1.00 or 1.25 PEX line from Well
   / 1.00 or 1.25 PEX line from Well #1
Pettrix
High Desert Southwest
I have about a 50' run from the well to the house. The drop pipe in the well is 1.25" and I am going to run a PEX line from the 1.25" pitless adapter to the house.
The Uponor Type A pex costs:
1" at 100' roll = $160
1.25" at 100' roll = $415
A noticeable price difference. I can run a 1.25" to 1.00" reducer from the pitless and just run the 1.00" line to the house.
Will I experience any flow loss due to the smaller diameter pipe?
Or should I just pay the $255 difference and get the 1.25" pex?
   / 1.00 or 1.25 PEX line from Well #2
If your pressure is good 3/4 is adequate for 50 ft and 1” is plenty.
   / 1.00 or 1.25 PEX line from Well #3
Generally the line plumbed at the house is 3/4". If you're running pressure tanks their opening is usually 1 1/4". I run 3/4" PVC from the pressure tanks to the house.
   / 1.00 or 1.25 PEX line from Well #4
I'm gonna take the other side of previous posts. I'd go 1½" PVC (not Pex) all the way to your pressure tank (assuming it's inside the house or at least near the foundation outside). This will reduce water friction between your well head and the house, giving you more pressure and volume. And it's likely to be less $$ than 1¼" pex.
If you're going to install irrigation, I'd bump it up to 2". Also, if irrigation get a cycle stop valve. This will keep your well running during irrigation, rather than cycling off and on all the time, thus adding a lot of stress to your pump motor. Since you're in the desert you probably won't have irrigation, but just in case....
If you're using pex inside the house (yet to be plumbed) use at least a 1" main and T off of that with ½" runs to fixtures. ¾" to tubs, showers. Actually the right way to plumb the house with pex is to install a manifold and run home runs to each fixture, but plumbers don't do that, because they don't understand why pex is engineered that way. I have a manifold and home runs, with proper sized pex to each fixture, and I get hot water in under 15 seconds, anywhere in the house. If you run a ¾" or 1" main and T off of it, you're looking at 3-5 minutes to get hot water, because you have to flush out all the cold water in the main and subsequent T's. May not be an issue for you, but it was to me.
   / 1.00 or 1.25 PEX line from Well #5
3-5 minutes to get a hot water is a ridiculously long time. There’s recirculating systems available to circulate the trunk line back through the water heater so the trunk line stays hot. It waste some energy to do that but it offers nearly instantly hot water.
   / 1.00 or 1.25 PEX line from Well #6
Yup, 1 inch is certainly adequate no need to go larger.
  • Good Post
Reactions: JJT
   / 1.00 or 1.25 PEX line from Well #7
I’d go with 1-1/2 pvc. If it develops a leak you then push a snake through, and pull back a 1-inch pex. By only digging one hole at the pitless adapter.
   / 1.00 or 1.25 PEX line from Well #8
100 yards of 3/4" has been doing fine here for 25 years.
   / 1.00 or 1.25 PEX line from Well #9
I don't think that there is a huge difference. Pay now, or pay later. The 1 1/4" PEX has 56% more area than 1" and has less resistance to flow, so you will pay less on the electricity to get the water to the house. Both forms of PEX will have lower resistance compared to PVC pipe of the same size which has couplings.
Couplings are often the weak link, due to gluing imperfections and pipe stresses; how much is it worth to you not to have that worry?
You might also shop around to see if you can get better pricing elsewhere; just make sure that you get drinking water PEX.
All the best,
Peter
   / 1.00 or 1.25 PEX line from Well #10
All the best,
Peter
Belled end pvc is far superior to using couplers. Pvc is also far superior to pex for burial. Maybe if you take adequate precautions covering the pex it would be fine but pvc is a lot more resistant to rocks rubbing through it.
   / 1.00 or 1.25 PEX line from Well #11
Personally, I would probably opt for the black poly rated at 200psi. Probably cheaper than the pex not sure though.
   / 1.00 or 1.25 PEX line from Well #12
I used 160psi 1" poly 30+ years ago, 900' run, no issues. If I recall correctly, you can get ~20 gallons a minute with 1" pipe. More than adequate for my needs.
   / 1.00 or 1.25 PEX line from Well #13
Polyethylene black pipe for sure. don't know why people are suggesting PVC lol. Use PEX inside the house only.
   / 1.00 or 1.25 PEX line from Well #14
! 1/2" black poly here, heav.y wall but a bit of flexibility plus rock resistance.
That is also what my down well piping is.
   / 1.00 or 1.25 PEX line from Well #15
To answer this question you first need to know how many GPM your well is capable of producing. If you can get 50 GPM out of your well then run a 2" line. If your well is only going to give you 3 GPM then do not waste your money on large pipe.
In fact, if you WANT sediment to build up in your line use a large line size that moves a minimal velocity of water.
   / 1.00 or 1.25 PEX line from Well #16
My well is 500' with the pump set at 400'. I have 1 1/4" poly pipe from the pump to the pitiless adapter. The run from the well head to the barn is 220' using 1" Pex. The well produces 12 GPM and I can easily pump it dry if the water runs long enough.
There is no sense in sizing a pipe to handle a flow larger than the well & pump can deliver.
   / 1.00 or 1.25 PEX line from Well #17
I run 1 1/4” hdpe from the pitless to the pressure tank/CycleStop valve (reduces to 1” at the tank/valve). 3/4” PEX to a Viega Manabloc. 1/2” PEX runs to fixtures. Well flows about 11gpm. 2 hp pump with about 50’ of head to the shop. No flow or pressure issues.
I’m not a fan of PVC for water lines-bad experience on a prior home.
I would be placing the PEX into a PVC conduit pipe to protect and insulate it. Last time I ran PEX for a water line, it was installed in a conduit pipe for protection and insulation.
The water line comes through the stem wall, just above the footing, and then it enters the home under the slab. It comes into a mechanical room which has a small 3 gallon pressure tank as I use a VFD well pump so I don't need a large pressure tank. I actually don't have room for a large pressure tank so the small 3 gallon pressure tank works well as it attaches to the wall using a bracket.
   / 1.00 or 1.25 PEX line from Well #20
Typically the underground is polyethylene not pex. Pex is a more modern material
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
2007 Heil Heavy Duty Aluminum Tank Trailer (A56438)
2007 Heil Heavy...
