Kioti loader bucket
/ Kioti loader bucket #1
rayboman
Kyoti RX7320
I bought a Kyoti RX7320 last october and my bucket is split all the way down the back bottom of the bucket. Does anybody know what type of replacement bucket i could buy. it is an 83" buckey
/ Kioti loader bucket #3
Being a newish Kioti owner, Id like to know how and where’s a picture or two ? Wow
/ Kioti loader bucket #4
If the unit is that new, it should be under bumper to bumper warranty.
/ Kioti loader bucket #5
Most dealers have access to 2 buckets. The light duty one and the heavy duty one. I always buy the HD buckets, They hold up much better.
/ Kioti loader bucket #7
On the side, I rebuild loader buckets as well as excavator buckets and I've seen (and repaired some ugly ones). Anything is possible when the abuse is serious. Just did one where the back sheet was ripped. Had a nice smile in it too. Smiles are the most difficult to fix as you have to cut both side (vertical sheets away from the bottom sheet) to allow the bottom sheet to revert back to it's original form., then reweld the sides to the bottom. It's never a cheap date either. My shop rate is $130 bucks an hour based on actual repair time, consumables not included.
/ Kioti loader bucket #8
Maybe just repair that one? How far spread out is the split? Can you just lap joint an angled piece of steel across the split and weld it down both sides? Was it a light duty material bucket?
/ Kioti loader bucket #9
I sure hope it was the light duty version. Hate to think what it took to do that damage to the HD one.
/ Kioti loader bucket #10
I would love to see this. I've never heard of something like that, especially on a new bucket! Yikes.
/ Kioti loader bucket #11
I have seen a few buckets that needed to be repaired. The OP didn't state the machine was new so I'm going to assume its worn from back dragging.
Out of the 3 tractors I have owned 2 had bucket repairs at the back. It's going to be cheaper to repair the bucket rather then buy a new one typicaly.
Case 1150G Dozer (A66285)
Case 1150G Dozer...
2006 STERLING ACTERRA CAB & CHASSIS (A60736)
2006 STERLING...
Kubota SVL95-2S (A64126)
Kubota SVL95-2S...
Case 1845C Uni-Loader Skid Steer (A62679)
Case 1845C...
17394SFL (A61568)
17394SFL (A61568)
Steiner 450 (A64126)
