TMG chipper
/ TMG chipper #1
CFar45
Member
Kubota LX3310, ZD21
Anyone have experience with TMG Chippers? I’ve been considering a chipper for some time but haven’t pulled the trigger because it would likely get infrequent use. It’s a “would be nice to have” but not a “need”. There are certainly better chippers out there, but given my anticipated use, I don’t really want to spend a lot. I also don't want to buy one that causes me so much frustration that it never gets used. Recently ran across a very lightly used TMG WC42 at a good price…unless someone’s just trying to unload their junk…. It’s made in China, distributed out of Canada. Looks similar to some out there sold under different brands. Any experience with these?? Thanks!
/ TMG chipper #2
No experience with that one, but with others ... a couple questions. Is 4 inches going to be enough for you? Any crooks/crotches in branches count, so you could wind up with jams on relatively small stuff unless straight. Gravity feed ... pretty much need someone dedicated to feeding the hopper AND you need to clear jams manually ... hydraulic feed much easier to back out of a jam & self tending so easier for 1 person operation. Also, with gravity, you need to lift branches higher to get into the hopper ... may be a problem with longer/heavy stuff, whereas hydraulic is a more horizontal feed chute & closer to the ground. Better than no chipper, but think about what you need to chip & whether it will work for you. I just lucked into a lightly used 8 inch, hydro feed woodmaxx for a little less than what that TMG goes for new in your link ... so, deals can still be found. At worst, buy the TMG, see how it works for you, & resell it if you find a deal on a better one that meets your needs more easily. Nothing is getting cheaper in the near term.
/ TMG chipper #3
/ TMG chipper #4
Power feed is much safer than "chuck and duck" self feeding. When one of those grabs a tree it sucks it in fast and there is no way to stop it. The power feed is a consistent slower feed and you can stop it any time.
Horizontal feed means a lot less lifting. I can chip trees that I can only lift one end of. With the angled gravity chute you have to lift the entire tree.
There are a lot of us here with Woodmaxx 8H chippers. They're $400 more than the TMG you're looking at but far more useful and safe.
Woodland Mills also makes good chippers that people here own and use.
/ TMG chipper #5
Yeah, both WM and Woodmax have hydraulic feed and horizontal input chutes for about the same amount of money. They're Chinese and distributed in Canada like the TMG.
Main differences between WM and Woodmax is Woodmax has a built-in way to raise the feed roller to remove a jam. WM makes the input chute to raise for more compact storage and for movement getting to location without whacking the back of the unit so easily.
/ TMG chipper #6
This.... probably why it is for sale. You need at least one hydraulic infeed roller, two is better. Do you have a rear remote? Some chippers have a self contained hydraulic system included.
/ TMG chipper #7
This.... probably why it is for sale. You need at least one hydraulic infeed roller, two is better. Do you have a rear remote? Some chippers have a self-contained hydraulic system included.
The Woodmaxx hydraulics are self-contained...pretty sure the Woodland Mills are as well...
Neither of these chippers are as fast as a "chuck and duck", but IMHO, much safer for a homeowner's use
Personally, I won't get within 30' (or more) of a chuck n' duck...
/ TMG chipper
All good points. Somewhat familiar with the woodmaxx and would certainly prefer one with power infeed. Never used the “chuck and duck” models, so wasn’t sure how much disadvantage they really are. I see a lot of them out there, so figured maybe worth a shot. Only experience is with larger, self contained trailered units - whole different ballgame. I wouldn’t even consider the TMG or similar at full price given the other options out there. This one is about 1/3 of new price. Probably someone trying to unload it due to all of the things mentioned. I think my question has been answered. Would love either woodmaxx or woodland mills. Just can’t really justify 3k for the amount of use it will get. Thanks!
/ TMG chipper #9
Just an additional manufacturer to consider-Victory. I shopped the usual suspects and was pretty much set on the 8H before stumbling on Victory- their 8” hydraulic indeed model is a virtual clone of the 8H at a lower price point (and free shipping as well). Final decider for me was lead time.
Been very happy with mine-we’ve been chirping limb piles left over from clearing various build sites around our place. Time consuming process for sure but, for us, more convenient and less risky than burning.
/ TMG chipper #10
I love that term. Seems to me it was invented by someone who had never used a manual feed chipper and needed to justify paying more than he had to for occasional use.
As one who has owned and used manual feed chippers for 25 years as an "occasional use" homeowner, unless you're made of money, I strongly suggest you pass on this needless option and spend your money someplace more worthwhile.
Power feed make sense for those who do a lot of chipping. But not for the typical property owner with occasional need for a chipper.
/ TMG chipper
Thanks! Hadn’t run across victory, but will check it out. Have to admit, I don’t need a chipper so badly that I’ve been actively shopping, but whenever I stumble across one, I get to thinking.
/ TMG chipper
Thanks. It seems there’s a lot of manual feed out there, so they can’t be entirely ineffective. I’ve never used a manual infeed, but more people than not seem to tell me to avoid them. People are definitely fans of their power infeed models and it seems that new prices for manual and power infeed aren’t too far apart in many cases.
/ TMG chipper #13
"Chuck and Duck" refers to the big self-powered commercial chippers...man killers...especially the older machines.
If you've ever been around one, you know how fast they pull material in...you'll also know they occasionally kick material back out...hence, the "duck".
Manual home machines, like the Woodmaxx 8M are ok...the advantage of hydraulics is one can walk away to get the get another branch while the chipper is pulling in what you've already loaded. After 3-4 years, I've never had a kick-back...I have had a couple jams due to a branch being too big to feed. Then it's a matter of reversing the feed roller.
