YanmarFever
Elite Member
- Joined
- Mar 10, 2002
- Messages
- 4,106
- Location
- Eating a melon..
- Tractor
- Branson 4520r 5520C- Yanmar FX235-D - Bad Boy rogue mower
A typical Japanese tractor exporter in Japan.
Not many YM machines over there anymore. Lots of KE, RS, AF and EF machines now. I did see a few Hondas. I was surprised by that.A typical Japanese tractor exporter in Japan.
| Name of the function in Japanese | Name of the function in English | Explanation | Examples |
| クリープ | "Creep" / Haulage | Special low gear, which is used for hauling or trenching work types | All tractors Kubota, Yanmar and Iseki uses this term |
| Uシフト | "U-shift" / Automatic transmission | Mostly used by GL-Kubota series or newer serivies. U-shift refers to the automatic transmission option. Check out what is the name of Automatic transmission nem for Iseki (on the right) | Kubota: "U-shift" Yanmar: No special name Iseki: "G-shift", "Q-shift", "B-shift" |
| 倍速 | "Baisoku" / Quick turn | Special function which allows tractor to do quick turn using its front wheels. Good for maneuverability. | Kubota: "Baisoku" Yanmar: "Baisoku" Iseki: "IQ turn" |
| ポンパ | "Pump" / Rotary up-down | Using pump-button (or lever) one can up and down rotary without using hydraulic lever. Also, when using pump, rotary goes down to depth which automatically set by driver. | Kubota: "Pump" Yanmar: Attachment up-down lever Iseki: Attachment up-down lever |
| バックアップ(バック上昇) | "Back Up" | If you switch to Back Up, the rotary will go up automatically when tractor moves back. | Kubota, Yanmar, Iseki: same term, there is no special name |
| オートアップ(旋回上昇) | "Auto Up" | If you switch to Auto Up, the rotary will go up automatically when tractor makes turn left or right. | Kubota, Yanmar, Iseki: same term, there is no special name |
| デフロック | Diff-lock | Mechanism which locks right and left axles of the tractor. Diff-lock allows tractor not to slip. | Kubota, Yanmar, Iseki:same term, no special name |
| 耕深調節・耕深制御 | Automatic plowing depth control | Option which allows one to set rotary's plowing depth. Here, in Japan, farmers use the option when the plowing ground is | Kubota, Yanmar, Iseki: Plowing depth dial or lever |
| 角度調節・水平制御 | Automatic plowing horizon control | This option which allows one to set rotary's plowing horizon level. Japanese farmers use the option so as to make plowing ground flat. | Kubota: "Monroematic" or "Monroe" Yanmar: Automatic horizon level control Iseki: Automatic horizon level control Mitsubishi: "MAC" |
| PTO逆転 | PTO Reverse Gear | Gear which allows to set rotary's claws rotation in the opposite. | Kubota, Yanmar, Iseki: all is same, no special name |
| ロータリーヒッチ | Rotary's hitch | Rotary's hitch is a special frame which is used at one of three common ways of rotary's attachment to tractor. | Kubota: B-hitch Yanmar: A2-hitch |
| ワンタッチ・クイックヒッチ | One Touch / Quick Hitch | One of the three common ways of rotary's attachment to the tractors. "One Touch" means that one need to used only one simple lever so as to attach or deattach rotary just with one move. | Kubota: B-hitch Yanmar: A-hitch Mitsubishi: Super Hitch |
Only saw one and it was full of water. Must have been standing in the rain for a while.You sure that isn't the back yard of one of the guys on this site?interesting video. Anyone see a loader? I didn't see a single one,
Or overnight.Only saw one and it was full of water. Must have been standing in the rain for a while.
it was Buck from EFC that did the expose on the Vietcong tractors back in the day...
Remember those? Boy were they ever ugly, more like smoke and mirrors for the unsuspecting.
Not only are there no loaders, the tractors themselves are small and from what I see there, are mostly used with rotary tiller/cultivators. Why so much emphasis on rotary tillage?
Farmers also have to seed, fertilize, tend the crop, harvest the crop... put in fence and irrigation, make hay, feed livestock, move manure and dirt - Where are all those implements?
And without a loader, how would Japanese farmers move all those implements & heavy items around?
So my question is, what machines do they keep on the farm rather than sell?
There must be machinery to help with all the other work on their farms.
Cal, it was Buck from EFC that did the expose on the Vietcong tractors back in the day...
We had a friend over there that hand picked our units for us, that's why they were so gorgeous.
And then Koyker Mfg loaders were the icing on the cake!
I met the some of the nicest people and members here because of those machines.
When we moved I filled a 20' dumpster of rototiller parts, wheels, tires, hoods, cabs, old seats, and tiller bkts ( I almost cried)
I cant dwell on Yanmars to much or I get depressed because it all ended so fast and ugly, thanks to the liars, I mean lawyers...
Maybe since just yesterday morningOnly saw one and it was full of water. Must have been standing in the rain for a while.
