Baling wire options for farm use
   / Baling wire options for farm use #1
Pearlsnaps
ENE TX
YM2500 now YT 359c
Howdy y'all
I unexpectedly found myself without any extra pieces of baling wire laying around. I don't even know where I got the stash that I was using.
All of my round bales are net wrapped, so I have no need for baling wire from a square baler. What is everyone else using as an alternative to actual baling wire from square bales?
   / Baling wire options for farm use #2
Electric fence wire, of the gauge you want.
Bruce
   / Baling wire options for farm use #3
"Mechanics Wire" or "Tie Wire" for rebar securing.... Check Big Box, Hardware, Tractor Supply, Local Auto parts.....Similar to:
   / Baling wire options for farm use #4
Small square bales, around here, are twine-bound. However small spools of wire are readily available at the hardware store... mostly used for 'mousing' a hook or binding a lamb/suckling-pig for a sit-roast.
^^^ WranglerX has posted an example of what's available. It comes in different gauges & lengths.
   / Baling wire options for farm use #5
I was wondering about rebar tie wire. I used it quite a bit 2 summers ago building our garage foundation. It seemed to be easy to break once you start twisting it. Many times, when I put the twist tool on it and started twisting, it would snap off before I felt it was tight.
I wonder what the strength of it is compared to "real baling wire".
   / Baling wire options for farm use #6
Hmm, just looked up some quick numbers and found several references to rebar tie wire being 16ga black annealed wire is 40-60,000psi. Didn't look for specs on the baling wire.
   / Baling wire options for farm use #9
Se
And its about a 100 year supply....
Sell 100 ft rolls to your neighbors, and give some as gifts.
Bruce
PS: the main point was the wire gauge of real baling wire. And it is meant to be tightly twisted without breaking.
   / Baling wire options for farm use #10
I have used rebar tie wire for decades. If you need something stronger double it up (y)
UNUSED CFG INDUSTRIAL PD680-PZ POST POUNDER (A51244)
UNUSED CFG...
E-Z Trail 675 Grain Cart (A50514)
E-Z Trail 675...
BUSH HOG 32601 - 6' ROTARY MOWER (A51243)
BUSH HOG 32601 -...
2019 VOLVO EC350 EXCAVATOR (A51242)
2019 VOLVO EC350...
UNUSED MOWER KING ECSSCT72 TRENCHER (A51244)
UNUSED MOWER KING...
AMG M 35 A2 C drop side 2 1/2 ton 6 x 6 truck (A50323)
AMG M 35 A2 C drop...
