Broke the Joystick base on my loader
   / Broke the Joystick base on my loader #1
Menagerie-Manor
Gold Member
Brookings Oregon
Yanmar YM2310D John Deere LX172 Woodland Mills HM126
So I need to locate a new cast mag base for my Besko loader stick, anyone have a source.
   / Broke the Joystick base on my loader #2
Y'all out of duct tape?
   / Broke the Joystick base on my loader #4
Unfortunately the base split in half, looks to be a Besko valve.
Ah, so super glue, then. Between those 2 things anything can be fixed! 😀
Sorry for your loss. Good luck in your search.
Looks like I'm gonna be sol on this part, Besko seems to be a very elusive, so probably be easier to swap in a new valve at this point.
   / Broke the Joystick base on my loader #6
Seems that certain Besko valve controls are of suspect quality. I think I've seen more than one complaint about broken linkage components.
   / Broke the Joystick base on my loader #7
I'm one of the guys that had to replace my Besko loader valve because I lost a $.69 spring for the one of the spools. Tried to contact Besko directly, but that was futile. Didn't even get a "go-to-hell" back from them. Also contacted 5 different dealers, and nobody carried any parts (gee...there's a surprise)
Ended up buying a new replacement valve assembly from Surplus Center. Pretty happy with the replacement. People there are very helpful too if you need some advice.
Here's a link if you want to check them out:
Yep, I was on that site earlier so will probably give them a call in the am to see what I can get asap.
   / Broke the Joystick base on my loader #9
Unfortunate reality might be that the part would be similar or higher price than new valve. I believe both Brand & Prince show a part number for their joy stick assemblies but would be pure chance if they had exact same mounting pattern.
   / Broke the Joystick base on my loader #10
Do you have the pieces that broke? Maybe take them to a machine shop and ask them to build you one. If it is the joystick mount I am thinking of it would not be that hard to build.
2009 International 4300 Truck, VIN # 1HTMMAAN79H163641 (A57453)
2009 International...
KUBOTA KX057-5 EXCAVATOR (A52709)
KUBOTA KX057-5...
2012 International ProStar T/A Day Cab Truck Tractor (A56858)
2012 International...
2016 Cat TL1055D Telehandler (A56435)
2016 Cat TL1055D...
JLG 660SJ (A58214)
JLG 660SJ (A58214)
2015 GENIE Z-62/40 TELESCOPIC/SCISSORING BOOM LIFT (A52709)
2015 GENIE Z-62/40...
