Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #7,601
If someone has this model and can post pics of their belt setup?
Check this thread: Flail Mower - Mott Flail Mower shooting grass to the front
/ Let's talk flail mowers #7,602
Hi all, New flail owner. After reading almost all this thread, I bought a Titan fl165. Not impressed with cut I'm getting. It has the hammer blades on it and I'm trying to cut heavy clover and hay that hasn't been mowed this season. It will bog my L3800 hst unless I just crawl. I'm wondering if the included y grass blades would work better. They are not as sharp like the hammers are. Hammers are packing full of hay and not cleaning out. Running at 540, level and in 2nd hole from highest setting. Ground is rough but not terrible was planted in oats with grass seed mix last season.
Yes, switch to the Y-blades, hammers are for brush.
/ Let's talk flail mowers #7,603
You will notice a huge difference with the Y knives.
Generally speaking you'll hit your area up with the hammer knives to clear it out of brush and saplings. Then you mow it with the Y knives thereafter or as needed.
Think of it as hammer knives as a bush hog, and Y knives as a finish mower.
/ Let's talk flail mowers #7,604
They did sell toe guards for the reverse rotation machines to keep that debris from hitting the back of the tractor. I doubt you'll find an OEM unit now, but you might be able to knock one out if you're decent at fabrication...
So yea, looks like the idler should be inside the belt on your unit. Still think that's a higher input RPM gearbox, but if it works for you otherwise, have at it once you get the belt on.
/ Let's talk flail mowers #7,605
/ Let's talk flail mowers #7,606
Thanks toolslinger. I think what you are saying makes good sense.
Thanks Xfaxman: agreed that the belt seems short. Thanks for the picture.
Cheers guys
/ Let's talk flail mowers #7,607
Hello and good morning ColdRider,
I want to welcome you as the newest resident member of the "Flail Mower Nations" from
The Great State of MAINE.
Heavy brush mowing/shredding will bog down a flail mower and or burn up the V belts unless
you operate at a crawl or have massive horsepower available to use.
The side slicer knives will cut/clip the heavy grass more effectively for you and recut it to make
the clippings smaller to allow them to dissolve into the soil faster for compost.
A properly sharpened side slicer knife will have a cutting edge with a 37 degree cutting edge on it.
/ Let's talk flail mowers #7,608
Thanks for the replies. I'll try the y blades. No cutting today, first real rain in a long time.
/ Let's talk flail mowers #7,609
New tractor owner and first time poster here.
After reading a lot of this thread and some others, I settled on a flail mower instead of a brush hog.
I ended up getting this Titan FL135 from a dealer in my state. Apparently these are not very popular in Alabama and this dealer was the only one I found that stocked small flail mowers.
I haven't seen much info out there on this model, so I thought I would share.
This is an Italian mower made by Cosmo and imported by Titan Implements (not palletforks dot com). I paid $2000 for it at Dixie Horse and Mule Company. It came with hammers installed but also included the Y blades. I wouldn't say it's QH compatible but I was able to connect it to my QH.
My little Kubota BX has no problem at all running it and I have been abusing it quite hard clearing some woods. I have been very pleased so far.
View attachment 756753View attachment 756754View attachment 756755
Axleman, u will like that mower. My post right before yours is exact same except older. I have switched to y knives since I got my area cleared and it does good job. Check bolt tightness every so often. Even the locknuts will work loose
/ Let's talk flail mowers #7,610
Cold rider,
I have smaller version of yours it does cut grasses better with the y knives. If the "grass" is thick and tall it will bog have to slow down till u get cut down. There are several adjustments u can make to adjust cut . Hight at roller and top link. Try different settings . May work better
/ Let's talk flail mowers #7,611
Cold rider,
Thanks, it's all a big experiment. We'll get it figured out.
/ Let's talk flail mowers #7,612
Any idea where to get replacement hammer blades?
/ Let's talk flail mowers #7,614
Can you smart guys (and gals) help me pick a used flail mower, and maybe answer a question about different knife types? I'm located in central Wi, with a 45hp tractor (1969 Case 580ck w/draftomatic 3pt and pto). My main use will be grooming a few acres of pasture with a little bit of fallen tree branches and occasional smaller saplings to mow over/mulch. Not necessarily looking to make the pasture look like a lawn-just want something that cuts and mulches better than a brush hog.
