New Tree Shear slow closing.
/ New Tree Shear slow closing. #1
E. J. Jones
Mahindra 4025
I have to run my tree shear from my rear hydraulics (20' lines). It's very slow to open and close, do the lines have to be purged of air?
/ New Tree Shear slow closing. #2
It takes a lot of hydraulics to operate a tree shear. It's probably working as good as it will ever work. If it's opening and closing, air is gone.
/ New Tree Shear slow closing. #3
Did you check the level of the hydraulic fluid level? What diameter of hose did you buy? Double check for a kink or a pinch in the lines. Check with the loader up all the way and all the way down. Do not forget to rock the shear up and down with it up in the air.
/ New Tree Shear slow closing. #4
You don't mention much except "tree shear". They typically have HUGE cylinders. If you're trying to use 1/4" lines, it will for sure will be slow.
/ New Tree Shear slow closing. #5
Tree sheers have big cylinders and tractors don’t have very high volume hydraulics. Low diameter hoses won’t help either. It’s probably working as well as it’ll ever work.
Thanks for the replies and suggestions. It is a 5" cylinder and I'm feeding it with 1/2" lines. I did some checking and my pump is only rated for 8.3 gpm. I think you're all correct, it's working as good as it's going to with this setup.
/ New Tree Shear slow closing. #7
Did the hoses come with the shear?...if they didn't and were set up to operate a hydraulic top link...it's possible the hose has a reduced orifice for flow restriction...just a possibility...!
/ New Tree Shear slow closing. #10
We have a shear head or two for this. It has a lot of hydraulics, but it takes a lot too. Saw head is on it now.
/ New Tree Shear slow closing. #11
Consider going with a pto hydraulic pump if you need more speed. I bought a Ford 7710 that needed more hydraulics and the previous owner added a pto pump.
David from jax
/ New Tree Shear slow closing. #12
If my math is correct 5” cylinder would extend approximately 1.6 inches per second with 8 GPM inlet flow
Your math is either correct or we're both wrong.
/ New Tree Shear slow closing. #13
Theres a calculator for everything now. Google hydraulic cylinder cycle time.
/ New Tree Shear slow closing. #14
This one's slow at 13 GPM.
72'' Fork Extension (A61567)
72'' Fork...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
2019 Ford F-550 4x4 Dur-A-Lift DTAXS39 39ft. Bucket Truck (A60352)
2019 Ford F-550...
2007 Mercades GL Sedan (A60352)
2007 Mercades GL...
2005 Peterbilt 387 with Wet Kit (A61307)
2005 Peterbilt 387...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
