New to me JD 430, 60” deck…
   / New to me JD 430, 60” deck…
Well, didn't accomplish much on it this week. I did fiddle with deck a little bit. I readjusted the wheels all the way up like it was when I bought it, then I tinkered adjusting the height. I got the blue wrench out and straightened the right front caster arm. It was tweaked ever so slightly inward. Took the wheel out. Heated it up, used a long axle that I had around that fit perfectly into top of caster arm. Looks alot better, but ended up breaking the top bushing by the prying. I'll be calling dealer or getting off ebay if dealer can't get them(M83541)...
   / New to me JD 430, 60” deck… #12
Dealer or go to Amazon...
2 pack of caster bushings at dealer was $9.84 + tax, and they even had them in stock!
   / New to me JD 430, 60” deck… #14
Good deal, probably means they sell a lot of them.
   / New to me JD 430, 60” deck… #15
ive had 430 since 1987 and until i got a deere 915 zero turn used it yearly-great machine-the only problem is that parts get hard to find ---good luck
Got the snowblower mounted up. I had to modify the bolt hole on the PTO extension I bought off eBay- it was off a smidge so I had to enlarge the hole on 1 side. After I had it mounted, I saw that the extension shaft was all the way into blower universal and touching the inner edge of it😡. So off it came so I could push the rest of extension onto the tractor shaft fully. Got it mounted again and it works! I also pulled the black seat edge fully off, as seat is getting replaced. I cut a piece off and put it on edge of hood, the part that rubs on top of dash. It works perfectly for that purpose, now the hood isn’t grinding into the black plastic dash…
   / New to me JD 430, 60” deck… #17
Yeah, that's a problem on the 430s. I've used a couple different things until I used a piece of door seal for Peterbilt cab door. Works great.
Lookee what I discovered👍-Kubota BX series rims are a perfect fit on the 430, and stick out 4” either way you mount rim. The JD wide rims it’s either 2-1/2 or 6”, so the Kubota rims are a happy medium 👍these are Kubota BX2380 rims, so I’m guessing any of the 12” BX rims from the 23xx or 26xx models will fit….
I found this tag from factory underneath pan next to frame, it’s a cardstock paper tag, looks like it held up pretty good where it was…
   / New to me JD 430, 60” deck… #20
You're going to give that 430 an identity crisis unless you paint those wheels yellow.
SKLP Massage Chair (A57149)
SKLP Massage Chair...
Unused 84" Bucket Attachment (A55272)
Unused 84" Bucket...
2010 JOHN DEERE 310J BACKHOE (A52709)
2010 JOHN DEERE...
Giyi Horizontal Log Splitter (A57149)
Giyi Horizontal...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58214)
2019 LOAD TRAIL...
garbage truck (A56858)
