Water Well Advice ? A/C or Solar ?
   / Water Well Advice ? A/C or Solar ? #11
I drive south - down into the wheat country( the Palouse ). Every old farm has, at least, one windmill. Not a one of them still operate. All replaced with electricity when it became available. I wanted one - just as a decoration. Until I found out how very heavy the entire unit was.
   / Water Well Advice ? A/C or Solar ? #12
Sounds like you need a Brumby pump! This simple pump uses air instead of electricity and weighs just a pound or two.
   / Water Well Advice ? A/C or Solar ? #13
How about solar + electric windmill? Should be able to generate power with sunshine, at night, and during inclement weather.
Having a small battery bank would be helpful, but the water tank is, in effect, a battery.
   / Water Well Advice ? A/C or Solar ? #14
The windmill at my grandfathers farm never pumped water in my lifetime. I filled remember him referring to the wooden platform below the blades and saying he used to stand up there and add oil. He never climbed to the top since I was born, either.
My relatives had a big tall windmill, still there. They had a big tank filled by the mill and gravity fed the house. They had running water 30 years before electricity came to this area. Probably 70 feet tall. Metal tower and all.
   / Water Well Advice ? A/C or Solar ? #15
Just use a submerged pump and a generator. PTO or stand alone. Big water tank. Fill a 500 gal tank. Get a bucket for grid down.
   / Water Well Advice ? A/C or Solar ? #16
I have a 6" water well (capped off) that an oil company drilled to fracture a nearby well. Best I recall, the well is about 330' deep with water level about 70'. I am considering using this only for cattle and a backup "prepper type" supply (not connect to the house). I have had a water well source previously, so I know some of the "in's and out's".
POWER: I *could* run A/C power from an existing meter loop to the well, it's about 150' away so ($$) trench, wire, conduit (must have, gophers). There is other power nearby if I added a pole and meter loop. But, I am NOT going this route ! Aside from the cost of this hook-up, the power Co. charges about 20-30/ Month just to have another meter. I already have (2) and this really rubs me wrong to pay almost $30 even if you do not use electricity.
I am considering solar, but do not know what all this entails. Anyone have experience with Solar water production ?
May not get this project off the ground due to costs and "what I want to end up with". For me, its a MUST that there has to be a slab, a building (which I would mount solar panels on) and a storage tank inside. My previous well had a building to protect my control box / softener (don't need now) and protect everything against the weather.
One of my concerns about Solar would be during winters. My last well used A/C, so was able to keep heat in the building at night. But, with solar, I really don't want to include battery storage for this purpose ($$).
Also, I could just take a flashlight to see around inside, but would be nice to have a light.
So, right now, I am in the thought / planning process only for the solar option. Do not want any big regrets. Any advice here ? I should mention also, I looked into the deep well hand pumps.... although would be cheaper... not wanting to go that route.
   / Water Well Advice ? A/C or Solar ? #17
Check out RPS solar. They specialise in off grid cattle ranches replacing windmills. We installed the RPS 400 pump turn key kit which included everything including the poly pipe a year ago. We had to supply the mount pole and ground wire. It has performed flawless and even pumps water on light overcast days. At full sun our well produces 18 gpm. It is upgradable to double the power available by adding 4 more panels.
Patrick
RPS 400 Solar Well Pump Kit
   / Water Well Advice ? A/C or Solar ? #18
I don't quite understand the purpose of the fracking well. Was it just as a source of local water, I.e. not an injection well? Before you get too far into this, you might want to have the water analyzed, both for trace metals, and for organics(hydrocarbons), plus I would highly recommend testing for organic fluorine compounds to make sure nobody put PFAS type chemicals down the well for any reason.
If you want to go the solar route, I would suggest getting a solar submersible well pump like @34Willys. They are designed to operate on variable amounts of sunlight for maximum efficiency. I would buy quality solar panels for durability. If it turns out that you don't get enough sun in the winter time, you can add more panels. If it were me, I would have the well pump feed a storage tank for a week or so of usage, so a week of bad weather wouldn't be an issue. I think that it is much lower maintenance to store water than to store power.
All the best,
Peter
   / Water Well Advice ? A/C or Solar ? #19
Like a few million other properties, mine has a 230VAC well pump. The NorCal power utility, PG&E, has gone down several times a year for as long as two weeks at a time. Have to run a 5.5KW gen (on propane) to get household water pressure. A real Hassle! I have been putting together a whole-house battery back-up solar system, but haven't finished it yet. So far, for about $12K, I will have 4.2KW solar panel array, and two inverters, making 230VAC. That will provide whole house power, including the well. I looked into using a 48VDC Solar well pump. They make solar pump controllers that don't need battery back-up. There are limits to depth and flow rate at a given pressure at the top of the line when filling a tank, or at household pressure. I now have two 24VDC submersibles that are supposed to pump up to about 75 feet of head at a minimal flow rate. Use one in the pond for irrigation on the veggie field, about 5 feet of head height. This install is 2 -235W solar panels and two group 31 AGM batteries, in case there are too many days with cloud cover. I'd say it's adequate for a small veggie field, say 1/8 acre, using drip tape for a time, and sprinklers on different timers to keep the coverage pattern up. I don't think it would adequately irrigate 1/4 acre in high summer heat.
   / Water Well Advice ? A/C or Solar ? #20
150 ft to provide AC power is your least costly route in my opinion.
If U don't wish to bury deep U can always run the AC inside of cheap PVC piping for protection.
207282 (A52708)
207282 (A52708)
2021 Club Car Carryall 500 Electric Utility Cart (A59228)
2021 Club Car...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
Pickup Truck (A59230)
72" ROCK BUCKET (A52706)
72" ROCK BUCKET...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
