Treatment for PT plywood for outdoor ramp
   / Treatment for PT plywood for outdoor ramp #11
Just did a dry pour with bagged Quickcrete. Easy peasy. Prep the ground, make a form, lay in some matting or rebar and fill it with bagged Quickrete and wet it down. Repeat daily for a week and viola. Concrete pad without back breaking mixing. I did broom it off on the second day for surface texture.
   / Treatment for PT plywood for outdoor ramp #12
As a kid my Dad, Grandfather and I poured lots of concrete. The "boat" is still at homeplace because we had to mix by formula. Nowadays as 5030 said Quickrete makes it so easy. Never paint, rot, insects, etc. Once concrete done correctly it will be there longer than barn itself.
   / Treatment for PT plywood for outdoor ramp #13
in terms of a sealer, i'd use a top water based stain on ply. Olympic & Cabot are my choice.
2 coats. have not had good luck w/oil based products on horizontal surfaces esp decks where water pools up. realize yours is incline, etc. good luck, regards
   / Treatment for PT plywood for outdoor ramp #14
i put a water based deck/wood sealer on a trailer deck and ran out so finished the last half with a oil based one. The oil looks sooooo much better 2 years later.
   / Treatment for PT plywood for outdoor ramp #15
that could well be. many variables including type of wood, conditions, & location. it's all about our own experience, one of the main functions of this forum.
my only recommendation is that like paint, always go top of the line regardless of product type.
as a footnote, been staining cabin's horizontal surfaces for decades. on the horizontal deck surfaces where rain pools, oil based just didn't hold up (hardwood deck). 15 yrs ago i switched to water base top of line. good results, though pealing has occurred where rain pools & sits. best regards to OP
   / Treatment for PT plywood for outdoor ramp #16
Water is what will do the damage to your ramp even treated timber that sits in water long term will rot. Often a paint that seals the water out can do more harm than good. The paint envelope around the exterior of the timber will get a split or crack at some stage and let water in, but because of the paint around it the water will have difficulty evaporating. The timber will stay wet longer than a unpainted peice of timber My preference is to absolutely soak it with a oil based stain that soaks right in as a posed to paint type system that only seals the surface several applications of a oil based stain will resist water getting in but still allow it to dry should water get in
   / Treatment for PT plywood for outdoor ramp #17
In the bag? Cut open the bag? or Pour out and level?
I've got about 20 bags of quickcrete that soldified. Makes for a rough surface.
   / Treatment for PT plywood for outdoor ramp #18
Dump the bags in the form and scree the dry Quickcrete level and water daily and second day, broom the top. End result is a nice concrete pad and I roast the empty bags. At 73, I'm way too old to be mixing cement in a wheelbarrow.
That stuff eventually turns into a rock if you leave it set in the weather.
I have a 3 point cement mixer in the shed, I should sell it.
   / Treatment for PT plywood for outdoor ramp #19
I would form it up & pour concrete. Broom finish.
So would I. I built some sail boats using laminated plywood construction. It wouldn't be my choice for a permanent ramp. Form and concrete are much better.
However, for a temporary ramp what you describe would work for light weight machines. Might need some center support.... Use screws for clamping and Resorcinol Glue for shear strength. That is the standard. Clamp from the center outwards. Plywood varies greatly, Home Depot 3/4" has less than half the strength of marine quality 3/4 inch ply. Marine ply has exterior glue on the inner plies as well as outer. Pre-drill for the screws being sure to include screw shank clearance so that the screws can clamp the wood. Without shank clearance, screws will just hold the boards in register without clamping.
Nothing wrong with a good marine epoxy like Gougeon Bros. West system epoxy (the best).....but it probably isn't necessary for this. If you can keep the ramp from the damp, you can even use inexpensive plastic resin glue - which is much cheaper glue. All the glues absolutely require wet assembly & lots of clamping pressure.
I have not had good luck using an exterior paint to keep water from plywood. Hope to eventually figure that one out.
Luck,
rScotty
   / Treatment for PT plywood for outdoor ramp #20
That's a great understatement!
About 6 to 8 years ago I was building a jury rigged enclosure to make my 18' Hudson equipment trailer usable as a cargo trailer. The purpose was to have a sort of enclosed trailer to haul stuff down to Mississippi, yet be able to switch back to an open equipment trailer to haul my tractors. I wanted to be able to load over the course of a few months and wanted to stop with the tarps.
So I bought a bunch of 4'x8'x3/4" pressure treated plywood from various sources, Home Depot, Lowes and the local lumberyard in Virginia, a few sheets at each place. All cost about the same per sheet. And were supposed to be the same quality. The Lowes was the absolute worst. After a relatively short period of drying, maybe a week or so, it was noticeably lighter per sheet. On cutting it I noticed large voids on the inner layers, I mean voids the size of 12" dinner plates. And it delaminated easily.
The Home Depot and local lumberyard were only slightly better.
After that I went to relatively solid marine plywood (which I had to paint) and Advantech waterproof OSB.
Unused 2025 CFG H15R Mini Excavator (A49461)
Unused 2025 CFG...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2017 Ford F-150...
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
2021 KENWORTH T680 SLEEPER (A51222)
2021 KENWORTH T680...
2018 Toro Sand Pro Bunker Rake with Edger Broom (A49461)
2018 Toro Sand Pro...
John Deere 980 Field Cultivator (A50514)
John Deere 980...
