Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #7,621
Your lift arms position the front of the mower either on the skids or holding the front off the ground,
the slotted top link is to allow the rear of the mower to move up and down as the roller follows the ground.
/ Let's talk flail mowers #7,622
I've never used a flail mower and could use some help understanding whether I should get one.
I have some kudzu growing in some of my fields. What I am seeing is that the vines are growing an inch or two off the ground that they aren't being cut by my rotary cutter.
Is a flail mower an option to cut these vines growing close to the ground or would it tear up the cutting heads so much that perhaps I just try getting rid of the vines with a field cultivator?
/ Let's talk flail mowers #7,623
A flail mower with side slicer knives will shred the kudzu and brush.
A flail mower/flail crop shredder works best at the 2-inch cutting height
and will keep the brush managed as long as you mow every couple
of weeks if you have the time to mow
/ Let's talk flail mowers #7,624
A flail mower has a rigid back roller the width of the machine/cut. Unless your land is perfectly level, that roller rides up and down on the surface beneath the vegetation and sets the actual height of cut.
It’s hard to imagine you can cut consistently at 2” without some scalping 72” away or alternately 3” high.
On a field it does a nice job because that inconsistency would be tapered across the width and you never see it, but you may not be able to get a 2” cut across the whole field much less 1” on an inch by inch profile across the mowing width (so if you do it use a 48” not an 84”!)
/ Let's talk flail mowers #7,625
My fields are uneven enough that I suspect there would be a fair amount of scalping if I set the cutter low enough to cut these vines.
/ Let's talk flail mowers #7,626
Check into using dethatching blades:
/ Let's talk flail mowers #7,627
I wanted to give you all a follow-up to my previous posts. Well, I changed out the hammers to y blades. Raised the rear roller up 2 holes. Adjusted top link so skids don't drag and still keep it level mostly.
Much better cut. Still occasionally bog and belt slip, yes I checked and tightened them. Very slow first cut but did a decent job. I will go over it again after it drys out some.
One question I have is this Titan has a slotted top link hole. All the pictures I have sent show this spot used. Right below is a nonotted single hole . Would it be better to attach the top link to this so it would stay solid and not allow the front to move up and down? It moves enough so the skids hit and start dragging piles of grass.
I tried the solid( not notched hole) on my bumpy ground it caused it to dig in. If your ground is relatively flat level it will work better. For me the notched hole works best
/ Let's talk flail mowers #7,628
If your dealing with a large acreage and amount of kudzu and other brush the
Hiniker 6 foot model 5710 flail mower would be ideal as it has no rear roller and it
can be equipped with a ratchet jack height adjuster or a double acting hydraulic
cylinder to adjust the height.
The cup knives are swivel hanger mounted and will fall back if it hits an object .
It has a CV PTO shaft that allows for tight turns while shredding the brush.
/ Let's talk flail mowers #7,629
I agree. A 2 inch cut my 72” Caroni would only work well on very level ground. Too much scalping wears on the Y blades and belts. If you have 2manyrocks then Oh My I expect. Here are my blades, new vs old. They had been reversed once. My nephew mostly ran it in our sandy loam soil (no rocks whatsoever) almost as a tiller trying for a 2 inch cut. He no longer has access to it. :giggle:
then Oh My.
/ Let's talk flail mowers #7,630
That's very helpful because we have hard clay mixed with rocks.
I found a field cultivator with spring loaded tines and hope to get it tomorrow. I think it will help to tear up the vines.
/ Let's talk flail mowers #7,631
Have a field bordered by railroad track with kudzu. Encroachment always a problem. Cutting two or three times a year for hay helped keep it controlled. Cows liked it but hard to dry evenly with mixture of leaf and vine. After we stopped hay making, bush hogging helped. It does not like getting cut back and grass can crowd it out if you keep it mowed. I have used the FEL grapple to skim and gather the vines. 2-4D kills it and not grass. Didn’t have much luck cultivating control with spring tooth plows or field tiller. Running livestock on it will control or eliminate it.
Had a few wind up problems with vines on truck drive shaft, rotary mower pto shaft and spindles. Seconds and you have a round bale of green tough vines to cut off. Hate to see a flail rotor wad.
/ Let's talk flail mowers #7,632
If nothing else, I figure I can use the field cultivator to gather the vines. I think the determining factor is whether I can dig out the kudzu tubers because that will kill the plant. So I'll be experimenting with tine spacing, depth....
A USDA agent recommended Milestone, Chapparel, or Open Sight to kill the kudzu. I am giving Whetstone herbicide a test run at the moment.
I don't know if kudzu would tend to wrap itself around the drum on a flail mower. Is that likely to happen?
/ Let's talk flail mowers #7,633
I haven’t used a flail mower on kudzu. Depends probably how often you mow, mower type and operation. Sometimes my kudzu is 6’ high covering the grass. Takes considerable Hp to mow and mulch. Once wrapping starts it’s almost instantly a problem. It’s like mowing baling twine. Been dealing with the good and bad of kudzu for 50 years. Eventually it’s going to win.
