pulling wire through conduit
/ pulling wire through conduit #21
Some time ago a licensed electrician told me just because wires will physically fit in a conduit doesn't mean you can, or should, do it. I believe there is also an amperage / heat rating limit as well. Probably not an issue with this job, but it's something I ran into with my construction a while ago.
Wires carry a lower amperage rating bundled vs loose. I’m not sure how many wires are bundled together factor into the rating.
/ pulling wire through conduit #23
I generally pull another pull string through along with the wires as well on long runs. You never know if you're gonna have to pull another wire through in the future. There's a risk of burning the insulation on the existing wires if you pull more through in the future, but if you're careful when pulling the initial wires through, they generally don't twist around too much, and again, if you use plenty of pulling lube and pull slowly, it's not been a problem for me.
not going aroud 2 90 and a 45...oops, I read a bit farther and see those are long bend corners, They will still add some resistance though.
exactly. i could pull those wires thru 4 of these 90's//... been there done that. i actually pull lots of hot tubs with 4 #4 thhn runs thru at least 2 of the 90's and in 1" pvc conduit , and that is never an issue.
/ pulling wire through conduit #24
In my area I could not find long bend 90's in 1 inch. Not at HD/Lowes nor electrical supply. Had to make them myself. Maybe a regional thing?
i actually prefer to make my own using a hot box. easier pull and can custom fit work better.
/ pulling wire through conduit #25
Another vote for @MossRoad's suggested method of connecting a rope or tape to the bundle. I don't trust the mesh for anything long or important, but I do use it.
I have used both fish tape and rope. Personally, I prefer rope, or pulling tape for longer runs.
From running fiber, I learned the trick of pulling an extra rope/tape when you do your main pull. It will save you grief later if you ever need it. The other trick I learned was to pull a line with a lube soaked raccoon tail or rag through the pull both ways before doing the real pull. It leaves extra lube on all the tight bits.
The first time that I saw the vacuum trick, I felt like I was watching magic. That thought was quickly followed by the thought of all the hours that I had wasted trying to fish something with fish tape. It works like a charm. Light rope and a plastic shopping bag and you are in clover.
All the best,
Peter
The first time I saw the vacuum trick was my first year at the newspaper. I was helping contractors install automatic paster units on the press that spin a new roll of paper up to speed, match it to the speed of the web on the expiring roll, then paste the new roll onto the expiring roll on the fly. Quite interesting. The contractors were looking for conduits that ran under and along the press under the concrete VS installing new conduit. They blew smoke from a little machine into an open conduit, then looked for it coming out. There were quite a few. When they'd find one they could use, they did the vacuum trick. Pretty ingenious.
/ pulling wire through conduit #26
Wires are THHN, longest pull between pull points is 70' +/-, ells are long radius, new pvc conduit buried and above ground. One end of the long pull is in a 10" at grade pull box with the 45 bend and the other is a condule, all other bends in the remaining 40 feet are through condulets. I tried one of those "Chinese" finger puller once, in the distant past, with bad results. I like Caver's idea. I actually increased the conduit size from code required 3/4' to the 1" as I knew it would be difficult. Arm chair eval now, I probably should have used 1 1/4".
Ron
I strip the wires, and put the largest one forward to the front of the finger puzzle, and bend it back into a hook. Then keep putting them in a little further back until you have all of the wires in the puzzle then tape the whole thing. I haven’t had one pull loose that way yet.
/ pulling wire through conduit #27
How did they have smoke as I have to trace some underground and no idea where it goes?
/ pulling wire through conduit #28
They had a little box that produced smoke, stuck the hose in the open conduit, and smoke would come out on the end, electrical boxes, etc. Probably something like a fog machine. This was 1988. I don't know if they bought it or invented it or what. They were a company that specialized in installing retrofits of newspaper machinery. Rough bunch of guys, but very efficient. Wouldn't trust them anywhere near my family.
/ pulling wire through conduit #31
I use a standard underground locator to trace conduits…even works in walls. Can also use tick tracer to find circuits.
/ pulling wire through conduit #32
I wonder if you could inject sound into an open conduit and hear it as you walked around?
Sound? In a newsprint press area?
Smoke sounds pretty good to me.
/ pulling wire through conduit #33
Dead quiet when the press(es) aren't running. Total sensory overload when they are. Like sitting inside of a truck engine compartment doing 55 down the highway.
Presses not running enough hours per day promoted consolidated printing plants and outsourcing of local printing jobs.
Consolidated printing plants pushed back deadlines to accommodate all of the different papers they have to print.
Pushed back deadlines contributes to non-current news in local papers that have to print at consolidated plants.
Pushed back deadlines = yesterday's news tomorrow.
Yesterday's news tomorrow = loss of interest in reading something you already learned on TV/internet.
Cancel my subscription.
That about sums it up.
/ pulling wire through conduit #34
Say it isn’t so… no daily for Moss?
I like the idea i of f compressed air after hours…
/ pulling wire through conduit #35
I still get it at the retiree rate of $50 per year. Just can't bear to let it go. They don't print a Saturday paper anymore.
/ pulling wire through conduit #36
That's less than 5 weeks SF Chronicle home delivery...
Cancelled twice but mom likes it and will spend mornings just silently ready through the pages... I think we are the last in the neighborhood...
At one time we had 3 papers!
That was the rates were so cheap no one could refuse.
/ pulling wire through conduit #37
One thing I learned the hard way is it can make a difference which way you pull. Where the each conduit piece come together the joint can be a leading edge in on direction that catches stuff as you pull, and a trailing edge in the other that won't catch stuff.
/ pulling wire through conduit #38
Good post.
Just installed 500' of 1 inch PVC in a trench, elevation change was 40' from one end to the other. Installed all the bell ends toward the direction I fed the wire from at the top of the hill. Making all trailing edges for lower friction for the wire pull.
Link to conduit wire fill calculator.
If you plug some numbers into the cells, it can determine Jam probability with your wire size.
/ pulling wire through conduit #39
My preference is for the Chinese finger trap type grip, and a pull rope. Lube helps a lot, and for big gauge wires the trusty Greenlee puller to pull the rope.
/ pulling wire through conduit #40
Those pullers are great. Used them loads of times. Just keep the idiots away from trying to pull 12 - #10 wires thru a 3/4ā€ conduit. šŸ˜šŸ˜‚
UNUSED RAYTREE REDM32-32" EXCAVATOR MULCHER (A62131)
UNUSED RAYTREE...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63118)
2004 Cadillac...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
2017 Ram 1500 4x4 Crew Cab Pickup Truck (A61568)
2017 Ram 1500 4x4...
49"X74" EXPANDED METAL TAILGATE (A62130)
49"X74" EXPANDED...
New/Unused Wolverine Ripper (A61166)
New/Unused...
