Home Made Creosote?
/ Home Made Creosote? #1
charlessenf
Gold Member
York County, SC
Kubota B7800
For a number of years, I've been soaking roofing shingles in diesel fuel and using it to treat posts I bury in the ground.
Now, I've taken to saving the black stuff that forms inside my steel fireplace box and adding it and some ash to the mix. Wondered - "Is this Creosote I'm making?"
/ Home Made Creosote? #3
Yes it is, and one heck of a good wood preservative.
/ Home Made Creosote? #5
I kinda thought that creosote was coal oil? (whatever that is)
So Lou, it's petroleum based?
/ Home Made Creosote? #6
Several variations as I understand it, but many solid fuels and some liquid ones when burnt or charred at low temps will produce creosote.
Much was made from coal that charred for coal gas for lighting. Many of the early municipal lighting systems used coal gas and one of those byproducts was creosote. Many woods will create creosote directly, think chimney fires. The dry creosote from wood boilers and coal stoves when mixed with diesel fuel makes a liquid creosote .
/ Home Made Creosote? #8
Do the roofing shingles dissolve completely?
/ Home Made Creosote? #9
OK, That's what I do. Scrape the black stuff from the insides of the firebox and mix it with the fuel oil (same as I use in my tractor). Curious to learn if there is an online source for this DYI creation.
BTW: "coal gas, gaseous mixture—mainly hydrogen, methane, and carbon monoxide—formed by the destructive distillation (i.e., heating in the absence of air) of bituminous coal and used as a fuel. Sometimes steam is added to react with the hot coke, thus increasing the yield of gas."
I did find that the stuff I'm scraping and adding to the diesel is CREOSOTE and how it forms: "
Additionally, in the early 1980’s, tests were conducted to discover which kind of wood created the most creosote in a regular “open” fireplace. The results were surprising. Contrary to popular opinion, the hardwood’s, like oak and poplar, created more creosote than the softwoods, like tamarack and pine. The reason for this is that if the softwoods are dry, they create a hotter, more intense fire. The draft created by the hotter fire moves the air up the chimney faster! Because it is moving faster, the flue gas does not have as much time to condense as creosote inside the chimney. Also, because the flue gas is hotter: it does not cool down to the condensation point as quickly.
Unlike softwoods, dense hardwoods tend to smolder more, so their flue temperature is cooler. This creates more creosote condensation on the surface of the flue. The misnomer that pine builds up more creosote than oak just isn’t true! It is not the sap in wood that causes creosote."
Still no source for creating a liquid creosote from these flakes.
No.
The fuel turns black/dark brown and the shingles remain relatively intact (though I've yet to try removing any of them after - what? - six years or more).
I added a plastic valve to a 5 or 6 gallon plastic bucket (old paint pail, drywall mud pail or similar) tossed in the shingles and filled the void with the diesel. Let it set for months, then pour some in an empty plastic coffee container (Folgers French Roast or Gourmet Supreme) and rest teh 4x4 post end in the mixture and brush it up the sides from time to time. Stuff seemed to get absorbed in the 4x4 nicely.
Recently been collecting and adding the creosote to the pail - have yet to try the new mix so I am not even sure it is disolving.
/ Home Made Creosote? #12
If you have ever used a cough suppressant with the word tussin in the name you have taken an expectorant called "Guaifenesin". Guaifenesin is made from creosote. It is used in most of the cough meds because it works. Stuckmotor's father wasn't blowing smoke when he made his "Meds". It might (no kidding) not be laboratory quality, but it must have worked or he wouldn't have kept doing it. There used to be "Acid Works" aka Creosote factories, along route 17 in NY's southern tier. Whenever I used to drive through there, my sinuses would clear right out.
:love: "Why should I press 1 for English?" Are you calling from a foreign (non-English-speaking) nation? In such a case that option would seem reasonable. But when calling from America? Shouldn't English serve as the presumption of a vendor?
As to the medicinal potential of my fuel oil mix, I'm not ingesting any of it (intentionally)! But I found a page on the subject down along the Guaifenesin* Rabbit Hole that mentions creosote 27 times ( ) as well as a link thereon to a page on Guaifenesin* ( ) which mentions creosote nary once!
So far, nothing confirming the "Creosote, it's in your cough syrup" allegation, above.
Even further off-topic, but seen in this thread as a concern:
Humans - Don't eat this ****!
Toxicity is expressed either via general depression with cardiac collapse or via the irritating/corrosive nature by irritation and burns of the skin and eyes. Brief exposures via inhalation may cause respiratory irritation. Oral exposure to larger quantities of creosote may result in stomach pains and burning of the mouth. Large doses (7 g for adults and 1–2 g for children) have been associated with death 14–17 h after ingestion.
* How in the dickens is this pronounced??
/ Home Made Creosote? #16
I found this:
Respiratory system
Paul Rutter PhD, FRPharmS, FFRPS, SFHEA, in Community Pharmacy, 2021
Expectorants
A number of active ingredients have been formulated to help expectoration, including guaifenesin, ammonium salts, ipecacuanha, creosote and squill.
Like everything (imho) it all boils down to amount and frequency. We all get oil on our hands every time we change oil, gas and diesel fuel when filling. Wash it off and you're fine. Getting it on you every day not washing is a problem.
Wearing gloves with creosote and exposed to it once every decade should be fine.
/ Home Made Creosote? #17
I sure would like to be able to buy a 5 gallon pail of it.
I remember sloshing it on regular k/d lumber for decks as a kid for my Dad.
/ Home Made Creosote? #19
Years ago it was common to use a mixture of roofing cement and kerosene to make a stain used to paint the undersides of roof soffits before the screening and boards were installed...
/ Home Made Creosote? #20
I suspect it's somewhat effective, but fell out of favor because of groundwater contamination.
I have a big gate & entry project coming up and I've been trying to figure out what to use; for a fairly free-standing structure I don't think bolting wood to a concrete base would be stable enough (given a 15' above-ground height) so I've been wondering about getting 20' posts and coating them in something before sinking them...
Case IH 475 Pull Type Disc (A64047)
Case IH 475 Pull...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
2015 GENIE S-65 MAN LIFT (A63569)
2015 GENIE S-65...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
