looking to buy first tractor with loader and backhoe
/ looking to buy first tractor with loader and backhoe #1
hypforlife32
none
Whats up guys, im looking to buy a loader, backhoe and mower setup. My yard isnt really large at all but about to add a 42x60 pole barn and roughly 350 ton of stone. total property is 1 acre of open land. i am looking to removing a bunch of top soil, and dig a couple ditches, lay stone, move some engines around. pull a coulple trees and having something to plow a 400ft driveway and decent size parking area. my gf for some reaons likes mowing grass so im looking for something that has quick detachable loader. or maybe even bucket. looking around a 13-15k budget. what are your recommdations? thanks open to all brands
looking at possibly a john deere 2320?
loking at a couple year project. also need to build a retaining wall as well. move a car trailer etc.
/ looking to buy first tractor with loader and backhoe #2
I recommend you rent a machine to do the work you list, then buy a zero turn mower and something else to plow with. Moving 350 tons of stone, a "bunch" of topsoil, and "pulling" trees are not work you want to do with a machine that would also be small enough to mow with.
i have a 2008 grizzly 450 now with a plow on it. yeah, thats kind of what i was afraid of. after the whole project is done itll be a 3/4 acre lot. lol
/ looking to buy first tractor with loader and backhoe #4
having to make a lot of assumptions like is your stone a road base type of gravel or boulders / hauled in and dumped in piles or needed to be dug out of ground.... assuming gravel dumped in piles then a B series sized kubota could move your stone in about 1250 buckets and a L series in about 800 buckets. Guess how many minutes it would take you to move a load and you can figure how many hours of work this would be. On an open 1 acre lot if flat etc.... In a B moving 350 tons maybe 4 days work and in an L sized tractor 2 days work but lots of assumptions including operator skill, etc....
Not knowing what type of trees you have... a can dig out stumps of Pine trees about 3-4 stumps an hours with a B sized machine and 5-8 an hour with an L sized using a BH in moderate loose soils.
Not sure what you mean by plowing... do you mean moving snow? both sized machines could do this with a bucket or blower unless your in a place that gets 4' of snow at a time. 400' driveway of moderate to light snow can be bucketd by B or L easily IMHO unless your in the mountains of big snow belt then I would go L here. Personalyy I like a blower regardless.
Both B and L sized units would pull a pto driven rear mount mower which is likely more than you need for an acre but heck that's a personal preference and site decision I guess. I never used a B with a MMM.... likely a zero tun or ride'm mower better option for a single acre but again personal choice.
cheers... its greating having projects and equipment to do it yourself!
I can always buy a smaller mower for her. They can be had pretty cheap to just mow. Right now this tractor would be put in he house garage until the other one is build. im paying somone to do the ground work for the pad and taking the tree down. i am handing removing them etc. yes, i meant snow. which doesnt really happen too often in northern maryland but i hate being unprepared. right now the 400ft long area is just pure grass, need to remove top soil and lay crush and run, dig ditch to burry electric to building from house. install new culvert pipe, extended retaining wall, and make new retaining wall in the back of the property which will be a total of 50-60 ft long if not more. i fell like spending the money to buy one and then sell it in a 2 years when everything is done ? I would be selling my kodiak 450 and switching to one. If it does snow its about 6k sq or more to plow move snow.
/ looking to buy first tractor with loader and backhoe #6
Buy an old full size backhoe at the best price you can locally of CL or FBM.
Do all your work with it.
When finished, sell it for same or more than you bought it.
Then buy tractor you need to maintain your property
/ looking to buy first tractor with loader and backhoe #7
Agreeing with sea2summit. 350 tons of stone is roughly 250-300 cubic yards which is a lot to move with the smallish ( my estimate of 1/4 yard heaped ) bucket. Plowing requires weight. Wet snow is incredibly heavy and a insufficient weight tractor will either fail to push the snow or the machines back end will just pivot when your blade is set at an angle.
Mixing mower work with tractor work does not make sense unless your towing a mower on three point hitch.
You want to be looking at 40 hp machines, which weigh more and have larger bucket volumes and lift capacity. Rent until you determine what meets your needs and budget and then decide if owning is something that makes sense.
like a 1970 case 430? lol
/ looking to buy first tractor with loader and backhoe #9
Up your budget by at least$10k , rent something, hire someone.
