Edited Title - Kubota L4060, LS XR4141, or ?
/ Edited Title - Kubota L4060, LS XR4141, or ? #1
LADPT
Louisiana
Kubota L4240 GST & Mahindra 4530
Our Ford 3000 & MF 135 have had good long lives but are ready to be replaced. We have a 5ft bushhog, disc, cultivator, box blade, drag, and several homemade scoops for digging trees with skid steer quick attach fel. (FIL is selling skid steer but I’m keeping some parts)
I’d love a 40-50+hp tractor, but that’s pushing my budget and I’d need all new bigger implements with no money left to buy them. Father has a Mahindra 4530 fel which is a tank if I need it occasionally.
Tasks include: bushhogging fields and trails, grading 1,500ft gravel drive, planting a couple acres of corn, beans, watermelons, okra, squash, etc…, moving large potted trees, digging and planting trees for small orchard, raking limbs, landscaping, turning compost piles, moving mulch.
I’m thinking 30-35hp (minimum 25 @PTO), fel with as much lift as possible, 4wd. 5ft implements need to cover the tires, or at least come really close. Prefer: power shuttle/gst or hst, but could do dry clutched shuttle, ease of attaching implements, industrial tires.
JD and Mahindra are 5 miles away. Most other dealers are within 30 miles.
I’m struggling to find enough HP and tractor weight without going to 6ft width. Any guidance on specific models to look for is much appreciated.
I’d like to keep it under ~15k but could push that a bit for the right deal. Does this sound reasonable? Thanks
/ Edited Title - Kubota L4060, LS XR4141, or ? #2
For new the Bransons spec out pretty dang good in that class. I don't own one, but wouldn't have any problem buying one.
Their compacts have some weight to them and they are matched up to what looks on paper to be a great loader for the class of tractor. Their owners seem to love them as well.
Factoring in weight, lift capacity, HST transmission and budget I'd give them a look. Even the 2515 H which is only 25 HP it has some weight and a loader that lifts nearly double the comparable Kubota.
Standard L series on Kubota. Only thing that grinds me on those is the loader capacity is low. They make you step up to Grand L to get a decent loader.
Deere dealer will steer you towards a 3000 E series that is really feature poor compared to competition.
Branson 15 Series
For used, try and find pre emissions if you can. They are getting harder to find but are out there.
New Holland TC35 and TC45's were Shibaru built and would fit your bill well for weight and capacity.
Of course Kubota L3400 / L3800's. There are quite a few of them around.
Deere 4105 is a hydro, has some weight to it. Would be a good match for what you are looking for.
/ Edited Title - Kubota L4060, LS XR4141, or ? #3
Branson's are worth the look. I'm thinking you should look at the 20 series all so . Maybe a 4820H
/ Edited Title - Kubota L4060, LS XR4141, or ? #4
No matter what your budget is it always seems like adding $5k to it gets you something newer/better. I think that is the case here. I always think of Kubota and John Deere because that is most common in my area. I think you can find a used one in that price range but my guess is it will be 10 years old or older.
/ Edited Title - Kubota L4060, LS XR4141, or ? #5
I have a friend with a Mahindra 2615 that is in good mechanical shape but been left out in the sun so faded paint and some surface rust that meets your specs and price point. He is moving out of state and will not need the tractor any more. msg me if you would like me to get you in touch.
this is in Corpus Christi TX. BTW.
Thanks for the offer @DaBear3428 but I think I’m looking for something bigger.
MF 1635 seems a good size. 3k+lbs, 64.5” wide so 5ft implements will nearly cover tires, plenty power, pst transmission, easy 3pt hookups. One nearby for $17,900 just over 300hrs.
Might post in the MF forum to check out that price.
/ Edited Title - Kubota L4060, LS XR4141, or ? #7
I LOVE my Mahindra 1626 shuttle. The earlier 1526 is similar with a few cosmetic differences. Might look around for a used 3016 as well.
