Battery Backup for Sump Pump
/ Battery Backup for Sump Pump #1
NibbanaFarm
New England
BCS 739, Cub Cadet 2544
Greetings. We live in an area that has frequent power outages. We have come to expect to lose power with just about any rain/wind event. Following the rain the sump pump is going to be cycling or I get water in the basement. I have a generator that runs the whole house but is a bit of effort to start up and more effort to put back into storage. A lot of times the only absolutely necessary item is the sump pump. (And we can't leave for travel if any weather events are expected.) I'd like to get a battery backup for the sump pump. I've found two that look like they'll do the job, and one I'm not sure about. Opinions or recommendations would be appreciated.
Model 933 | SEC America This one is made in USA and I was able to view all the docs online and convince myself that it will work. Also over the phone customer service was excellent. Around $800.
1500W Primary Sump Pump Backup Power System At least some of the components of this one are made in China. Can't find any docs on the website. Called customer service, asked a question and was disconnected. Somewhat more powerful but either should run my 3.5 amp Flotec pedestal pump. Around $500.
CyberPower Sump Pump Switch - Ace Hardware Looks a lot like an UPS for a computer. One of the reviewers said if the battery runs down it needs to be reset or it won't work when the power comes back on. That bothered me. A little under $200.
Thanks for your help.
Nibbana
/ Battery Backup for Sump Pump #2
That is a great idea! I live in snow country too. The 933 looks perfect. I would want 3 though, wellhouse, sump pump and pellet stove.
/ Battery Backup for Sump Pump #3
Your #3 choice look nice and affordable too.
/ Battery Backup for Sump Pump #4
A ups should not be used to power a sump pump. Heck, my ups wont even power my printer. Its not designed for motor start loads.
/ Battery Backup for Sump Pump #5
Whatever unit you buy, I would make sure that you have enough batteries attached to take you out three days or so. If you can, check with the companies what the maximum capacity of the batteries could be for charging. Then when you run the generator once a day, you won't have discharged the batteries very far, and they will last longer.
FYI: most batteries can charge rapidly 20%-80%, and then slow down the charge rate. Lead acid batteries don't do well below 50% discharge, unless they are deep discharge marine/RV batteries, and they may not be worth the additional cost.
There are 12V sump pumps, which may be a better choice for your application. You could, if you have space have both a 120V and a 12V pump in the same sump. Pumpspy makes a dual pump 120/12V system.
https://www.amazon.com/Superior-Pump-92900-Submersible-Tethered/dp/B005MKGRBO
https://www.amazon.com/Zoeller-508-0006-Aquanot-ProPak53-Preassembled/dp/B00M3B5YQE/
Using a 12V pump improves the efficiency when on battery power.
All the best,
Peter
/ Battery Backup for Sump Pump #6
Solar generators are newer, better solutions for backup power. 2 things you need to know running watts & starting watts (watts = volts x amps). Look at Ecoflow Delta2 or larger unit. Other portable solutions include Bluetti, Zendure, Jackery. Small gas generator better choice to recharge batteries over solar panels
You could invest in larger permanent installs
Yea, after reading the reviews, it doesn't look like the third would be a good choice for sump pump application. Several people said it needed to be reset if the battery drained down and wouldn't work until reset even if the power came back on. Also lower power output and battery capacity.
Edited to add: I should have mentioned, I don't have room in the sump for another pump. My understanding is that solar is just going to recharge a battery. We lose power specifically during storms so solar isn't going to help. It usually only floods after a storm when there's a lot of water in the ground. Once the water drains away the pump doesn't come on often if at all.
/ Battery Backup for Sump Pump #8
Disclaimer; I had a similar experience at our previous residence. But, I had a situation where during high rain and snow melt, my sump pump might start and stop 30 times in an hour. The only time the pump was off was about 30 seconds while the crock refilled.
The first choice seems to be the best. You say you have a 3.5 amp pump, but that is running amps. Batteries are going be be depleted more quickly due to starting current and in a situation such as I had at probably double as an equivalent (speculation on my part). So, using the chart in the link, even using the largest 8D battery and doubling the amps to account for start amps, it only provides about 12 hours of run time. In my case, that would have maybe been 2 days. Hardly enough to go away for a weekend and not worry.
In the end we just bit the bullet and installed a whole house standby generator. That saved at least 2 planned trips. One of them we even left while the generator was running and it ran another day until power was restored. I knew that when the app said the generator had stopped and was ready to run again. And there was the alert text from the power company that power was restored.
One final thought, if you choose a flooded cell battery setup, make sure you have good ventilation to remove the hydrogen gas generated. The alternative is a sealed battery such as AGM.
/ Battery Backup for Sump Pump #9
One reason i like my automatic standby is i have 2 drain pumps in basement. Dont want to worry when away.
/ Battery Backup for Sump Pump #10
Maybe restrict the inlet or outlet piping so pump runs longer and cycles less?
/ Battery Backup for Sump Pump #11
@NibbanaFarm ...
Do you have city water? If so, I recommend a water driven backup pump. No batteries to maintain, and it always works.
Basepump makes good ones.
/ Battery Backup for Sump Pump #13
There’s better ways to accomplish the same thing. If you were going to permanently cripple your output you might as well use a smaller pump to reduce the battery load. You could make the sump pit bigger so it does more work per cycle or you could install a second smaller output pump with the float set lower. That way the larger pump only started when the smaller one is overwhelmed. A sump pump cycling isn’t that big of a deal anyway. They’re not starting under much load and the starting current isn’t that much.
/ Battery Backup for Sump Pump #14
Can't recommend solar as a solution. However Ecoflow delta2 has LiFePo4 battery chemistry, 1800w inverter, 1024wh battery (about $1k)
1800w gas gen (dual fuel) about $1400, runs on gas or propane. The solar gen can start/stop gas gen to recharge battery. Downside special charge cable is 16' long. Gas gen can make 120v AC, uses DC on charge cable for faster charging. Phone app lets you check up on equipment operation.
Larger Delta Pro could run fridge, fans on heating stove and sump pump -- solar gens also recharge from power grid.
I don't have city water or sewer.
When I first installed the sump pump it cycled a lot. I got a lower power pump and dug the sump about six inches deeper and that solved the cycling problem. Now, depending on how much water is in the ground, it can run for 5 or 10 minutes straight. It's only a problem after heavy rain or snow melt. The sump is dry for months during the summer and can go for long periods without ever cycling.
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
FENCE PANELS (A58214)
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
High Accuracy Meter Fuel Pump (A61166)
High Accuracy...
Brock 36'x17' Flat Bottom Grain Storage Tank (A57148)
Brock 36'x17' Flat...
1998 New Holland TC21 (A62177)
1998 New Holland...
