new project
/ new project
The number that I have found is 34145-70010. I have not found any listed for that number. I can't get mine fixed I will go to making an electric pump to work
/ new project
More on my project , still waiting on water pump to come back. The connector to the altenator is sun damage as far as falling off , so I'm looking for a replacement connector. The connector is 4 wire and that back of altenator looks like this
/ new project
I need to know the wiring for this connector , not sure if I can make out the colors so may have to trace
/ new project
still looking for help finding the correct connector
/ new project #26
Wrong number. That's just a part serial number, no hits on the web at all.
The model is AH2015S Alternator. You can find it all day long on the web.
This alternator is used on Shibarura, Hinomoto, Yanmar and a few Kubotas too. It's automotive origins are on Mazdas from the 1970s into the 80s. Like the popular Mazda 323, later becoming the Mazda Series 3. It's also used on some Mitsubishi forklifts.
/ new project
Back working on my project tractor . I got the water pump back from rebuilder , now I need some hoses. I do not have anything to go by except the engine is a 2DR5 . I do not have the old hoses so I need a part number to be able to find them as the parts stores are no help
/ new project
even a good picture of what the hose looks like will help
/ new project #29
The 2DR5 & 2DR7 manuals are hard to find. between member BubbaGoat and myself, we have the largest stash of PDF manuals for these Mitsubishi & Satoh machine. just those with the 2DRx engines are a rare find. Wish I could help more. There is a pinned thread at the top of this sub-forum and it has a very helpful document to assist you.
/ new project
I may have a document coming from valley power with some hoses
/ new project #31
I just changed the alternator this weekend. The OE original lasted 41 years.
Guess what brand fits.
I have Mitsubishi on my Yanmar now. :)
/ new project
How do you change from 4 wire to 2 wire ? which 2 do you use and what do you do with the other 2 ? What about using a 1 wire ?
/ new project #33
My machine uses the 4 wire setup. 2 wires on the female Delphi connector spade terminals and then 2 eyelet wires that are tightened down.
Mitsubishi makes more than just one type of alternator. You'll need to find what type works for your machine. ;)
/ new project
Thanks , I'm still looking for a lower radiator hose and can't find one. I just got the parts book and it calls for a number 68401-00300. I tried on line search and no luck , any ideas ???
/ new project
Got the radiator hose fixed just did a splice of 2 hoses and some tubing. The tractor runs now and does not over heat temp at 176 . Also just taped the wire and plugged into the alt and charging battery at 13+ vdc
/ new project
I now have the FEL it is a JD. think it maybe a model 70 the bucket is 53 inches. Now I need to make the mounts and get some parts. I need a 2 spool control valve , I have found a 11gpm on e bay is that a good one to use ? I need the parts to tap into the hydraulic system , is there an adapter that mounts to the pump ?
/ new project #37
Ok I get how to turn off now with the lever . What is this part for ?
That's the cover for the fuses. You unscrew the hand knob in the center and the cover comes off
/ new project
I have found the control for the loader , I need to know how and where to splice the hyd line to connect to the loader valve.
/ new project
here is a page from the manual I have , is at the top wher I spice into the hyd pressure line
/ new project #40
I usually cut the pressure line & braze pipe fittings on the cut ends, Bell adapters work good. You can drill the line side to the size you need. Run the pump side to the IN on the valve & the OUT to the other cut line.
SHOP BUILT MINI VAC TRAILER (INOPERABLE) (A67714)
SHOP BUILT MINI...
TEXAS BRAGG 16 FOOT TRASH TRAILER (A68842)
TEXAS BRAGG 16...
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
THE MACHINE CO. THAWZALL H250 HEATER (INOPERABLE) (A68842)
THE MACHINE CO...
backhoe
backhoe
PORTA POTTY (A68842)