/ looking to buy first tractor with loader and backhoe #10
Ignore the advice for 40 plus horsepower. That's going to be extreme overkill on a 3/4 acre lot after the initial work. Instead shop around for a used Kubota BX series subcompact or a similar brand. You probably won't get one with a backhoe for that price, but you're better off hiring or renting a mini-ex for a day or two anyway. I'm not real familiar with all the features of the mid mount mowers, but I'd research the brand(s) available locally on the used market to see how difficult they are to remove or reinstall. Get a 4 or 5 ft box blade to help move spread gravel, as well as maintaining and plowing driveway. Don't let the big tractor guys deceive you. Those subcompact are incredibly handy and capable machines.
This is kinda what I was thinking here. I’m paying someone to do the hefty work already because of the price. I’m looking to be able to dig a couple long trenches. Move, spread and maintain mostly. The retaining wall I can do with the backhoe slowly. Looking to touch things up here and there. Honeslty doesn’t even have to mow. Mowers are so cheap now. I like the b series’s or Deere 2320 style.
/ looking to buy first tractor with loader and backhoe #12
I think you're on the right track with a 2305, or you can also look for a Kubota BX but you will need to up your budget to $20k to get a nice one with backhoe and mower. You  might find something with loader and backhoe for $15k but it won't have that new tractor smell.
A subcompact is sufficient to do all of the stuff you mentioned it will just take a while. Yes it would be better to have a 75hp skid steer for moving all of that stone but a small tractor will get it done. Rental money is better spent added to your tractor budget IMO.
I moved about 60 yards of crushed rock with a skid steer but also had a compact TLB for part of the job and the compact can haul crushed rock without an issue. Just set your machine up with proper ballast and know it's limits.
I have been very impressed with every Kubota BX I've tested.
While mini excavators are leaps and bounds more productive with a backhoe than a SCUT, even a small backhoe will come in handy for so many things if you can find one within your budget.
I would also prefer a $2500 ZTR than using your tractor for mowing an acre.
/ looking to buy first tractor with loader and backhoe #13
Hypforlife32, this is from the Yanmar Tractor
website hope it will be of some help!
willy
/ looking to buy first tractor with loader and backhoe #14
This would be my suggestion too. Most likely whatever tractor you buy that is the right size will not fit in your garage. It might be a little hard to find something newer in your price range or impossible.
/ looking to buy first tractor with loader and backhoe #15
Do yourself BIG a favour - listen to Hay Dude's advice.
Buy a full sized construction backhoe. Use it for 5 years doing what you need it to. Sell it for what you paid for it and then go buy a SCUT.
Finding the right SCUT TLB for your job is like finding Sasquatch.
/ looking to buy first tractor with loader and backhoe #16
Actually, I saw one the other day ...
/ looking to buy first tractor with loader and backhoe #17
Maybe I should have said "find an apple update that doesn't break things I use regularly to give me features I don't want and need". I used to be able to copy and paste images easily on my ipad now it just wants to paste the links to the images!
/ looking to buy first tractor with loader and backhoe #18
Go buy one of these if you are closeish. Forget about the backhoe and hire that work done or rent a trencher. You can use this for probably 80% of what you want to do and mow with it afterwards. It will just take forever and a day to move that much stone with it but hey, you may enjoy it!
I list them since they have 1,200 pound loader lift in a small package... and the are Yanmar : )
/ looking to buy first tractor with loader and backhoe #19
Of course the used machine that’s affordable will have no mechanical issues will it?
/ looking to buy first tractor with loader and backhoe #20
Not if you check it out before buying it, right??
I’m not saying something like the lights, fan, etc might not be broken, but pretty much start it up and test it out a little before buying should do the trick on an old 2WD backhoe.
Heck, I’ve had brand new equipment break in first few times of using it, too.
2019 Big Tex 10PI-20BK4HDIR 5 Ton T/A Flatbed Equipment Trailer (A59230)
2019 Big Tex...
JOHN DEERE 850K LGP (A58214)
JOHN DEERE 850K...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
2025 Swict 72in. Skid Steer Bucket (A59228)
2025 Swict 72in...
2014 Acura MDX SUV (A59231)
2014 Acura MDX SUV...
