How remove bolts-ct2025 brush guard?
/ How remove bolts-ct2025 brush guard? #1
wisconsitom
Bobcat ct2025 HST
Hi all. Wishing to remove factory brush guard to add/ weld expanded metal. Guard is secured by 4 bolts. Bolts have no nuts and deadend in frame. These bolts are very tight. I put all I dared to on them, working from below with great leverage, and could not budge. I mean, I was pulling so hard on that wrench that had it slipped or had one of these bolts started to turn, I might've broken some ribs. But no-go. Any suggestions,?
/ How remove bolts-ct2025 brush guard? #2
Heat to cherry and crank them off, or just break or saw or grind them off. Nuts & bolts are cheap. Einstein proved that Time is Money. (That would be Herb Einstein).
/ How remove bolts-ct2025 brush guard? #3
I would highly recommend you invest in a battery, or air, impact wrench.
Got a couple battery units, suppose we can give em a try. I just want to be assured these bolts are meant to be removed and that they aren't left-hand thread or something weird like that. Thanks. Yeah we're looking at air impact unit for up at that shop. Maybe sooner than later.
/ How remove bolts-ct2025 brush guard? #5
After giving them a soak in penitrating and alowing a bit of time to work, I go for an impact wrench, but if that is not enough I go for my old fashion impact driver you whack with a big hammer. If that doesn't do it you finish up with a bolt in two halves. Then it's plan B
/ How remove bolts-ct2025 brush guard? #6
I have taken mine off with a battery milwaukee impact wrench. I splurged a bit and got the one off ebay with the bobcat laser cut into it. Looks better than factory and fit well. Just drill 2 holes bolts onto the factory guard.
Thanks all. Will try battery impacts when I'm back up there. Wouldn't mind not sizzling that paint off where bolts attach if I don't have to.
I like those Bobcat (and Kioti) grills they offer, but we're already down the road of making our own.
/ How remove bolts-ct2025 brush guard? #9
Bought or built, they're an absolute must; it only takes one rogue pole, stick, branch, etc., to really ruin a day.
/ How remove bolts-ct2025 brush guard? #10
Any chance you still have a link? I made one but I'm not entirely happy with it (other than price).
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
40' CONTAINER (A52706)
SKID STEER ATTACHMENT (A58214)
SKID STEER...
2021 FORD RANGER (A60736)
2021 FORD RANGER...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
500BBL SKIDDED FRAC TANK (A58214)
500BBL SKIDDED...
