Thinkin about..
/ Thinkin about.. #1
Duds13
Charlton, NY
Kioti CK2610, Kubota BX 2200
A new saw. Current saw is a Stihl MS271 Farm Boss. I like Echo for the 5 year warranty, which saw in their lineup would be a better (power, faster) saw than my Stihl? There's really nothing wrong with my Stihl, just looking for some more power but not looking for a huge saw. All I'm cutting is firewood. I take down occasional trees if they aren't huge and are in an open area where they won't get hung up. Thanks for the help!
/ Thinkin about.. #2
My main firewood saw is a Husqvarna 372xp. I’d definitely recommend that saw if the budget allows. I had a 590 echo that lacked to impress me and I sold it. To be fair it’s a lower priced saw. I’d look for more cc like a 680 echo. I have a 6100 Makita saw as well. I think it’s a little behind the Husqvarna in quality but it’s not a bad saw. The 6100 would definitely be an upgrade from a 271 but I’d still consider a size bigger saw.
/ Thinkin about..
One of my best buds is a logger and a big Husky fan. That's two votes for Husky
/ Thinkin about.. #4
Very good saw, but approaching $1,000 now, but it would blow away a MS271 Farm Boss. It’s like 5.4HP buy runs around 10,000RPM
The Makita (Dolmar) 6100 is much more reasonable priced at $650, but like 4.6HP but screams about 13,500 RPM.
/ Thinkin about..
Ooof, yeah not looking to spend $1000. I'll take a look at that 6100. Appreciate the replies so far!
/ Thinkin about.. #6
I really like my big Makita 6401. Screams and cuts like a sumbiatch. Has amazing sound.
/ Thinkin about.. #8
The 6100 was a saw I refused to stock as a dealer. I would order one if somebody really wanted one. Otherwise I would push you toward the 6400/6401/6421. The reason was the 6100 uses the K095 mount which limits you to 20 inch bar or 24 if you searched for that bar which was somewhat uncommon. The 6400 series uses the D009 mount which can go larger to 32 inch or more. 24 inch was the normal bar I sold that saw with. Cost difference between the 2 saws was $20.
/ Thinkin about.. #9
About the best saw for the money has always been any of the Husqvarna 365 variants.
/ Thinkin about.. #10
I have both for my 6401’s. Use the 20” 95% of the time.
I had 2 of them, bought them completely refurbed from Home Depot rentals. Sold one. I shouldn’t have done that.
/ Thinkin about.. #11
Stihl 261-C is what I bought to take over the top spot from my Farm Boss. Sticker was up to $699 but they charged me $630, 'sale price'.
Still love the Farm Boss but just wanted a little more power and a little less weight. This 261 is touted as a entry level 'Pro' saw. It was hard to find one on the shelf.
/ Thinkin about..
I seriously considered a 261 when I got the Farm Boss and kick myself for not getting one.
/ Thinkin about.. #14
I always felt like those Makita/Dolmar saws were good because saw so many at rental centers, HD mainly. I rented a Makita cut off saw once and was very pleased with it. But when it came time to buy one I wound up with a Stihl 420 because local dealer.
Never ran across any Makita/Dolmar dealers or any store carrying them as a main line.
/ Thinkin about.. #15
I run a 261C at work. Its not a strong felling saw.
The Farm Boss has been 'good enough' for what I have needed felling and cutting. I like the 261C for the couple extras you get, Comp release, less weight, little more power, etc but I can see how if you were working professionally you would want more.
/ Thinkin about.. #16
The Makita is a great saw. I have a couple of echo's one is a 590, I like it fine, but, home owner saws are weaker and heavier than pro grade. If you don't run it much, the 590 runs a 20" chain fine in hardwood, and I would recommend it. If you cut many cords a year, or fell larger trees the pro grade saws are worth the difference in money.
Best,
ed
/ Thinkin about.. #17
I needed to fill the 60cc "hole" in between my 50cc & 70cc 044 stihl. I got the cs620 Echo and even the diehard Stihl and Husky boys really have a hard time finding anything wrong with these. It's an 'X' series and that's more of a commercial saw with comp. release, aluminum loop handle and chain cover, adjustable bar oiler and reportedly it's a ported & tuned 590. Great firewood saw and $630 out the door not on sale.
There's a bunch of saw builders (hot rodders) on YouTube comparing it with both of the other orange saws.
/ Thinkin about.. #18
Have you checked out battery powered chain saws? I use a 6” for trimming, 12” for falling/bucking 10” and under wood and a 18” for larger trees/logs. They work fine for falling and cutting personal firewood, little land clearing and helping friends out. I also have two gas power chainsaws that I haven’t used in 3-4 years. My favorite saw that I got about a month age is the 56v EGO. Battery saws work as good as the equivalent gas saw, plus they are quieter and a lot less hassle.
/ Thinkin about.. #19
I have an Echo 590 Timberwolf and really like it, the power is adequate, I like the feel and balance of the saw.
/ Thinkin about.. #20
Just replaced my Husky 562XP with the Echo 620. Lost the bearings in the 6 yr old Husky, not sure why. Have only run one tank of gas through the Echo, but seems to have the power I was use to, controls set up logically, like the sprocket outside the clutch, see thru gas tank. It does have a lot of plastic, but so does everything else. Time will tell about how it lasts, but it was also $599 instead of $900+ for the comparable size Stihl or Husky. The 5 year warranty and a good dealer also helped.
Fecon 72in Mulcher Head Skid Steer Attachment (A66734)
Fecon 72in Mulcher...
2017 Crane Carrier Co. T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2017 Crane Carrier...
OUTBOARD ENGINE STANDS (A66738)
OUTBOARD ENGINE...
2012 FORD FOCUS SEL (A64280)
2012 FORD FOCUS...
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
2007 JLG 450AJ SERIES II SKYPOWER TELESCOPIC BOOM (A65056)
2007 JLG 450AJ...