/ Let's talk flail mowers #7,634
Any long stem growth will wrap itself around any type of mower
if it is long and thin stemmed. A flail crop shredder with cup knives is
designed to cut through that type of growth.
You have to have enough horsepower to run a flail mower to allow
it to spin up to 2200 RPM plus to work well taking half cuts in deep
thick stemmed brush.
/ Let's talk flail mowers #7,635
Update on my flail (JD 25A) first use and first time user. Cuts so much nicer than the brush hog and no rows. I love it! Some of the field was a 2nd time cut but most was first time through. Since it has been so dry it cut fairly easy. Fuel intake seemed to be about the same for me. The before and after pic is first time this year and most likely last. These fields are in the mountains in north east PA about 2100 elevation and I only keep them mowed so not to be over taken with brush. 2nd pic is a different field with a combo of 1st and 2nd cut. 2nd cut was like a lawn mower.
Only issues I had were rolling fields so it scalped a bit but not bad. Less than the hog. Bigger issue was some of the grass was thick and wrapped on the rotor and wrapped tight she started smoking after a bit. I cleaned it out and the belt side wrapped up again but other side wrapped and then cleaned itself out. Belt wasn't hot or smoking and neither were the bearings. I thought it was that at first but it was the friction of the grass and rotor from what I can tell. Grass was burnt black on the real packed stuff. Just had to keep and eye on it so as not to torch the field. Had to go about 0.5 mph in the real thick stuff. Not sure what that grass is but its near swampy areas and gets about 2 feet high and super thick. Good news I don't have much of it. From what I could tell it doesn't like the tall thick stuff. It doesn't like soft ground either.
All in all I'm pleased and still lots to learn. Thanks to all that provided input and advice it helped a lot. Thank you!
/ Let's talk flail mowers #7,637
Hello nittanyjd,
I am glad that your first foray into mowing the plot went very well.
Are you using the top hole for the top link on the 25A?
Once you get into routine you can mow in 4 acre plots every two weeks to keep it tamed down.
After the first killing frost you will be able to mow everything down to 2 inches and not have a brush monster
to deal with if you have too much wet ground to mow without getting stuck.
To save time fuel and brakes you can start mowing in the center of your plot or plots and just mow in a spiral and
then you can just mow without stopping instead of having to stop, b ack up and turn around to mow the next row.
You can do the outer edges first or last for a couple of passes when your spiral mowing meets the tree line.
Having a fender mounted tractor radio or earmuffs with a radio in them helps reduce with the boredom.
Welcome to the "Flail Mower Nations"
/ Let's talk flail mowers #7,638
Hello nittanyjd,
then you20220820_131646.jpg can just mow without stopping instead of having to stop, b ack up and turn around to mow the next row.
leonz - I have an iMatch quick hitch on it and flail only has one hole. Its in the float when mowing and raise front end of flail in higher stuff. Real high and thick stuff I had to lift mower and roller up about 4 inches.
Grass wrapping around rotor and getting warm is my concern. I'm guessing that's from grass too high. Doesn't seem to wrap in lower tin stuff. 1st pic is where its wrapping..after I cleaned it out.
Do I have the best blades for cutting grass shown in 2nd pic? Wasn't sure if side slicers would be better Grass only. Very little brush at field edges. Have a brush hog for that stuff sitting nearby for that.
thanks again for the help everyone.
/ Let's talk flail mowers #7,639
I could see how tall grass could get pulled into that gap.
/ Let's talk flail mowers #7,640
leonz - I have an iMatch quick hitch on it and flail only has one hole. It's in the float when mowing and raise front end of flail in higher stuff. Real high and thick stuff I had to lift mower and roller up about 4 inches.
Grass wrapping around rotor and getting warm is my concern. I'm guessing that's from grass too high. Doesn't seem to wrap in lower thin stuff. 1st pic is where its wrapping..after I cleaned it out.
Good morning Nittanyjd,
The scoop knives you have are a multi-purpose mowing and shredding knife.
The side slicer knife with the slotted mounting hole is best suited for shredding brush
and mowing grass as you can make multiple passes to shred the grass and brush to a
very fine clipping that will rot away and dissolve in the soil quickly.
2021 Kenworth T880 Tandem Dump Truck, VIN # 1NKZL40X6MJ464380 (A65563)
2021 Kenworth T880...
12 in. WRXLS Excavator Bucket Attachment (A64194)
12 in. WRXLS...
2020 WIRTGEN WR200 XLI SOIL STABILIZER (A62129)
2020 WIRTGEN WR200...
Pair of 480/80R36 Tires (A65640)
Pair of 480/80R36...
2014 Freightliner Cascadia Semi Truck (A66285)
2014 Freightliner...
2019 C&M TRAILER 16' COOL DOWN TRAILER (A65643)
2019 C&M TRAILER...
