IndyJay
Super Star Member
- Joined
- Apr 23, 2021
- Messages
- 18,602
- Location
- S.E. Indiana
- Tractor
- 2021 Kioti DK4510MS w/Loader, Grapple Prev: Massey 1250
Don't confuse me with facts, I've already made up my mind...
I think I might not need a tractor then. I've been looking at the BCS walk-behind, but tractors seemed like they could do any kind of plowing. I was wrong.Subcompact tractors weigh 1,400 to 1,700 pounds. Subcompact tractors are fine for mowing grass and moving light loads around a smooth property in the FEL bucket. You can plow an established garden plot with a subcompact tractor, though most with a choice would prepare a garden with a PTO powered rototiller. Few employ subcompact weight tractors on more than two (2) smooth acres, three smooth acres tops.
As soon as a plow on a (light) subcompact tractor encounters any but the smallest underground root or other obstruction, including hard ground, the tractor will lose traction and stop.
When plowing dirt tractor capability is a factor of 2-WD or 4-WD and tractor weight.
A 4-WD compact tractor with a bare tractor weight of at least 2,700 pounds, such as the Kubota L3901 in the second video, will pull a single bottom turning plow through almost any moist soil, including sod which has been first mowed VERY SHORT or previously killed with Roundup/Glycophosphate. Plow will cut tree roots up to 1" if not too concentrated.
Compact tractors under 3,000 pounds bare weight operate in landscape, kitchen/commercial garden or hobby farm applications on one to ten flat acres.
BUY ENOUGH TRACTOR
No convincing because your drawings don't align with reality. I have not clue how many agree, but that doesn't matter; what matters is the physics of the situation, some drawing.
Here's what it really acts like:
What are you talking about?No convincing because your drawings don't align with reality. I have not clue how many agree, but that doesn't matter; what matters is the physics of the situation, some drawing.
And that the tractor’s CG moves as it yaws, rolls, or pitches, especially when it is in motion due to centrifugal force.Your drawing is right to some degree but you’re ignoring the fact that the front axel has stops.
Again, while experience makes an enormous difference, the physics of a 3 wheeled tractor and a 4 wheel tractor make the 3 wheeled tractor less stabile on slopes. Always!Depends on land your using for and how much seat time under your belt.
Hit a bump or a hole and all bets are off.And that the tractor’s CG moves as it yaws, rolls, or pitches, especially when it is in motion due to centrifugal force.
I thought about buying an older tractor like an 8N, but then I started reading about them flipping over. I'm sure you can use common sense be pretty safe, but I got to thinking that maybe all tractors could flip? Was looking for advice on safety. I was thinking I probably need a sub compact now because they look safer, but I could be fooling myself.
It for plowing new ground with stumps and roots, mostly the leftover roots.
Edit: I have no experience with tractors, if you couldn't tell.
Also comes to mind how the old 3 wheel ATVs all went away in favor of Quads. Those old three wheelers would flip in a heart beat. Basically the same tread width, same wheelbase.
And they were all wide fronts, so must be more dangerousFond this nugget when searching…
That would be true if both axles were rigidly connected. But every wide-front tractor I've ever used has the front axle jointed so that on uneven ground it isn't constanly trying to twist the machine.![]()
NASD - Tractor Overturn Hazards
No other farm machine is so identified with the hazards of production agriculture as the tractor. The rubber-wheeled, row-crop tricycle tractor of the 1930's revolutionized production agriculture. The tractor had the speed, power, flexibility, adaptability, and handling ease that helped move farminnasdonline.org
I was under the impression that they got banned because so many riders got their feet under the rears and they got eaten by the ride.There comes a point when it makes better sense to hire a dozer or excavator to root out stumps once they get to a certain size simply in order to get the job done without tearing up a tractor.
I was also thinking about the Consumer Product Safety Commission banning 3 wheelers because of all the accidents.
