Lifting safe - Ballast Box needed?
/ Lifting safe - Ballast Box needed? #1
Jtschnel
Platteville, WI
John Deere 1026R
I spend time here, mostly reading and learning. Have learned a lot and really appreciate those who post and assist.
I hope I have the correct place for this question, if not I apologize. I am having a gun safe being delivered next week and have opted to lift it off the delivery truck myself to reduce the delivery cost (they won't have to bring a fork lift with them). I'll then need to position it in the garage I've built out for cars, motorhome, etc.
I have a cabbed JD 3046R with an H165 loader, and wondering two things.
First, will that the 3046R with H165 loader be able to lift it off a larger delivery truck ... safely?
Second, assuming it can lift it, should I attach a ballast box before unloading? I don't have one yet but will purchase one before if needed.
The shipping dimensions of the safe are listed as 63.33 H x 42.79 W x 28.00 D, and the weight is around 750 lbs.
Many thanks,
Jim
/ Lifting safe - Ballast Box needed? #2
750# will probably be fine.
If in doubt, as soon as you get the load away from the truck, lower it as close to the ground as you can.
From what I can see your tractor weighs likely 3000+# so I doubt 750 will lighten the rear end much. If you do have a 3pt attachment, any weight back there at all will act as a ballast; people use a ballast box just because it's compact - a mower of any sort is likely to serve just as well, they may just stick out more so require some attention when driving to avoid hitting anything with them.
/ Lifting safe - Ballast Box needed? #3
I think your 3046 has enough weight (especially if the rear tires are filled) to handle 750 lbs. without 3PH ballast. 750 lbs. isn't really that much weight.
However, I do advise you to get a ballast box (or fabricate one). For heavier lifting, the box is the perfect implement to balance out the tractor/FEL.
/ Lifting safe - Ballast Box needed? #4
Do you have forks? I also agree you should be fine but like ning said hook up the heaviest attachment on your 3 point hitch, this issue with these delivery trucks is often the height. The object is not that heavy but your boom is already max out so you dont have all your lifting capacity... Make sure the load is as close as your tractor as possible, if possible have the truck in a low point and your tractor as high as possible.
/ Lifting safe - Ballast Box needed? #6
While everyone here has good numbers in mind, I have to disagree with the group here, just because of the unique lift to weight ratio I've observed on this particular machine. I have the 3033R, same tractor as your 3046R, with a smaller engine.
The trouble with this tractor is that the 320R loader is so unusually heavy that, even given the substantial weight of this machine, the ass gets awful light awful fast. In this particular regard, it is worse than any other machine I've ever owned. I can't even drive the thing up a damp grassy hill with the HD bucket installed, without going to 4wd if I don't have some weight on the rear.
That #750 lb. safe isn't much, with regard to the lift capacity of that loader (assuming 320R), but it's going to be awful high in the air. If your ground is anything less than level, you're going to want some implement on the rear of that tractor. Mind you, it doesn't have to be a ballast box; a snowblower, aerator, or brush hog works just as well.
/ Lifting safe - Ballast Box needed? #7
Your tractor will lift it fine as long as you have the counterweight on the 3ph.
Great excuse to get yourself a ballast box. I have just washed stones filling mine. But will add, also have the iMatch quick hitch to make attaching the ballast box to the 3ph.
You have not given any info how you plan to hook the FEL to the safe. Very important, and a pic of your plan will help with our help for you. If you have forks to slip under the pallet, then you should be good. If only a bucket, then prolly not good.
Now, if you can lift the safe off the truck bed, then hold that position while the truck pulls away. Then slowly lower the safe to the ground as you keep the load level.
Suggest not backing away unless perfectly straight away until the load is near the ground.
/ Lifting safe - Ballast Box needed? #8
Don't see a 320R loader?
/ Lifting safe - Ballast Box needed? #9
OP mentioned 3046R tractor. The preferred loader for that tractor is the 320R, although he could have gone cheap and bought the more economical (phased out) 300R.
More importantly, I want to see what's going into the safe. I'll show you mine, if you show me yours! :D
/ Lifting safe - Ballast Box needed? #10
I'd use a two wheel hand truck for a safe. I've put them in for people. Your tractor should be fine to get off truck.
/ Lifting safe - Ballast Box needed? #11
I would get a couple of old drums and fill them with water and lift them each drum being 400 or so
/ Lifting safe - Ballast Box needed? #12
Worst case, pick up the safe off of the truck with the tractor; have the truck leave, then lower the loader and hand truck it.
But seriously I think you'll be fine. Drop the loader as low as possible without hitting the ground when moving, don't make any sharp turns, and to really slow if it feels light at all.
/ Lifting safe - Ballast Box needed? #13
OP also mentioned a different loader which also shows up on TractorData as the H165 FEL. Threw me off, and now wonder if the 320R gives more (or less) lift to the JD 3046R tractor.
Interesting.
/ Lifting safe - Ballast Box needed? #16
They don't have a lift gate truck?
Bruce
/ Lifting safe - Ballast Box needed? #18
Bruce
When I have freight deliveries, they have a big upcharge for lift gate service, so I always opt to use my forks. One of these days I will probably order something too heavy for my little tractor.
/ Lifting safe - Ballast Box needed? #19
Do you have a tractor and no rear attachments whatsoever? Just put something on the back.
But barring the limited details, there are too many variables to answer this question...
We dont know if the tires are loaded
We dont know if you are using bucket and strapping the safe
OR if you have clamp on pallet forks
OR if you have actual quick attach forks
OR if the area is even level where this lift needs to take place.
But, do you have any implements for the rear of the tractor at all? If so, why even question it. Put something on. There is ZERO harm having something on the back while unloading. But how are things gonna go and whats it gonna cost if your tractor WONT lift it, and you have to take the time to then attach something, or worst case, have to reschedule a delivery?
/ Lifting safe - Ballast Box needed? #20
Ballast Boxes are handy...don't take up much room...very compact on the 3PH (unlike most implements) and can be used as a carry-all if one uses weight that can be removed.
Mine, which I've had for many years, is filled with sand. I'd estimate the weight at 600-700 pounds.
The best part, IMHO, is the compactness...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
2025 Safety Basket Forklift Attachment (A61572)
2025 Safety Basket...
2020 KOMATSU D51PX-24 CRAWLER DOZER (A64279)
2020 KOMATSU...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
2017 Hyundai 53' Dry Van Trailer (A62613)
2017 Hyundai 53'...
