ID Grain Drill
/ ID Grain Drill #1
dieselscout80
Elite Member
South Carolina
New Holland TC45DA
I got a grain drill, but don’t know what manufacturer or model number. It’s 8‘ wide with 12 drops to single disc openers.
The previous owner thought it was a IH number 5, I didn’t find any pictures that match my drill.
There is NOT decal inside the grain tanks/bins.
/ ID Grain Drill #2
Possibly a McCormick M or MF
/ ID Grain Drill
Here’s a couple of pictures of the grain tank.
/ ID Grain Drill
Here’s a couple McCormick M listing. The tank seems bigger, but that maybe just a function of it being a wider drill.
/ ID Grain Drill #5
I saw those too. The hitch configuration was more of what I was looking at to compare. Yours has the back-to-back angle tongue like the smaller M, or perhaps a #10
/ ID Grain Drill
Could an old drill like this be converted to use a hydraulic cylinder to lift the discs rather than the old mechanical setup?
/ ID Grain Drill
I put a tape measure on it and it doesn’t seem to be 8’wide.
It has 12 drops spaced 7” apart and the discs (single disc) are 81" outside to outside.
The seed box is 7'3" wide.
Question what width is this McCormick M drill considered?
/ ID Grain Drill
Anyone know what wheels will work on a McCormick M drill that has rubber tires aka low wheel.
The part number in my manual is 453 631 R91 for 15” wheels and 16 632 W for 16” wheels.
They are 8 bolt wheels and the center hole a bit less than 5.25” in diameter.
/ ID Grain Drill
Well after welding the area around the valve stem on the one wheel I have a working McCormick M grain drill. I planted 2.5 acres of rye with it today.
Note 225/75r15 tires are too wide as they rub on the drive end of the drill. It had 215s on it but couldn’t find any of them.
/ ID Grain Drill
After finally using my McCormick M grain drill and the factory power lift works great I don’t think I’ll be switching it to hydraulic lift.
I do need to look at replacing the roller wheel bearings as it has plenty of play.
/ ID Grain Drill #14
Glad to see its working for you.
2007 Mack CV713 Granite T/A Pole Truck (A62679)
2007 Mack CV713...
2004 INTERNATIONAL 7400 20FT T/A FLAT BED (A59914)
2004 INTERNATIONAL...
2009 Bobcat T190 (A64126)
2009 Bobcat T190...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A65054)
2001...
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
