15 years ago built pole barn.
/ 15 years ago built pole barn. #1
ROUSTABOUT
Elite Member
Luther Willis Hill, AR
Pettibone, Ford, Massey Ferguson, International, JD, David Bradley, home mades
I just showed up and started drilling holes and setting posts. Everything is fine and straight 15 years later. Had 18 inches of snow and a few lighter snows on it. Had old power poles and bolted chicken house trusses to them. Two bolts each.
/ 15 years ago built pole barn. #2
18 years ago, my wife and I (along with one of the tractors) erected a 47 wide x 95 long x 17 high Clearspan Storagemaster arch building that has withstood the test of time and Michigan winters and wind storms and looks as good as the day we put it up. I keep all the equipment in it and store rounds as well. Totally enclosed, solar powered ventilation fans and a metal 14' high roll up door at one end and a man door at the other.
I bet my Clearspan's total cost was maybe 1/4th of your stick built building, maybe. Best part is, because it has no rat wall or posts sunk in the ground but instead rests on 2 x 10 x length PT planks and screw in earth anchors every 8 feet on each side, here in Michigan it's totally exempt from any real estate taxes as it's considered a 'portable' building under the RTF act here.
/ 15 years ago built pole barn. #3
Good to hear your hard work has rewarded you for the last 15 years Rustabout, here’s to another 15 years!
I built my pole barn (24x40) over 20 years ago, it’s doing well too, only problem I’ve had is that it’s completely full of my treasure/junk. My plans are for another building that will be a dedicated workshop. Right now I can’t bring myself to spending the money at these inflated prices.
Mike
/ 15 years ago built pole barn. #4
(y) Dad use to say "Do right the first time"
Mike
Things are high, I can guarantee that one.
This one was 2200 dollars.
/ 15 years ago built pole barn. #7
Last year we built a 10'x12' wood shed out of mostly 2x6 treated wood and steel roof. Raised 3/4" plywood floor, slat sides, and open front on 4x6 timber foundation. All screwed together because we've gotten too old to hammer. Cost was about $2500 for top grade materials.
Comparing that to the 800 sq. ft barn my wife and I built years ago for $600, and the real dollar cost before inflation was about the same for each.
rScotty
rScotty
Yes, if you do the math. In the old days a jam up good team of mules was six bales of cotton. That will buy a new diesel pickup today.
500 lb bales and cotton was .65 a lb. Six bales. $20.00 was an ounce of gold. One fella I knew, sold 125 bales on Monday, Sept 28, 1929. His uncle didn't sell his. Said they finally burned his uncle's. Couldn't get ,05 a pound for it.
/ 15 years ago built pole barn. #9
5030 built his 95‘ x 47‘ building for 1/4 the cost of yours ($550).
Looks like he took you out to the woodshed Roustabout. lol
I just built it with two other fellas. It isn't mine. All the materials were someone else's junk. Power company had replaced a lot of power poles. Trusses were from a fell in chicken house. I just know he wrote me a check for 2200 for the 3 of us to put it together.
3 Point Hitch Attachmnet (A66734)
3 Point Hitch...
2012 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2012 CHANDLER TRI...
2018 MAGNUS MINI VAC TRAILER (A67714)
2018 MAGNUS MINI...
2018 Kawasaki 4x4 Diesel Utility Cart (A66734)
2018 Kawasaki 4x4...
16 Pipe Squeezer (A67714)
16 Pipe Squeezer...
2011 EDMONTON TRAILER MFG FRAC PUMP (A67714)
2011 EDMONTON...
