TruFuel 50-1or Stihl 50-1 or Red Armor 50-1??
   / TruFuel 50-1or Stihl 50-1 or Red Armor 50-1?? #1
5030
Rest in Peace
SE Michigan in the middle of nowhere
Kubota M9000 HDCC3 M9000 HDC
What is the best and experience? I got a gallon of Red Armor. We have e-gas here and it's terrible. Not cheap but is it worth it???
   / TruFuel 50-1or Stihl 50-1 or Red Armor 50-1?? #2
I found a nearby gas station that has 91 octane ethanol free fuel I buy for my two stroke fuel. If you goggle “ethanol free gas” you can find where you can buy it. Pure-gas.org is the website. I have to drive about 15 miles to buy it but still cheaper than the premade stuff.
Not my question and it's hard to find here anyway. I want some input on the syn fuel.
   / TruFuel 50-1or Stihl 50-1 or Red Armor 50-1?? #4
i use the stihlbrand and like it, no experience with other two.
use because I have intermittent use of chain saw. For blower I use ethanol free gas. I am lucky that neighborhood station has it
   / TruFuel 50-1or Stihl 50-1 or Red Armor 50-1?? #5
Never heard of Red Armor……Sorry
   / TruFuel 50-1or Stihl 50-1 or Red Armor 50-1?? #6
Great! Are you willing to truck it to us?
I tried "goggling" it over a decade ago. In the Washington DC area I needed a formal relationship with an airport to buy ethanol free even at a relatively small local airport.
In Mississippi it's around, but virtually all 87 octane.
I usually carry 5 gallons of ethanol free back to Alexandria, Va. every return trip.
I've only used Tru-Fuel when eth-free wasn't available to mix.
   / TruFuel 50-1or Stihl 50-1 or Red Armor 50-1?? #7
I like mixing my own two stroke fuel because I can run the oil I like. The closest station with E0 is over an hour away and it's $2/gallon more then E10. So I run E10. With fuel stabilizer (which I'd use anyhow as its hard to know how long my gas will sit) I have had no problems with any of my equipment. Even the machines like the lawnmower that sit all winter with gas in the carburetor.
In my area Pure-gas.org is not accurate, showing stations that I know no longer carry E0 or race gas. Call to make sure before you drive far.
   / TruFuel 50-1or Stihl 50-1 or Red Armor 50-1?? #8
I use SEF-94 40:1 , not cheap put it's the best out there. I have a Sunoco a couple of towns over with 91 E0 that I run for the "gas hogs".
   / TruFuel 50-1or Stihl 50-1 or Red Armor 50-1?? #9
I can't speak to ready made pre-mix, But I can share something abut the oil. I have always used Stihl synthetic with god results. Recently, I bought a ported and modified Echo from a saw builder who has a great reputation. He recommended Red Armor. He said Stihl oil is good, but Red Armor is better.
edit (I meant good results, although, I would have been thrilled with God results!)
   / TruFuel 50-1or Stihl 50-1 or Red Armor 50-1?? #10
I use Stens 40- l. 50-1 is too lean especially with todays hot running engines.
   / TruFuel 50-1or Stihl 50-1 or Red Armor 50-1?? #11
I just buy 90 Efree at pump here local at 1 buck more then e gas and mix with VP oil.
SEF premix fuel is VPracing stuff I heard.
   / TruFuel 50-1or Stihl 50-1 or Red Armor 50-1?? #12
I've always used Echo oil and never had a problem, no carbon, no plug fouling.
I will say tho, some of the good luck may be because there is no ethanol where I always get my fuel. Only time I strayed was yesterday, put the oil in my can, go to a closer station since all I needed was saw gas, figured I'd check it when I got home just because. I'll be d++ned if there wasn't ethanol in the gas which I refused to use and will slowly add it to my truck to get rid of. Went to my regular station and hoping they hadn't switched, nope....just good ole gas still.
   / TruFuel 50-1or Stihl 50-1 or Red Armor 50-1?? #13
Unfortunately many states do not sell ethanol free at the pump.
   / TruFuel 50-1or Stihl 50-1 or Red Armor 50-1?? #14
I can't speak to ready made pre-mix, But I can share something abut the oil. I have always used Stihl synthetic with god results. Recenty, I bought a ported and modified Echo from a saw builder who has a great reputation. He recommended Red Armor. He said Stihl oil is good, but Red Armor is better.
I Like Bel-Ray's MC 1 racing synthetic and Cenex non ethanol Premium mixed at 45 : 1
Almost 50 years using it.
Think I read somewhere that they make Husky's XP oil but can't find anything now.
Runs clean and smells "Good" also has octane boost.
   / TruFuel 50-1or Stihl 50-1 or Red Armor 50-1?? #16
I live in Oregon. We use non e fuel (5.19 gl for all the equipment mix 45-1 Stihl never had any issues in eight years!
   / TruFuel 50-1or Stihl 50-1 or Red Armor 50-1?? #17
Yep, as long as I can buy E-free I will run it in my stuff, including my truck. I mix with Stihl syn at 40/1 and have never had any bad results. I assume what you are asking about is pre-mix. I have no idea where you can even buy that stuff around here. Never seen it. Might as well buy Coleman white gas if you're gonna do that. :ROFLMAO:
   / TruFuel 50-1or Stihl 50-1 or Red Armor 50-1?? #18
In my area with zero gas stations selling ethanol free, chainsaw dealers, hardware stores, and box stores sell the pre mixed bottles.
Do keep in mind that leaning the mix out can and will cause scoring of the cylinder walls. I'd not exceed 50-1 under any circumstances.
   / TruFuel 50-1or Stihl 50-1 or Red Armor 50-1?? #20
I have bought the premixed stuff twice when buying new saw and new trimmer only because they extend the warranty if you buy it when you buy the equipment new. It’s very expensive like over $9 a quart ! Around here all the hardware stores and Walmart carry premix as well as some gas stations. The premix is very convenient for folks that don’t use much and it eliminates the chance of making a mistake mixing your own.
Ethanol free gas is readily available where I live most gas stations carry it and that’s what I use in my 2 stroke equipment.
I get a kick out of the very many people that claim mixing 50-1 is bad even though that’s what most manufacturers recommend , I’ve been using many different brands of 50-1 oil since the 70’s in lots of 2 stroke equipment and it’s never caused me any trouble.
2010 Specialized Structure 1456 (A56858)
2010 Specialized...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
159120 (A60430)
159120 (A60430)
2002 Allmand Night-Lite Pro Towable Light Tower (A56857)
2002 Allmand...
