Eradicating moles
/ Eradicating moles #61
As has been said before here: mix 40% cement with 60% corn meal. carefully fill the hole and cap it so no innocents are exposed.
I have had great success with this method
/ Eradicating moles #63
Moles eat grubs. Treat for grubs and theirs no food. No food and they go away.....
I just want to affirm how important and correct this is ... if you do not eradicate the food source you will always have moles ... just that simple.
/ Eradicating moles #66
Subscribed.
They have taken over my yard this past year. Barely can walk without twisting ankle.
/ Eradicating moles #67
It seems like it would be difficult and not desired to eliminate all the earthworms in your soil, since that is a large part of a mole's diet.
/ Eradicating moles #68
That’s what I am trying to figure out…..
/ Eradicating moles #69
There are several reasons I've settled on the Victor Out O Sight mole traps.
- Nash choker loop traps are inhumane. I started with these traps. They work very well, but do no kill the mole quickly. I've come home to find moles dragging that style of trap around the yard, and many times I've found the trap tripped, pull it out, and the mole is still alive in there. I won't use them again.
- The downward spike type traps... I tried those as well. I've found them tripped, but not once did I find a dead mole under it, nor blood on the spikes. To me, no mole = no dead mole = no evidence it worked.
- The scissors-type traps that you step on to set. They do work on shallow mole tunnels, but do not work well on deep tunnels.
Here's why I like the The Victor Out O Sight traps.
- Can be set in any depth of tunnel.
- Can be easily modified to work in any soil type, by pop-riveting a canning jar lid to the trigger plate, which increases the trigger area. Works in sandy soils better that way.
- Out of the 300+ moles I've gotten with this type of trap, only 2 were still alive in the trap. It just pinched the fur on their sides and held them there. I let them go in the woods. All the others were dead. So I'm making the assumption that they died faster than all of the other types of traps, and nothing got away wounded.
- These things are strong. You can't set them with your hands. You have to use cocking bars. I think the strength of the grip is what does in the mole so quickly.
Finally, the price. You can still get them for about $12 (see link above).
I've had 6 of them for 15 years now. They hang on a post under a porch roof. Very durable. I've never had to replace one yet.
If you have pets and are worried about them sniffing around and tripping the traps, the trigger bar will snap their nose. It's bitten my finger a few times. So I'd put an upside down bucket over the trap. You could put a brick or block on top of it if you're animal is prone to investigating things in the yard.
I suggest anyone with mole troubles pick up a couple of these traps and a bundle of the little orange marker flags. Walk around your yard and indent the mole tunnels with your heal and drop a flag next to the dents so you can check them the next day. When you find the tunnels with the heal dents popped back up, that's where you set the trap. If a heal mark doesn't pop up in a few days, it's not an active tunnel. Look elsewhere for the best productivity.
Anyhow, I'm repeating myself, so good luck.
/ Eradicating moles #70
That's what we've been trying to tell people for a couple decades. Yes, moles eat grubs like I eat chocolate eclairs. But their primary food is earth worms. You shouldn't put down grub control unless you have a grub problem. If you don't have a grub problem (patches of dead grass), you don't have moles feasting on grubs. It's just that simple. They're eating something else: earthworms!
/ Eradicating moles #71
The red-tail hawk in my yard in NC did a great job of keeping the moles in check.
I had a 10' 6x6 sticking up in the yard which he gladly used as a perch.
He also ate voles which are vegetarians and often get blamed for what the moles are doing.....
/ Eradicating moles #72
I am fighting the underlying cause, grubs, too. If I dig a small hole in this yard, I find 1-3 big fat white grubs. Look like Japanese beetle grubs I see pictured.
Am using Milky Spore organic control. Get it from Amazon in granulated your can use in a spreader. Seems to be working. Haven't read whole thread so sorry if this repeats. Here is link to what I use:
/ Eradicating moles #73
I have a mole breakout in my yard this year. I heard coffee grounds spread in the area deters them. Seems iffy to me (grubs likely are attracted by coffee grounds) but why not try it? So today I took the coffee grounds pan to the yard to spread out instead of the compost. I just hope the moles don't start earlier and dig faster starting tomorrow :oops::coffee::coffee::oops:
/ Eradicating moles #74
Contrary to popular belief, moles main source of food is earthworms. They do love the grubs, but its worms that sustain them.
Moles are carnivores. If they are in your yard, there’s a good source of meat. Worm meat. Grub meat. Other larvae meat.
So you can either make your lawn soil a sterile growing medium for grass by killing all the meat that lives there, or you can deal with the moles with traps or poisons. I don’t like poisons, so I trap them.
I stopped counting at 300 on our 1 acre, but after about 6-7 years of 50+ per year, they finally went to a manageable number of only a couple per year.
Victor Out O Sight mole traps are hands down the best. Less than $15 each. Can be set in any soil type. You can pop-rivet a canning jar lid to the trigger to increase trigger size in really sandy soil. Kills them fast and rarely misses. About as humane a trap as you can get, and I’ve tried most. It’s the only one I use.
/ Eradicating moles #76
I’ve tried everything
No one has tried everything.
I read somewhere that Rats hate tobacco. Won't cross it.
I hve tobacco seeds and will plant some to see if I can deter the little buggers with that.
My plan:
Raise my own tobacco unless I can buy some bales of it for cheap. Then till that into the soil around my garden. If it works, I'll consider myself a genius and gift myself some beers.
/ Eradicating moles #77
Chop up garlic. Spreading an area, wait a few weeks spread some more just ahead of the previous area. You basically will Herd then off your property. We grow garlic just to use as rodent control. We grow mostly 'red' garlic as they have more of a bite then the mellower ones.
/ Eradicating moles #79
Forget the Grandma cures and get some chemical 'Shots'. Cap over holes in an area and light one and put it down the hole. Cover with a shovel full of dirt and be ready to chop them out as they try to escape the smoke.
10ft. Fork Extensions (A59228)
10ft. Fork...
2011 Toro Multi Pro 1250 Gas Sprayer Cart (A59228)
2011 Toro Multi...
Kivel 48in Forks and Frame Skid Steer Attachment (A59228)
Kivel 48in Forks...
2015 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2015 Kubota...
John Deere 5105M (A53317)
John Deere 5105M...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
