Harbor freight quick hitch
/ Harbor freight quick hitch #1
gd165623
Member
i have a nib harbor freight quick hitch that i bought for my old L3010 and never put it on. Thinking about putting it on my L2501 .Other than the top hook problem, what do you guys think of them. Price was right and it would sure make hooking up mower easier. Any thing else i need to know about it ? Thanks
/ Harbor freight quick hitch #2
I've got an L2501 with one. A new top hook made things easier. Also with the way my 3pt is adjusted for maximum swing, if the top link arm is adjusted most of the way inwards and I pull the 3pt all the way up it will make contact with and break my rear turn signals/lights. Fair warning. Otherwise it's been great.
/ Harbor freight quick hitch #3
Depends on the age of your implements... if they are new enough to conform to standard measurements. Mine are old mis-match implements and the HF QH just became another implement to put on and take off (depending on what I was going to attach.)
/ Harbor freight quick hitch #4
I put the info on another thread where you can
get the top hook
willy
Did you use the bushing adaptors on lower studs [or whatever they are called ] I have a new LP 1260 mower so it is qh ready
/ Harbor freight quick hitch #6
Like mine. Had on the 2025R and now on the B2601. Replaced top hook with the Amazon one that sets the hook out about a 1/2 inch. Also have a U shaped thing that can be used in place of the top hook on my back blade. I had one of the bottom pins come loose; didn't come out: crooked sideways a bit. Now, I put tape over the inside where the pin goes to secure them.
Oh, I think the top hook hole in the QH are not Cat 1. I drilled the holes out on the QH to put a Cat 1 pin in. Don't remember the details. Not the top hook holes specifically. Think it's the hole where the top link goes to the QH from the tractor. I replaced the bolts on the top hook with pins from Ken's stuff, BoltOnHooks. I used one of those multi size drill bits to enlarge the top link hole.
Dont they make slide on bushings for bottom hooks--rather than $30 per set attachment bushings,i would like to move bushings from one attachment to another
/ Harbor freight quick hitch #9
I need to try it again... see how it goes!!
You one time modify your non conforming implements so your QH works on everything and you don't have to remove it....
/ Harbor freight quick hitch #10
I cheated.... 1 inch water pipe on my CAT 1 Pins.... This is on my 600lb ballast box.... This is affordable way to have bushings on every implement
And yes its a draw bar bolted to ballast box with 3/4 inch threaded rod...
/ Harbor freight quick hitch #12
You can also just Amazon the things:
quick hitch bushing kit
These also have the top link bushings included.
The only issue I've had with the generic kits is sometimes you need to take a drill bit one size larger than the holes to make the roll pins actually go through. Just depends on luck. But they otherwise work great. Makes lifting heavy implements like our 800lb chipper solid as a rock, no rattling around in the hitch.
/ Harbor freight quick hitch #13
I bought the pair of Cat 1/2 and Cat 2/3 bushings at TSC for all my implements. Much cheaper than those $30/implement ones. TSC has those, too.
/ Harbor freight quick hitch #15
TSC has the bushings as they have quite a few
of them that's where I got the ones for my land
plane
willy
/ Harbor freight quick hitch #16
One more thing to note, is that you may need to get a PTO extender, to extend your PTO shaft about four inches, the extra width this hitch puts the implement back by. Depends how much overlap is on your shaft.
/ Harbor freight quick hitch #17
You can purchase a drive shaft to do the same thing
willy
2022 EZ-GO ELITE...
2018 TAKEUCHI TL8 SKID STEER (A64279)
2018 TAKEUCHI TL8...
3pt 6' Rotary Mower (A64119)
3pt 6' Rotary...
2007 Chevrolet Express 2500 Cargo Van (A61573)
2007 Chevrolet...
2014 FREIGHTLINER CASCADIA T/A SLEEPER TRUCK TRACTOR (A59914)
2014 FREIGHTLINER...
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
