, nobody would quote a price per foot. Turnkey well and pump ranged from $10K to $15K. They went 300', 20' of casing and hit 5 gallons a minute and installed a 1/2 hp pump, for $10K. The contract was for up to 500', or 5 gallons per minute, no more than 100' of casing, firm fixed price.
/ Cost of deep wells ??? #18
Our well was drilled next to the house in '76 to a depth of 31 feet and we've been using it for lawn irrigation at about 10 GPM ever since. I don't remember the cost but if it was over a thousand or two we would not have been able to afford it. The driller hit a rock at 31 feet.
/ Cost of deep wells ??? #19
Its different for every state. Ours is 650 feet cost us start to finish around $12,000
/ Cost of deep wells ??? #20
I believe the well drilling cost is directly proportional to cost per acre. :devilish:
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2024 Land Pride PFL3048 48in. Forks and Frame Skid Steer Attachment (A66734)
2024 Land Pride...
1990 FORD LT9000 HOT OIL TANK TRUCK (A67714)
1990 FORD LT9000...
2005 BMW (A68183)
2005 BMW (A68183)
PALLET OF HYD HOSES (A68842)
PALLET OF HYD...
x (A68191)
x (A68191)
