FELs and digging
/ FELs and digging #1
SmallChange
New Holland WM25 with 200LC front end loader, filled R4 tires 43X16.00-20 and 25X8.50-14 (had a Kubota B6200D with dozer and R1 tires)
I kind of think "front end loader" means an implement on the front end for picking up and moving loads, from a pile. I fear my little CUT bucket (with a straight edge) isn't meant for cutting into the earth, and if I try to do that, I should go easy, because I'm pushing it out of its intended comfort zone.
But I also think a "backhoe loader" that has teeth on the backhoe bucket and ALSO the front end loader bucket is indeed meant for cutting into the earth. So, it's heavier as well as having teeth.
These seem contradictory. So, how do you tell if a bucket on the front is intended for actual digging? Is it the teeth? Is it the fact that there's also a backhoe on the other end? Putting a tooth bar on my bucket could be taking a bit of a chance with it, right?
Enlighten me please? Thanks!
/ FELs and digging #2
It is more the style of loader and strength of loader arms and frames vs teeth or no teeth. I use my FEL to move dirt but am also conscientious on this not a loader meant to perform heavy excavation work. I do have a tooth bar which helps immensely for digging but the down side is that is really limits curl capabilities. I also usually loosen any hard packed dirt with rippers or my disk to make digging easier.
/ FELs and digging #3
A toothless bucket can still dig into the earth, it will just take time. Works best when you try to skim a little bit of dirt at a time. If you hit a large rock though, then for the most part, you’re at a dead stop.
Like Oldnslo says above, you could loosen up the dirt first. I used to do that with my tiller.
/ FELs and digging #4
The type dirt you're digging will come into play as well. I live in an old lake bed - 14,000 years ago at the end of the Ice Age my place was submerged. There are virtually no rocks and the digging is pretty easy. Trenchers work well here for burying pipes here, too.
/ FELs and digging #5
By contrast here it's clay and rocks. :cry: However the FEL works great to get gravel out of the creek bed.
/ FELs and digging #6
On my prior tractor, a 7-point toothbar dramatically transformed the digging power. The OE straight cutting edge simply did not apply enough local pressure to bust up hard packed soil without putting the entire weight of the tractor behind it - which was obviously very hard on the loader frame. A tooth bar made it able to penetrate into packed soil - but you still need to dig slowly and carefully. If you see the loader frame twisting, STOP.
My newer tractor came with a piranha toothbar on it, and it works ok too. Concentrating the FEL power on smaller area enables much higher local pressure to break up soil or other materials. Highly reccomended.
/ FELs and digging #7
There's quite a bit of difference in stress between a 60" loader bucket vs a 20" backhoe bucket digging into the same compacted material. I doubt that the loader bucket on even a backhoe is really intended to dig into very much compacted material. I believe the bucket on my Terramite is more intended to move material that has already been dug by the backhoe bucket. There is a noticeable difference in the size of the arm assembly for the bucket compared to the front loader lift arms and cylinders.
Although adding teeth to a front loader bucket will help somewhat with compacted material, most tractors probably aren't designed to do that and you're taking a risk of damage if you go too far trying to dig with a FEL.
/ FELs and digging #8
I've done quite a bit of excavating over the years with a variety of kubotas ranging from a b series to a grand L usually for patios and walkways in areas that it wasn't worth damaging the rest of the yard with a skidsteer. I think the determining factor is how much rock is in the soil. We have a mix ranging from soft sand to pure clay but very little rock. I even had a customer that dug a few hundred yards of virgin soil out next to his house to make a walkout basement with nothing but the standard bucket of a deere 1026r. As long as you are digging in a way that causes a consistent load from one side of the bucket to the other and greasing religiously you wont hurt anything.
/ FELs and digging #10
A toothbar essentially puts the same force (the partial weight of your FEL and tractor, and any pushing force) onto a smaller area, fewer points. So more rock, dirt and sod busting PSI, but you can keep the same force on the loader arms and cylinders…or try to.
A spade bucket does the same thing.
/ FELs and digging #11
You're on the right track... With common sense a FEL can dig, and teeth will make it easier and put less stress on the machine. The object of adding a tooth bar is not to transform a FEL into a bulldozer that will move mountains.
I don't have a tooth bar (on the short list) so when I have had to dig I generally run a 5' tiller over the area, then scoop with the FEL. My area is mostly hard clay that will stop a standard FEL bucket in its tracks. Likely doable with teeth on the edge.
/ FELs and digging #13
Honestly they are not made to dig. They are generally too wide to be easily pushed into the ground. And if the ground is soft and you do manage to get a good hole started. At about 3-4 ft in you will need to start to drive the machine into the hole and back out with a bucket load which can be a real chanllenge at around 5 ft... in my experience.
/ FELs and digging #14
I’ve been able to dig with my current tractor and my previous tractor, a Kubota BX. You have to take your time and like someone said, just kind of skim along.
/ FELs and digging #15
Didn't Kubota in the early US sales years require their tractors to be able to dig a hole with the FEL deep enough to drive the tractor "under" ground level and then drive out and then fill the hole in.
Could have sworn I saw an ad or something in their literature many years ago.?
/ FELs and digging #16
Like said before, not really designed to dig, but can be done ----- but, dig slowly, taking just a few inches at a time. A tooth bar dramatically improves the digging capabilities. I have done a bunch of digging prepping pad sites for buildings. The secret is to go slow, small 'scrapes' vs 'digging', and to watch the loader. You'll know if you're pushing too hard.
I picked up one of these for my 66" bucket, really made a difference!
/ FELs and digging #18
I dug a grave for a horse a while ago. 72" bucket width. 6' deep. Make sure you have extra weight on the front to get down-force & 4wd to back out of the hole. keep the ramp angle shallow. Necessity is the Mother of Invention. I also recently dug up a water line break with my bucket. In this case the bucket size gives you a hole big enough to stand for repairing the line and for getting to the exact location of the break.
/ FELs and digging #19
Same here Twice one with the Ford 3000 FEL and one with the Rhino. I did Over pressure a hydraulic line when digging, pushing with the bucket valve centered and "popped" the line.
Part of the reason for having a full size backhoe now. It can be done , but an involved time consuming digging job for an FEL for sure.
/ FELs and digging #20
I have twice dug horse graves with my 2WD JD870. Smooth 5 foot bucket. Just takes time. It has been a while but I recall more than an hour, less than two. I did buy a toothbar but have not had to dig a grave since I got the toothbar.
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
John Deere Z994R (A60462)
John Deere Z994R...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59910)
2018 FREIGHTLINER...
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