With any chipper, never feed from directly behind the infeed chute....stand to the side. Wear gloves that are snug about the wrists. I wear a forestry helmet too
/ TMG chipper #14
The purchase of my 6" Salsco "Chuch and Duck" chipper several years ago was in agreement with TerryR's opinion that the extra expense (and possibility of failures of the hydraulic feed mechanism) was not worth the price for my use. I disagree with ericm979's statement that you must lift the entire tree. I have often dragged a tree, rested the butt on the lip of the in-feed chute, and walked back to tip the crown so gravity takes over.
The gravity feed is not as aggressive as a roller. Often the resistance of splayed branches against the tapered sides of the in-feed chute is greater than the pull of the blades necessitating tamping or pushing the stuck branch with another. Safety has a lot to do with situational awareness. Look at the branch you are about to chip to check for an errant limb that might snag you, feed from a balanced position, quit before fatigue clouds your judgement.
/ TMG chipper #15
When I had the Woods 5000 chipper, I normally cut the trunks to 5 or 6 foot lengths for easier handling.
The 5000 was a great chipper/shredder, but I wanted more capacity (my Woodmaxx will chip up to 8", but I rarely go larger the 6").
I do miss the 5000's shredder though...
Only thing I didn't like about the 5000 was it dropped the chips below the chipper
/ TMG chipper #16
As my life moved on around here in years, I ended up with two machines........
1. MacKissic Mighty Mac shredder / chipper....SC1650 HTE It still serves me the past 13 years. It is electric start ...gasoline powered ..4" maximum capacity chipping. It is really good at shedding small stuff....but can chip larger branches as well.
2. Woodland Mills WC68 PTO powered chipper. As time went on I needed a bigger machine to handle bigger stuff in larger amounts. Have used it over 3 years now.
I really like both machines to match the job at hand.
Cheers,
Mike
/ TMG chipper #17
We went to the WM WC46 so that we don't have to lift stuff very high to get them into the chute. Before, I'd used a MacKissic TPH-122 for about 16 years. It chipped up to 3 1/2 inches and did shredding in a separate chute. My source of leaves dried up; so, don't have much use for the shredding any more: just chop such up with the bush hog. Getting older and not as strong to lift stuff very high into the chute.
The WM unit with hydraulic feed is A LOT less dangerous for chipping vines. The Mac would whip them around and very quickly pull them in. The input feed roller controls the input rate to the WM unit. However, the WM unit whips whole trees around and tosses them mostly to the right side of the chute. One wants to stand back and to the left of the chute, but starting bigger pieces requires a pretty good jab to get the roller started on them, often starting with a smaller piece first.
The hydraulic part has been essentially maintenance free except for setting the safety bar tension at which it shuts the feed down. It's adjusted by a little screw set by a lock nut at the bottom of the unit.
Have yet to rotate the chipper blades (they have 2 sharp sides) after going through 2 seasons of use.
I carry a low lift hydraulic jack in the FEL to lift the feed roller whenever it jams. A scissor jack or very long pry bar would work as well. The Woodmax has an included lever for this. This is the reason why they do not provide a folding chute for storage.
/ TMG chipper #18
You know, it's possible to disagree without insulting the people you disagree with.
I have both kinds of chippers. "Chuck and duck" is not my term but it's commonly used. More accurately my experience would be push and push and push, then when it catches let go and turn away real quick so you're not pulled against the chute or whacked by branches Then stay out of the firing line so the stub that often shoots out won't hit you. Unless it's a very straight branch that's not too long, you may have to help it by repositioning or lifting the branch.
With the power feed chipper it's much easier to get branches to feed. They feed at a controlled rate and there's no stubs shooting out of the chute. I often can get a branch started and then walk away for another one while the chipper chews away. It's much better at handling irregular shaped branches but part of that is the larger throat.
For my use there's no comparison. Of course my experience is with these two chippers and the kinds of material that I have here to chip (brush and branches of the trees that grow here). Someone else's experience may differ.
Right now the list price on the MacKissick TPH185 chipper/shredder I have is $200 more than the list price of the Woodmaxx 8H. It's also got a shredder, which I used mostly because feeding small material was so difficult. When I bought it many years ago it was the only small chipper I could find. When I got the 8H the chipper/shredder was relegated to shredding leaves for my wife's compost piles. That's the one thing that it does better than the 8H.
/ TMG chipper #19
I have both kinds of chippers. "Chuck and duck" is not my term but it's commonly used. More accurately my experience would be push and push and push...
That exactly is my point. "Chuck and duck" doesn't describe the way it works at all. So why is it used to disparage manual feed?
I see that comment often, but in 25+ years of using a PTO chipper I've never had it happen.
/ TMG chipper #20
I see a lot of TMG stuff for sale at the local monthly auction listings (chippers, augers, flails, greenhouses just to name a few). I've looked at a few different products of theirs online where I could find reviews, and in general the reviews aren't particularly favorable.
Aluminum Fifth Wheel Tripod (A61166)
Aluminum Fifth...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2025 Pabreak Hydraulic Vibratory Roller Skid Steer Attachment (A61567)
2025 Pabreak...
UNUSED WOLVERINE PFF2-13-45W QUICK ATTACH MAST (A62131)
UNUSED WOLVERINE...
2015 Chrysler Town & Country Van (A61569)
2015 Chrysler Town...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