I bush hog and till A LOT with 5' implements.
950 hours so far. Never been back to the dealer.
/ Edited Title - Kubota L4060, LS XR4141, or ? #8
i would avoid a modern mahindra. if you go mahindra, get a 3 digit one.
/ Edited Title - Kubota L4060, LS XR4141, or ? #9
Both fine tractors - depending on their condition I would consider spending the time & money to rebuild and keep at least one of them.
/ Edited Title - Kubota L4060, LS XR4141, or ? #10
The Ford 3000 and MF 135 are roughly the size of a larger compact like a 4 series Deere. Even then, finding one narrower than 5' might be a stretch if it's on fat industrial tires. You will have to do some looking to find a machine in that size range with a loader for $15k, and it's going to be pretty well used. I'd probably go look on a classified site like Tractorhouse to look what you can get in the 30-40 HP range with a $15,000 ceiling.
If it was me, I would probably look at rehabbing one or both of the machines you have, as long as they serve you well. Both are very well thought of machines and even if you have to split a tractor or rebuild an engine, you still should have change left from your $15k.
/ Edited Title - Kubota L4060, LS XR4141, or ? #11
What is a modern mahindra? I have 2 an 04 model 2810 with over 1100 hrs and a 2017 model 2538 with over 500 hrs , Both have been excellent tractors, You might want to explain what you mean by modern.
/ Edited Title - Kubota L4060, LS XR4141, or ? #12
hope that works for you, but in the market today if it is a good deal jump on it fast.
Used market seems to be slowing down around here slightly…or rather prices are coming down. Many are dropping $2-4k (20+%) in less than a week on FB marketplace. I’m hoping the trend continues.
The 1635 doesn’t have SSQA or rear remote. Passing on it.
There’s a Mahindra 3616 but it’s lightweight at 2560lb base without loader.
Still looking and researching…building a spreadsheet of specs and used pricing.
/ Edited Title - Kubota L4060, LS XR4141, or ? #15
i hope it does slow down the market has been nuts lately.
/ Edited Title - Kubota L4060, LS XR4141, or ? #17
Why? Can you explain what you mean.
The only mahindra dealers i have seen are glorified lawn mower dealers with people who dont even know how to use their own computer system. I always have to explain how to search for parts for my tractor to them.
Thankfully, old enough mahindras are such good copies of internationals, you can order international parts.
My buddy has a 2014 ish mahindra 25 hp lawn tractor with back hoe. It was in and out of the shop so much due to poor manufacturing and deal incompetence, that he had to borrow my husquvarna lowes mower to get the work done.
The 40 series mahindra is very similar to an older machine like a 485 but with modern electronics on board. It would be the only model i would consider if only it had the mechanical injection pump.
plus mahindras have ZERO resale value if that matters to you. I was able to get 48hp with loader and bush hog for under $5000 used.
That being said, i would never buy a JD either due to their lobbying against right to repair.
Interestingly my local Mahindra dealer has always only carried Mahindra tractors, though he’s added Bad Boy mowers and Echo equipment.
My closest Kioti dealer is primarily a lawnmower shop, with a few smaller model tractors.
Point is it varies and we all have to gauge our local market.
/ Edited Title - Kubota L4060, LS XR4141, or ? #19
Ok thanks for explaining. My Mahindra dealer is great and My family has been dealing with them forever. Never had a problem.
/ Edited Title - Kubota L4060, LS XR4141, or ? #20
just goes to show YMMV, I have had great service from my local Mahindra dealer, they sell mostly Mahindra and some bad boy equipment. repairs have been better than expected and I love my 5145.
UNKNOWN  20 FLATBED GOOSENECK (A58216)
UNKNOWN 20...
2017 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A62129)
2017 CATERPILLAR...
832737 (A61166)
832737 (A61166)
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2025 SDLanch SDLE20 Diesel Mini Excavator (A60352)
2025 SDLanch...
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
