Baling wire options for farm use
/ Baling wire options for farm use #1
Pearlsnaps
Member
ENE TX
YM2500 now YT 359c
Howdy y'all
I unexpectedly found myself without any extra pieces of baling wire laying around. I don't even know where I got the stash that I was using.
All of my round bales are net wrapped, so I have no need for baling wire from a square baler. What is everyone else using as an alternative to actual baling wire from square bales?
/ Baling wire options for farm use #3
"Mechanics Wire" or "Tie Wire" for rebar securing.... Check Big Box, Hardware, Tractor Supply, Local Auto parts.....Similar to:
/ Baling wire options for farm use #4
Small square bales, around here, are twine-bound. However small spools of wire are readily available at the hardware store... mostly used for 'mousing' a hook or binding a lamb/suckling-pig for a sit-roast.
^^^ WranglerX has posted an example of what's available. It comes in different gauges & lengths.
/ Baling wire options for farm use #5
I was wondering about rebar tie wire. I used it quite a bit 2 summers ago building our garage foundation. It seemed to be easy to break once you start twisting it. Many times, when I put the twist tool on it and started twisting, it would snap off before I felt it was tight.
I wonder what the strength of it is compared to "real baling wire".
/ Baling wire options for farm use #6
Hmm, just looked up some quick numbers and found several references to rebar tie wire being 16ga black annealed wire is 40-60,000psi. Didn't look for specs on the baling wire.
/ Baling wire options for farm use #9
Se
And its about a 100 year supply....
Sell 100 ft rolls to your neighbors, and give some as gifts.
Bruce
PS: the main point was the wire gauge of real baling wire. And it is meant to be tightly twisted without breaking.
/ Baling wire options for farm use #10
I have used rebar tie wire for decades. If you need something stronger double it up (y)
/ Baling wire options for farm use #11
I have about a 6" spool of wire I think is electric fence wire. It's been around for at least 20+ years. I've made choke cables and control cables with it and works very well. I bought the spiral sleeve separately so I can make the length I need. I also had 1/4" shrink tubing to make them look factory for old lawnmowers. I can't even remember all the times I've cut short pieces off that spool for paint hangers and what not. I still have a lot left though. I can't imagine having a 100lb$ of bailing wire just sitting around unless I had a bailer.
Thanks for all the replies gentlemen.
I'd seen that rebar tie wire on tractor supplies website. Wasn't sure about the twist power of it so I appreciate that feedback. I don't really need a 100year supply of it that comes in those big rolls 🤣🤣 but I guess it's a one-time purchase for the rest of my life wouldn't be too bad.
/ Baling wire options for farm use #13
I will say high tensile fence wire can trash some cutters. I tried to cut some with a pair of Craftsman slip joint pliers and they never cut again. My standard fencing pliers cut it just fine.
/ Baling wire options for farm use #14
I hate when I do that. Tie wire can shear. I tied a lot of rebar in my youth and still use it today on the ranch. For tough applications double it up. The correct way to get the max tightness is to (a) use tie pliers that have a wide flat nose (b) pull the wire tight by grabbing the 2 pieces to be twisted and racking the pliers back against the pipe or (whatever you are tying) then twist up the slack you created. A little final twist can be applied but not too much.
/ Baling wire options for farm use #15
Electricians/linesman pliers works pretty well...
/ Baling wire options for farm use #16
I've used those small rolls of rebar wire for close to 50 years, and it works great. Years ago I had some coaching that resembles scootr's description. Using it double with a saddle tie makes incredibly strong joints. Linesman pliers are my choice.
A few years ago I picked up a roll of wire at Tractor Supply that I really like. It is about the same size as rebar wire but has a coating of some sort that makes it nice to work with, and it doesn't rust up in my tool box like the rebar wire does.
/ Baling wire options for farm use #17
No doubt lineman pliers will work great. Are those Klein's shown? Good stuff.
The tie wire pliers have the added hook on one handle making the pull and tug a bit easier.
Later we got gadget twisters that were "faster tighter" but I prefer the do it yerself methods.
That's one of the pleasures of old age.
/ Baling wire options for farm use #18
The company where I worked did some precast concrete light bases. Always looking for something to make life easier, we tried using a handheld machine for tying rebar. It looked a lot like the one in the video below. It was a cute idea, but it didn't make the wires as tight as doing it by hand.
/ Baling wire options for farm use #19
TSC has galvanized electric fence wire that is easy to work with and won't rust. Don't try high tensile wire.
/ Baling wire options for farm use #20
YES.... It comes in different gauges and different size spools..... Should have also mentioned that when I did inital tie wire spot..... Old age and mental fog is my excuse and I am standing buy it....
Deutz F3L912 3-Cylinder Air-Cooled Diesel Engine - 48 HP - Industrial Pump Takeout (A63689)
Deutz F3L912...
2011 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2011 FOREST RIVER...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
INSPECTION (A65583)
INSPECTION (A65583)
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