I have a couple of options that are currently listed:
6' John Deere 25a
6' Land Pride FM3072
They're both listed at roughly the same price.
Any opinion on which would be better for my needs? Also curious if there is a performance difference between those two knife styles. I notice that the 25a has the knives attached to the rotor via a clevis looking thing, whereas the Landpride is just pinned to the rotor. Is there advantage of one over the other? I tend to think the clevis type attachment would handle trash/debris better but would love to hear all your thoughts. Thank you.
/ Let's talk flail mowers #7,615
6' John Deere 25a
Hello from Eastern WI.
I would personally take the JD 25A only because parts are going to be more readily available aftermarket. Either way, Flailmaster should have the knives and probably some other parts. The advantage of the clevis mount is the blades have an additional direction to move if they strike something. The knives will do just fine for what you are looking to do. I have an Alamo with a similar set up as the JD 25A, and I use it for the same stuff. I also mow my lawn with it, but I don't care much about my lawn so it does just fine for me. Just be careful on the fallen branches. I try to not run over anything over an inch or two. I've had larger pieces wedge into the hood and destroy my belt. When I mow heavier grass it will leave a nice carpet of clippings behind. I'd snap it up quick as they don't last long on the used market in this area it seems.
/ Let's talk flail mowers #7,616
Thanks Adell. I've been watching the market for at least a year now. You're 100% right-good deals are gone in a heartbeat. I haven't jumped at either one just yet because they feel a little over priced for my blood. But then again what doesn't these days!? Curious what you think a fair price is for either unit?
I'd love to get an Alamo mower like you mention but the few I ever see listed that are in serviceable condition also end up way too high priced. What model Alamo do you have and what tractor do you use it on?
/ Let's talk flail mowers #7,617
I'd anticipate the JD to be about $1200 and the Land Pride to be about $1500, but those might be low as I'm basing this off when I was looking and selling a few years ago. Seeing that new prices have almost doubled on some implements, I wouldn't be surprised if they're asking double my numbers.
I would also like to note that those are not the original blades for the JD. JD used a duck-foot looking blade (seen in the Flailmaster catalog). But what is on there is a good replacement as those are the Alamo style blades. They are better priced and more readily available.
I have the SHD88 on my MF 2706E. I paid $1200 for it, but I drove 3 hours each way to pick it up in IL. It was an old Tollway mower and it was in need of all new blades, clevises, and pins. I also had to replace the rear roller after about 2 years use, because it was dented pretty bad when I got it. It broke one day mowing the ditch. I welded it back together to hold on until I was able to replace it. I was able to get the roller ends from Flailmaster and a piece of tube locally, and then weld it together myself. I also replaced the roller bearings at that time.
/ Let's talk flail mowers #7,618
6' John Deere 25a
I only have experience with a 6 ft Caroni with 56 Y blades & 28 clevis’s. I replaced all bolts, nylocks, and clevis’s recently in an all in refurbishment. Clevis’s are the most expensive part.
/ Let's talk flail mowers #7,619
6' John Deere 25a
I bought a JD 25A a few years ago that was severely abused and rusted into the ground. After replacing all the bearings, blades and clevis and several hours of welding it works like a charm. I was so happy with it's performance I cleaned it up and painted it.
/ Let's talk flail mowers #7,620
I wanted to give you all a follow-up to my previous posts. Well, I changed out the hammers to y blades. Raised the rear roller up 2 holes. Adjusted top link so skids don't drag and still keep it level mostly.
Much better cut. Still occasionally bog and belt slip, yes I checked and tightened them. Very slow first cut but did a decent job. I will go over it again after it drys out some.
One question I have is this Titan has a slotted top link hole. All the pictures I have sent show this spot used. Right below is a nonotted single hole . Would it be better to attach the top link to this so it would stay solid and not allow the front to move up and down? It moves enough so the skids hit and start dragging piles of grass.
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
2001 Blaw-Knox PF 150 Paving Machine  (A62679)
2001 Blaw-Knox PF...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2008 JLG 3246ES 32ft Scissor Lift (A64553)
2008 JLG 3246ES...
Transfer Pump (Electric) (A64127)
Transfer Pump...
