/ Harbor Freight Tools that don't suck #15,301
I bought this magnetic sweeper for the Members Only price of $9.99. To test it, I rolled it over a 9/16 open end wrench twice and it picked it up both times. If it keeps my tired old bones from having to crawl under or out from under a vehicle to get a tool once, I'll call it money well spent. 17 In. Mini Magnetic Sweeper
/ Harbor Freight Tools that don't suck #15,302
Those work great but the handle connection is flimsy. I attached a right-angle shelf bracket using hose clamps, to reinforce the connection.
This was after I used it to pick up dozens of roofing nails on grass and all the way down the unpaved driveway, after the roofers departed. Now it works as intended.
As you said its great for reaching under the workbench, tractor, etc for a tool. Or searching for the washer that fell and rolled.
/ Harbor Freight Tools that don't suck #15,303
One of my older pistol grip grease guns has a needle tip on it.
If I go down to my shop today I'll have to get it and the winter grade bar oil for it.
Not even really looking forward to using it but after this storm goes through I at least go cut a little bit with it to be sure it's in working order.
Winter grade bar oil??? If that's sold in the south I don't know about it.
/ Harbor Freight Tools that don't suck #15,304
Thanks California. I'll keep an eye on the handle connection.
/ Harbor Freight Tools that don't suck #15,306
sounds like a New England product, Canada... some bar oil is a lot runnier than others.
I bet one could mix something appropriate in it to improve viscosity.
I've gone to pour from a very cold jug and just waited for thick goop to come out.
Maybe get a gallon jug, pour half the bar oil in it and dilute with? Motor oil?
of course if you get it too thin it will just fling off and likely make a mess.
I liked the old style where you could push in a plunger for an extra shot of oil
/ Harbor Freight Tools that don't suck #15,307
It's a lighter viscosity oil for use in cold temperatures, I've seen the standard oils pouring about like tar when it wasn't even real cold just 20F or so.
/ Harbor Freight Tools that don't suck #15,308
My bar oil is like molasses right now.
/ Harbor Freight Tools that don't suck #15,309
A fallen nut or washer can wind up in places and positions that amaze me.
/ Harbor Freight Tools that don't suck #15,311
Interesting new vise.
Bruce
/ Harbor Freight Tools that don't suck #15,313
With a hitch vise, you can have a receiver on your workbench in the garage, in the barn or shop, your tractor, and your truck, then move the vise to where the work is.
Bruce
/ Harbor Freight Tools that don't suck #15,314
I've a lot of low shelves that small parts and tools like to hide under. I picked up several of the magnetic tool holders when they were free or a $1. I tie a strong string on them and keep them scattered around the shops. Thus when I drop something I can slide the magnet underneath the shelving.
/ Harbor Freight Tools that don't suck #15,315
25% off one item. Exclusions apply, read the fine print.
LINK
Exclusions don't leave much. Not sure how you present the original coupon if it's an online coupon. Technically if you print it out it's a copy. I've heard that if you give them the ID# of the coupon they'll accept it, but I've never tried.
/ Harbor Freight Tools that don't suck #15,318
"With a hitch vise, you can have a receiver on your workbench in the garage, in the barn or shop, your tractor, and your truck, then move the vise to where the work is.
Bruce"
My version of that, built about 12 years ago - theirs is probably lighter, mine weighs 100 pounds... Steve
2013 MACK GU713 CAB AND CHASSIS (A60736)
2013 MACK GU713...
2017 Ford F-250 Pickup Truck, VIN # 1FT7W2B63HED67208 (A61165)
2017 Ford F-250...
Auger and Bit (A60352)
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
