Best way to get diesel into the tractor?
   / Best way to get diesel into the tractor? #11
Battery powered pump,best thing ever.Use it for tractor,mower,atv.
   / Best way to get diesel into the tractor? #12
I just set my tank on the floorboard of the tractor, open the ball valve and wait a little bit.
   / Best way to get diesel into the tractor? #13
Nice. Unfortunately some of us still drive orange tractors that fill like lawn mowers .
I have been using a 12v pump for 5gal can transfer. I'm in the process of moving to a 55gal blue plastic barrel with the same pump
   / Best way to get diesel into the tractor? #14
Another vote for 12V pump. So much easier.
But I have used the little pumps that run on two D cells. Still use that type for filling the ZT, Mule etc.
   / Best way to get diesel into the tractor? #15
A “shaker siphon hose”. Self priming with a couple shakes. About $10.
1) Set fuel can on tractor (fender, hood, etc..) above fuel tank.
2) Inset check valve end of hose in fuel can, other end in tractor tank.
3) Shake check valve end of hose up and down a few times.
4) Go do something else for 3-4 minutes while can empties.
   / Best way to get diesel into the tractor? #16
   / Best way to get diesel into the tractor? #17
I have a couple of battery powered ones similar to that. They have an auto shutoff feature. I use them to fill the lawnmowers now, but I used to use them to fill the tractors too until I got my tank and 12v pump setup. Pouring fuel out a 5-gallon jug gets old at my age. :D
It's funny, I've got a battery operated one, I've just never used it. 🤣
   / Best way to get diesel into the tractor? #18
Nice. Unfortunately some of us still drive orange tractors that fill like lawn mowers (n)
I see 2.2 gal/min on most of the battery ones (on LEVEL transfer - who does that???). What's the lift range? Can it pump from the ground to the tractors fuel tank (hood level)???
   / Best way to get diesel into the tractor? #19
On mine I have have to set the can on a 2' step ladder (the hose doesn't reach),yes 2.2 gal per minute and auto shut off.Still a lot better than lifting a 5gal.can.Enough lift to fill no problem.
   / Best way to get diesel into the tractor? #20
Siphoning is the best. But I use a longer hose, put the container in the FEL, use the FEL to do the lifting.
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A54607)
2007 FREIGHTLINER...
2008 Ford E-350 Altec AT200AV 30ft Bucket Van (A55788)
2008 Ford E-350...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
2007 MACK CTP (GRANITE) ROLL OFF (A54607)
2007 MACK CTP...
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
UNUSED CFG INDUSTRIAL QH12R EXCAVATOR (A54756)
UNUSED CFG...
