Help with roundup mixing.
/ Help with roundup mixing. #82
In general, soil itself acts as a filter. Like most filters, it can only handle a fixed volume at a time.
in Civil engineering not too long ago the mantra was:
"The solution to pollution is dilution."
My granddaughter is in Purdue Civil Engineering I should ask her if they still think that way.
/ Help with roundup mixing. #83
I suppose I could ask my son. He has an MS in ChemE. He did his thesis on using switchgrass for biofuels, but he works in a papermill. Part of his job is environmental controls and monitoring.
/ Help with roundup mixing. #84
As I expected, he had more questions than answers...soil type, weather, etc. Biggest risk would be in heavy clay soil with heavy rain right after. He did say that it would require an EPA report if 50 gallons or more are 'spilled'.
I did some estimates...to spray my entire driveway it would be something less than 20 gallons. (that's how many gallons it would take to paint a wall the size of my driveway...cannot imagine having to put the diesel on that thick. Given where we are, there are probably a lot more things that get to the groundwater than a little diesel fuel. There is brown coal nearby. Imagine every time it rains, the water soaks through that coal on its way to the water table. I would probably just use the herbicide myself, but I think panic over the use of diesel that way is a bit of Chicken Little syndrome.
/ Help with roundup mixing. #85
I used to work at a medical school, and they said that when I questioned dumping radioactive tracers down the sink. The translation was, "We don't want to deal with safe disposal and they will never catch us."
/ Help with roundup mixing. #86
So what is a good available substitute for Ortho Triox?
I maintain a commercial parking lot in industrial zone and one Triox in the cracks and crevices and good...
Now it is every 4 to 6 weeks roundup and string trimmer...
/ Help with roundup mixing. #87
Jeez guys, I put maybe a cup or two in a 40 gallon mix. That's sprayed maybe 2 times a year. I doubt that any ever hits the ground considering how heavy the vegetation is but if it did it would take 1000 years to get 50 gallons on the ground. Good Lord....
/ Help with roundup mixing. #88
I pour in equal parts Roundup or Glyphosate, 2,4D amine, Atrazine and add some surfactant and diesel fuel. If it's ditches I add Pramitol. I mix a gallon or so and pour it into my 40 gal sprayer. Results are fast and amazing.
You can leave the 2,4-D, atrazine and diesel out of this mix and get the same result. Diesel will instantly burn the leaves of the plant, and will not allow the Roundup and 2,4-D to be taken into the plant.
Atrazine mostly works as a pre-emergent and so does Pramitol. Pramitol is more of a soil sterilant and will kill/prevent more plants than the Atrazine. Pramitil does basically the same thing that Atrazine does, and more.
Roundup is much safer to apply than diesel.
I work with lots of high school athletic programs and there are still a few that use diesel to mark the lines on their football fields.
/ Help with roundup mixing. #89
Thanks for the great information you have shared. What is the best way to control an early infestation of Johnson grass?
/ Help with roundup mixing. #90
I understand what you are saying but on several points I have to disagree. I have used this mixture with great results for years, much better results than Roundup alone. Much better. It kills faster and lasts mutiple times longer. As far as atrazine goes, prior to Roundup ready corn seed we used almost exclusively atrazine as a pre and post emergent herbicide. We sprayed in pre-emergent and mixed it with the nitrogen post-emergent. I've been using a broadcast mix of atrazine and 2,4D amine for years over my turf grass to control early season weeds and primarily sand spurs. I mix it with my Reagent when I spray for fire ants. I use it in my total kill mixture because I have it. As for Pramitol, yes it is a ground sterilant and again I mix it with my total kill because I have it and I hope some of it makes it's way to the soil. With these mixes I usually end up only having to spray each once per year vs mutiple times of spraying with just Roundup. Thanks for your recommendations CTC.
/ Help with roundup mixing. #91
Vinegar/salt mixtures?
It has the advantage of shifting the soil pH, making regrowth in the crack harder for weeds. Of course, once the rainy season hits, the soil pH will reset, but hopefully you have the cracks sealed by then.
All the best,
Peter
/ Help with roundup mixing. #92
I sprayed half of the 20K sqft fescue K31 yard with 41% gly this morning in prep for reseeding as a result of getting some bad seed a couple years ago. (It had three or four different varieties of grass mixed for some reason) The other half of the yard is a good stand of clean fescue that was seeded a year earlier from a different batch of seed.
Anyway, the problem I always have in spraying and fertilizing is knowing exactly where I've been each pass. Try to use tire tracks as a guide but that doesn't always work well. So this time, I tried a bottle of blue dye as shown in the pic. The last picture shows the difference between sprayed and unsprayed with the blue dye showing up, ironically, as darker green. The dividing line is fairly apparent directly down the middle of the photo.
The problem was that the dye was not visible while spraying and only slightly visible after drying and then only next to the unsprayed grass. So, I had to resort to using tire tracks as a spraying guide. UGH! I have tried using spaced wire flags in the past but that isn't really a good solution either especially when using a couple passes at an angle to each other.
Wondering what you guys use for guidance when fertilizing and spraying lawns?
/ Help with roundup mixing. #93
All the best,
Peter
It's the gaps from concrete to asphalt...
plus the smallest of imperfections... parking lot is leased but almost no traffic... Never had weeds on surface when lot had lots of traffic but with almost zero traffic amazing how pesky the weeds can be.
/ Help with roundup mixing. #95
If what you call Johnson Grass is the same as what I call Johnson Grass, Roundup should work very well on it. This weed is usually not found in lawns, because frequent mowing will keep it from growing and spreading. In my experience, even low rates of Roundup are effective on Johnson grass, as long as it is growing rapidly.
/ Help with roundup mixing. #96
I agree with you that your mix will give you great results and will work quickly, and will last a long time. However, my opinion is that in your mix, the Roundup and 2,4-D are mostly wasted, because the diesel kills and burns the plant instantly, and does not allow the Roundup and 2,4-D to be taken into the plant and be translocated within the plant.
Translocation within the plant is how the Roundup and 2,4-D work to kill the plant, and the kill is slower than with diesel. Using diesel is similar to using paraquat, or sodium chlorate, or even MSMA. The all are contact killers and are not translocated.
And, since the Atrazine and Pramitol work in a similar way, one or the other could be left out of the mix.
I also believe that if you use only Roundup and Pramitol, your kill will be slower than with your mix, but should last just as long.
/ Help with roundup mixing. #97
Thanks, it is coming up in my field. I let my neighbor cut it for hay a couple years ago when my tractor was down waiting for parts. Everywhere he dropped a round bale I have Johnson grass, hemlock or thistle popping up. These guys around here bail anything for hay, he was supposed to clean his equipment. 🤬
/ Help with roundup mixing. #99
Talking to myself here again, but I did find some info on homemade foam markers for spraying, fertilizing etc.
Probably will rig one up to just drop foam under the center of the tractor which would be a big help in knowing where I've been and where I haven't.
My sprayer has a broadcast bar that is very wide but the nozzles spray pretty wide, roughly 20 feet wide. How do I know where I sprayed? Mostly guessing.
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
2016 Audi A3 Hatchback (A61569)
2016 Audi A3...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
New/Unused Landhonor Electric Hoist (A61166)
New/Unused...
2025 Unused SDLGC80 Electric Golf Cart (A60352)
2025 Unused...
Dad's Garage Decorative Metal Sign (A61569)
Dad's Garage...
