Broke the Joystick base on my loader
   / Broke the Joystick base on my loader #1
Menagerie-Manor
Gold Member
Brookings Oregon
Yanmar YM2310D John Deere LX172 Woodland Mills HM126
So I need to locate a new cast mag base for my Besko loader stick, anyone have a source.
   / Broke the Joystick base on my loader #2
Y'all out of duct tape?
   / Broke the Joystick base on my loader #4
Unfortunately the base split in half, looks to be a Besko valve.
Ah, so super glue, then. Between those 2 things anything can be fixed! 😀
Sorry for your loss. Good luck in your search.
Looks like I'm gonna be sol on this part, Besko seems to be a very elusive, so probably be easier to swap in a new valve at this point.
   / Broke the Joystick base on my loader #6
Seems that certain Besko valve controls are of suspect quality. I think I've seen more than one complaint about broken linkage components.
   / Broke the Joystick base on my loader #7
I'm one of the guys that had to replace my Besko loader valve because I lost a $.69 spring for the one of the spools. Tried to contact Besko directly, but that was futile. Didn't even get a "go-to-hell" back from them. Also contacted 5 different dealers, and nobody carried any parts (gee...there's a surprise)
Ended up buying a new replacement valve assembly from Surplus Center. Pretty happy with the replacement. People there are very helpful too if you need some advice.
Here's a link if you want to check them out:
Yep, I was on that site earlier so will probably give them a call in the am to see what I can get asap.
   / Broke the Joystick base on my loader #9
Unfortunate reality might be that the part would be similar or higher price than new valve. I believe both Brand & Prince show a part number for their joy stick assemblies but would be pure chance if they had exact same mounting pattern.
   / Broke the Joystick base on my loader #10
Do you have the pieces that broke? Maybe take them to a machine shop and ask them to build you one. If it is the joystick mount I am thinking of it would not be that hard to build.
SHOP TOOLS (A58214)
SHOP TOOLS (A58214)
2013 CIMC REEFER TRAILER (A58018)
2013 CIMC REEFER...
1604 (A57192)
1604 (A57192)
2007 Hummer H3 4X4 SUV (A56859)
2007 Hummer H3 4X4...
2025 MS380R Mini Stand-On Track Loader Skid Steer (A56857)
2025 MS380R Mini...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
