YT359C Sluggish Power steering
/ YT359C Sluggish Power steering #21
Nice tractor and yes that would be a problem for me too. Agree that you should not have to run high RPMs for basic steering function. Hope they take care of you guys, sounds like they might, keep us posted.
/ YT359C Sluggish Power steering #22
Just got off the phone with Yanmar Tech Support.
They do acknowledge there is an issue and it is being addressed. They took my name and number and will get back if/when an engineering solution is available.
Please remember to update the group when Yanmar Tech Support fixes it. This sounds like a simple problem to address. I doubt that Yanmar designed it with the problem you are describing. It sounds like adjustment.
To answer that question about the JD310SE , and it's power steering.... most larger tractors have an independent hydraulic pump specifically for the power steering. So there is no way that steering can be influenced by other hydraulic systems. That's a nice feature and adds enough expense to beless common with utility and compact size machines.
I'm not sure how the newer Yanmars are plumbed, but know quite a bit about the older ones. Those had a shared hydraulic system with a single hydraulic pump. High pressure from the pump went first to a priority valve which distributed the flow. The priority valve was adjusted to insure that the power steering always had the necessary pressure regardless of RPM or accessory hydraulic use.
The degree of priority is simply adjustable on most priority valves. It just takes a wrench and screwdriver to change the percentage by which any system has priority over another. I wonder if the Yanmar's with a problem are simply misadjusted....perhaps when the loader was added. Some priority valves are also physically symmetrical - the old Yanmar ones were. So if the loader was added later that loader connecton to the priority valve is another source of error.
You could probably track this problem down yourself with a basic pressure gauge test kit and the appropriate hydraulic fittings. A hydraulic pressure testing kit is surprisingly inexpensive. It looks like $75 to $150 will buy a usable kit on amazon. Be sure you know which fittings your system uses.
Luck,
rScotty
/ YT359C Sluggish Power steering #23
Luck,
rScotty
Unfortunately the tractor is under a full 10 year warranty. I don't dare mess with the bypass settings.
/ YT359C Sluggish Power steering #24
Hey guys did anyone ever get a resolution in this ?
I've got a new yt359 open station, over all it's a pretty nice tractor but this steering issue is ridiculous.
On mine it doesn't really matter if it's revved up or not with a bucket of dirt it just doesn't want to turn.
No way all of them are like this.
Mine sounds like a relief valve is by passing. But I don't know a lot about how it works.
I do know I've owned 4 JD and 1 Kubota and none had any trouble steering at any rpm as long as the tires wasn't flat.
That being said the dealer is coming to get mine next week to look at it . We'll see.
/ YT359C Sluggish Power steering #25
Unless there is a mistake in the online specs, it shows the 359 to have about 5 lpm hyd flow LESS than the 347.
Researching more, I found this...
Power​
No surprises here: the YT347’s smaller engine limits power to the PTO to 39.5 hp, while the YT359 can deliver up to 52 hp. However, when it comes to hydraulic flow rates, the 347 exceeds the 359. The smaller tractor can move up to 10.1 gpm (38.3 l/min) for the PTO and 5.7 gpm (21.7 l/min) for the power steering. The 359 only pumps 9.4 gpm (35.5 l/min) through the PTO hydraulics and 5.3 gpm (20.1 l/min) through the power steering system.
/ YT359C Sluggish Power steering #26
It will turn if you begin moving the tractor but to me that is unacceptable.
/ YT359C Sluggish Power steering #27
This is true hydraulic steering. Paschal's Law aside, there is a reason that hydraulic tests are not performed at idle. Set the hand throttle at around 2k rpm and is should improve. Remember, if you are lifting a heavy load, it is true hydraulic steering and may be going over the relief built within the orbitrol (steering) valve. If this should happen, the slightest of movement should allow you to turn. Best of luck, let us know if this works.
This is the only answer at this point. I think it's a design flaw and judging from the responses from Yanmar, they don't seem to want to admit it. I called Yanmar tech support. They put me on a "list".
I love this tractor. When I do have a full bucket and the steering won't budge, I simply begin moving the machine and the steering works.. Think about it, turning the wheels when not moving doesn't do much for the work you are doing.
Yes there are times where you want the machine to start going a different direction from a standstill. This is where the problem lies.
/ YT359C Sluggish Power steering #28
Luck,
rScotty
Maybe - probably - it's just me, but I don't see the sense in not checking it yourself. Maybe an adjustment is the problem and maybe not, but testing the pressures and adjusting a priority or relief valve is a simple process. Doing that is no more complicated than any other routine maintenance and routine maintenance doesn't affect the warranty.
Having PS that works properly seems better than having an unresponsive 10 year warranty.
/ YT359C Sluggish Power steering #29
Maybe it's set to bypass just before the steering link bends or breaks or the cylinder seal blows. If they can design that amazing transmission, they sure as heck can design power steering that works in these conditions. The issue is they are ignoring it and not acknowledging.
/ YT359C Sluggish Power steering #30
I'd assume that Yanmar got the design right. Chances are that someone set it up wrong when assembling it or adding loader or remotes. My guess is that Yanmar knows that too & is why they are ignoring it.
But does it matter? It's easy to check the hydraulics with a gauge and see if the pressures are correct. That's the first step.
If you do that, you might want to leave gauges inline where you can glance at them while the tractor is working. That's what I do on mine. Surprising what can be learned that way.
rScotty
/ YT359C Sluggish Power steering #31
rScotty
Not something we need to do as a new tractor owner.
/ YT359C Sluggish Power steering #32
Well, I'll agree with part of that.
It's not something I'd want to do as a new tractor owner. But in the world we live in now I'm finding that doing things myself is something I often need to do if I want it to work right anytime soon.
But then I grew up in rural Texas in an era where most any of the guys in my HS class could turn a wrench, and half the gals could too.
I know you've been around long enough to know all this and more. Let us know how the dealer and Yanmar do with it. I'm curious.
rScotty
/ YT359C Sluggish Power steering #33
I live in rural Texas and have been wrenching and building stuff my whole life. Just got finished putting new brake calipers, rotors, brake pads, brake lines, wheel hubs, ball joints, front driveshaft on my 2004 Dodge. I have three rat rods, a huge shop with a lift.
It's a brand new tractor. What my expectations are seem to be higher than yours. I expect them to fix it not me.
/ YT359C Sluggish Power steering #34
Well if I don't get anything resolved from the dealer I'll for sure be back on here asking about the priority settings or whatever.
The way it is now is unacceptable.
/ YT359C Sluggish Power steering #35
Ok dealer said my tractor was 3 gallons low of hydraulic fluid. topped it off and tested it they claim its good now . we'll see.
/ YT359C Sluggish Power steering #36
In your first message you said that the fluid level was good. What happened?
/ YT359C Sluggish Power steering #38
This isn’t a post from the OP. I got confused as well.
Oh. I see that now. Thanks.
There are enough complaints about the YM359 power steering that I get them confused. Maybe there is something in the way they are plumbed that is making them read right when actually low on fluid.... or maybe something else.
I don't recall if anyone posted a resolution to the lazy power steering. Did I miss it?
rScotty
/ YT359C Sluggish Power steering #39
rScotty
Nope. No resolution yet by the OP.
/ YT359C Sluggish Power steering #40
I'm picking mine up tomorrow so if it's fixed or not I'll post up.
Sorry for the confusion I just figured there was more interest here so I posted.
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
2004 COMBILIFT CL30060LA45 FORKLIFT (A63276)
2004 COMBILIFT...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
